SE MI COND U CTO R
500 mW DO-35 Hermetically
Sealed Glass Zener Voltage
Regulators
Absolute Maximum Ratings
AXIAL LEAD
DO35
TA = 25°C unless otherwise noted
Parameter
Power Dissipation
Storage Temperature Range
Operating Junction Temperature
Value
Units
DEVICE MARKING DIAGRAM
500
mW
-65 to +175
°C
L
xx
x
+175
°C
L
: Logo
Device Code : TCxxx
These ratings are limiting values above which the serviceability of the diode may be impaired.
Specification Features:
Zener Voltage Range 2.0 to 75 Volts
DO-35 Package (JEDEC)
Through-Hole Device Type Mounting
Cathode
Hermetically Sealed Glass
Anode
Compression Bonded Construction
All External Surfaces Are Corrosion Resistant And Leads Are Readily Solderable
ELECTRICAL SYMBOL
RoHS Compliant
Solder Hot Dip Tin (Sn) Terminal Finish
Cathode Indicated By Polarity Band
Electrical Characteristics
Device Type
VZ @ IZT
(Volts)
Nominal
IZT
(mA)
ZZT @ IZT
(Ω)
Max
IR @ VR
(µA)
Max
VR
(Volts)
TC2V0
TC2V2
TC2V4
TC2V7
TC3V0
TC3V3
TC3V6
TC3V9
TC4V3
TC4V7
TC5V1
TC5V6
TC6V2
TC6V8
TC7V5
TC8V2
TC9V1
TC10V
TC11V
TC12V
2.0
2.2
2.4
2.7
3.0
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
100
100
100
110
120
120
100
100
100
80
80
60
60
30
30
30
120
120
120
100
50
5
5
5
5
5
5
2
0.5
0.5
0.5
0.2
0.2
0.2
0.5
0.7
1
1
1
1
1
1
1
1
1.5
2.5
3
3.5
4
5
6
7
8
9
Number: DB-035
Jun 2016 / F
Page 1
TC2V0 through TC75V
TAK CHEONG
TAK CHEONG
SE MI COND U CTO R
Device Type
VZ @ IZT
(Volts)
Nominal
IZT
(mA)
TC13V
13
5
TC15V
15
5
TC16V
16
5
TC18V
18
5
TC20V
TC22V
22
5
TC24V
24
5
TC27V
27
2
TC30V
30
2
TC33V
33
2
TC36V
36
2
TC39V
39
2
TC43V
43
2
TC47V
47
2
TC51V
51
2
TC56V
56
2
TC62V
62
2
TC68V
68
2
TC75V
75
2
VF Forward Voltage = 1.2 V Maximum @ IF = 200 mA for all types
ZZT @ IZT
(Ω)
Max
IR @ VR
(µA)
Max
VR
(Volts)
35
40
40
45
45
30
35
45
55
65
75
85
90
90
110
110
201
230
240
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
0.2
10
11
12
13
15
17
19
21
23
25
27
30
33
36
39
43
47
51
56
Notes:
1. TOLERANCE AND VOLTAGE DESIGNATION
The type numbers listed have zener voltage as shown and have a standard tolerance on the nominal zener voltage of ±5%.
2. SPECIALS AVAILABLE INCLUDE
Nominal zener voltages between the voltages shown and tighter voltage, for detailed information on price, availability and delivery,
contact you nearest Tak Cheong representative.
3. ZENER VOLTAGE (VZ) MEASUREMENT
The zener voltage is measured under pulse conditions such that TJ is no more than 2℃ above TA.
4. ZENER IMPEDANCE (ZZ) DERIVATION
Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an RMS value equal to 10% of the
dc zener current (IZT) is superimposed to IZT .
Number: DB-035
Jun 2016 / F
Page 2
TAK CHEONG
SE MI COND U CTO R
Typical Characteristics
1000
Total Capacitance [pF]
PD-Power Passipation [mW]
600
500
400
300
200
f = 1MHz
Ta = 25℃
VR = 0V
100
VR = 2V
100
VR = 30V
1
80
120
160
VZ - Reverse Voltage [V]
Temperature [℃ ]
Figure 1. Power Dissipation vs Ambient Temperature
60
80
Figure 2. Total Capacitance
Valid provided leads at a distance of 0.8mm from case are kept at
ambient temperature
1000
1000
Iz=1mA
Ta = 25℃
Ta = 25℃
Iz=2mA
100
Forward Current [mA]
Differential Zener Impedance [Ω]
VR = 20V
10
Iz=5mA
Iz=10mA
10
1
100
10
1
0.1
0.1
1
10
0.2
0.4
0.6
0.8
VF - Forw ard Voltage [m V]
1
1.2
Figure 4. Forward Current vs. Forward Voltage
Figure 3. Differential Impedance vs. Zener Voltage
300
100
PD = 500mW
Ta = 25℃
Reverse Current [mA]
PD = 500mW
Ta = 25℃
250
VR = 5V
200
150
100
50
10
1
0.1
0.01
4
6
8
Figure 5. Reverse Current vs. Reverse Voltage
10
15
25
35
45
55
65
75
Figure 6. Reverse Current vs. Reverse Voltage
Number: DB-035
Jun 2016 / F
Page 3
TAK CHEONG
SE MI COND U CTO R
Package Outline
Package
Case Outline
DO-35
DO-35
DIM
Millimeters
Inches
Min
Max
Min
Max
A
0.46
0.55
0.018
0.022
B
5.08
0.200
C
25.40
38.10
1.000
1.500
D
1.53
2.28
0.060
0.090
Notes:
1.
2.
All dimensions are within JEDEC standard.
DO35 polarity denoted by cathode band.
Number: DB-035
Jun 2016 / F
Page 4
很抱歉,暂时无法提供与“TC24VTB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.11405
- 1000+0.08940
- 2000+0.08851
- 5000+0.08674
