1N5220...1N5267
Silicon Planar Zener Diodes
Standard Zener voltage tolerance is ± 20%.
Add suffix "A" for ± 10% Tolerance, suffix
"B" for ± 5% tolerance, suffix "C" for ± 2%
tolerance, Other tolerance, non standard
and higher Zener voltages are upon request.
Max. 0.5
Max. 0.45
Min. 27.5
Max. 1.9
Black
Cathode Band
Black
Part No.
Black
"ST" Brand
Black
Cathode Band
XXX
Black
Part No.
Max. 3.9
ST
Glass Case DO-35
Dimensions in mm
E
T
M
E
S
Power Dissipation
Ptot
Junction Temperature
Tj
Storage Temperature Range
1)
Symbol
Tstg
XXX
Max. 2.9
H
C
Min. 27.5
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Min. 27.5
Max. 1.9
Min. 27.5
Glass Case DO-34
Dimensions in mm
Value
Unit
1)
mW
500
200
O
- 65 to + 200
O
C
C
Valid provided that leads are kept at ambient temperature at a distance of 8 mm from case.
Characteristics at Ta = 25 OC
Parameter
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 200 mA
1)
Symbol
RθJA
Max.
0.3
VF
1)
1.1
Unit
K/mW
V
SEMTECH ELECTRONICS LTD.
Subsidiary of Sino-Tech International (BVI) Limited
Dated : 28/10/2010 Rev: 01
1N5220...1N5267
Zener Voltage Range
Type
VZnom
VZT
1)
Dynamic Resistance
Reverse Current
Temp. Coefficient of
Zener Voltage
TKVZ
at lZT
ZZT
ZZK
at IZK
IR
at VR
(V)
Min. (V)
Max. (V)
(mA)
Max. (Ω)
Max. (Ω)
(mA)
Max. (µA)
(V)
%/K
1N5220B
2.2
2.09
2.31
1150
0.25
100
1
很抱歉,暂时无法提供与“1N5246B”相匹配的价格&库存,您可以联系我们找货
