LS R976-NR-1
LS R976-NR-1
    AMSOSRAM(艾迈斯半导体)
    发光二极管/LED 红色 633nm 104mcd SMT
LS R976-NR-1 数据手册
www.osram-os.com Produktdatenblatt | Version 1.1 LS R976   LS R976 Chip LED 0805 Applications —Electronic Equipment —White Goods —Gaming, Amusement, Gambling Features: —Package: SMT package 0805, colorless diffused resin —Chip technology: InGaAlP —Typ. Radiation: 150° —Color: λdom = 633 nm (● super red) —Optical efficacy: 7 lm/W —Corrosion Robustness Class: 3B —ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM)   1 Version 1.3 | 2021-09-28 LS R976   Ordering Information  Type Luminous Intensity 1) IF = 20 mA Iv LS R976-NR-1 28 ... 180 mcd   2 Version 1.3 | 2021-09-28 Ordering Code Q62702P5178 LS R976   Maximum Ratings Parameter Symbol Operating Temperature Top min. max. -30 °C 85 °C Storage Temperature Tstg min. max. -40 °C 85 °C Junction Temperature Tj max. 95 °C Forward current TA = 25 °C IF max. 25 mA Surge Current t ≤ 10 µs; D = 0.005 ; TA = 25 °C IFS max. 100 mA Reverse voltage 2) TA = 25 °C VR max. 12 V ESD withstand voltage acc. to ANSI/ESDA/JEDEC JS-001 (HBM) VESD   3 Version 1.3 | 2021-09-28 Values 2 kV LS R976   Characteristics IF = 20 mA; TA = 25 °C Parameter Symbol Peak Wavelength λpeak typ. 645 nm Dominant Wavelength 3) λdom min. typ. max. 625 nm 633 nm 650 nm Spectral Bandwidth at 50% Irel,max ∆λ typ. 16 nm Viewing angle at 50% IV 2φ typ. 160 ° Forward Voltage 4) IF = 20 mA VF typ. max. 2.00 V 2.50 V Reverse current 2) VR = 12 V  IR typ. max. 0.01 µA 10 µA Temperature Coefficient of Peak Wavelength TCλpeak typ. 0.14 nm / K Temperature Coefficient of Dominant Wavelength TCλdom typ. 0.05 nm / K Temperature Coefficient of Forward Voltage TCVF typ. -2 mV / K Real thermal resistance junction/ambient  RthJA real max. 800 K / W Real thermal resistance junction/solderpoint 5) RthJS real max. 450 K / W 5)6)   4 Version 1.3 | 2021-09-28 Values LS R976   Brightness Groups  Group Luminous Intensity 1) IF = 20 mA min. Iv Luminous Intensity. 1) IF = 20 mA max. Iv Luminous Flux 7) IF = 20 mA typ. ΦV N 28 mcd 45 mcd 110 mlm P 45 mcd 71 mcd 180 mlm Q 71 mcd 112 mcd 290 mlm R 112 mcd 180 mcd 460 mlm Group Name on Label  Example: N-1 Brightness Wavelength N 1   5 Version 1.3 | 2021-09-28 LS R976   Relative Spectral Emission 7) Irel = f (λ); IF = 20 mA; TA = 25 °C OHL00555 100 Ι rel % orange 80 Vλ super-red yellow 60 40 20 0 400 450 Radiation Characteristics 500 550 600 650 nm λ 700 7) Irel = f (ϕ); TA = 25 °C 40˚ 30˚ 20˚ 10˚ 0˚ ϕ  50˚ OHL00408 1.0 0.8 0.6 60˚ 0.4 70˚ 0.2 80˚ 0 90˚ 100˚ 0.8  1.0 6 Version 1.3 | 2021-09-28 0.6 0.4 0˚ 20˚ 40˚ 60˚ 80˚ 100˚ 120˚ LS R976   Forward current Relative Luminous Intensity 7) IF = f(VF); TA = 25 °C 7), 8) Iv/Iv(20 mA) = f(IF); TA = 25 °C OHL00232 10 2 mA 5 OHL00642 10 1 ΙV Ι V (20 mA) IF 10 0 10 1 5 5 10 -1 5 10 0 10 -2 5 super-red, orange yellow 5 10 -1 1 1.4 1.8 2.2 2.6 10 -3 10 -2 3 V 3.4 Relative Luminous Intensity 7) Iv/Iv(25 °C) = f(Tj); IF = 20 mA OHL02378 IV I V (25 ˚C) 1.6 orange yellow super-red 1.2  0.8 orange yellow super-red 0.4 0 -20 0 20 40 60 ˚C 100  Tj 7 Version 1.3 | 2021-09-28 10 0 10 1 mA 10 2 ΙF VF 2.0 10 -1 LS R976   Max. Permissible Forward Current IF = f(T) OHL00420 30 mA I F 25 20 15 10 5 0 0 10 20 30 40 50 60 70 80 °C 100 TA Permissible Pulse Handling Capability Permissible Pulse Handling Capability IF = f(tp); D: Duty cycle; TA = 25 °C IF = f(tp); D: Duty cycle; TA = 85 °C OHL02140 0.12 IF A t D = TP tP IF  OHL02147 0.12 IF A T t tP D = TP IF T D= 0.08 0.06 0.04 0.005 0.01 0.02 0.05 0.1 0.2 0.5 1 0 -5 10 10-4 10-3 10-2 10-1 100 101 s 102 tp  0.06 0.04 D= 0.005 0.01 0.02 0.05 0.1 0.2 0.5 1 0.02 0.02 8 Version 1.3 | 2021-09-28 0.08 0 -5 10 10-4 10-3 10-2 10-1 100 101 s 102 tp LS R976   Dimensional Drawing 9) Further Information: Approximate Weight: 3.0 mg Corrosion test: Class: 3B Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC 60068-2-43)   9 Version 1.3 | 2021-09-28 LS R976   Electrical Internal Circuit 9) 1.2 (0.047) Recommended Solder Pad  1.2 (0.047) 0.9 (0.035) 1.2 (0.047) OHAPY607  For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning. 10 Version 1.3 | 2021-09-28 LS R976   Reflow Soldering Profile Product complies to MSL Level 2 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t Profile Feature Symbol Pb-Free (SnAgCu) Assembly Minimum Recommendation Maximum Ramp-up rate to preheat*) 25 °C to 150 °C tS Time tS TSmin to TSmax Ramp-up rate to peak*) TSmax to TP Liquidus temperature  60 2 3 100 120 2 3 Unit K/s s K/s TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 3 6 Ramp-down rate* TP to 100 °C 10 Time 25 °C to TP  All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 11 Version 1.3 | 2021-09-28 °C 480 s K/s s LS R976   Taping 9)   12 Version 1.3 | 2021-09-28 LS R976   Tape and Reel 10) Reel Dimensions A 180 mm W Nmin 8 + 0.3 / - 0.1 mm   13 Version 1.3 | 2021-09-28 W1 60 mm W2 max 8.4 + 2 mm 14.4 mm Pieces per PU 4000 LS R976   Barcode-Product-Label (BPL) Dry Packing Process and Materials 9) Moisture-sensitive label or print L E E V l e be sela ). k, H de L If an bl r co ba (R id m ity . H R hu 0% e e /6 tiv ˚C la ared ag ck re fr 30 _ < in pa % k of to 90 rs ea s d ). rs ou or te (p on rs H de , ou iti H an bjec ng ou rs co ˚C 72 si nd H ou 5 te 48 ˚C su es e H co ± 24 6 da e y 40 be oc tim ˚C e or < ith tim ill pr). or ct w O w nt 23 tim e at lo or fa M TO F s al tim at le ˚C at lo at or e. P th F l tic th va lo or ur O F lo s ui on be if: read en w ed l 4 5 F m la ce eq id lo g, n oc l ve vi 5a is in or be 24 de pr ve l 6 Le de , nt whe e te co g: , w e Le ve l ke r ou se da ba ed flo ur e Le ve m % ba e ba al st ur e Le r en re ed e re> 10 oi st e e fo tim ur se al op fo M se oi st ur as k, is or . 33 se is M oi st bed k, lo H an , g ph -0 M oi in an in F R ng ar rbl D M e ba T r po If bl ith % lif ki r C. (if S is p. w ea r ks lf J10 ba to et th va Y ea m rs m _ r w, < he ed 1 ee te Y d, EC iredicat S fte at nt > 1 W Hou D A flody qu In no ire 1. d e ou 4 8 re reity is qu/JE re 2. bo e M tim to es id 2b re C 16 : e a) S tim is IP ic ed loor tim e b) ev Humor or e en F tim lo or D 2a king nc te F op a) lo or 3. b) ba re F lo da e fe l 1 2 F If al re tim ve l 4. se d l 2a ve Le 3 an ve l ag e Le e B ve ur e Le at st ur e Le D oi st ur e M oi st ur M oi st M oi M N E RS s in IV O IT T S C nta N U TIO U coSEND Ais bUagRMEICO T E CThIS S d Barcode label < M RA OS  Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 Desiccant AM OSR OHA00539  Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033. 14 Version 1.3 | 2021-09-28 LS R976   Schematic Transportation Box 9) Dimensions of Transportation Box Width Length 260 ± 5 mm 230 ± 5 mm   15 Version 1.3 | 2021-09-28 Height 85 ± 5 mm LS R976   Type Designation System Wavelength (λdom typ.) B: 470 nm S: 633 nm T: 528 nm Y: 587 nm A: 617 nm R/J: 625 nm H: 645 nm O: 606 nm G: 570 nm L: Emission Color blue super red true green yellow amber red hyper-red orange green Color coordinates according CIE 1931/Emission color: W: white Package Type Q: CHIPLED 0603 / 0402 R: CHIPLED 0805 N: CHIPLED 1206 / CHIPLED with lens Light emitting diode L B Q H Lead / Package Properties 1: footprint: 0603 / height: 0.6 mm 3: footprint: 0603 / height: 0.35 mm 9: standard H: footprint: 0402 / height: 0.35 mm  Encapsulant Type / Lens Properties 1: focusing lens (=20°) 7: clear resin or white volume conversion 8: white volume conversion 9: clear resin  Chip Technology: 1: TSN 3: standard InGaN 4: AlGaAs 6: standard InGalP E: ThinGaN & package with 8 kV ESD stability G: NOTA, Powerflip, ThinGaN 16 Version 1.3 | 2021-09-28 9 G LS R976   Notes The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this data sheet fall into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. When looking at bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Subcomponents of this device contain, in addition to other substances, metal filled materials including silver. Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage, production, and use. Devices that showed visible discoloration when tested using the described tests above did show no performance deviations within failure limits during the stated test duration. Respective failure limits are described in the IEC60810. For further application related information please visit www.osram-os.com/appnotes   17 Version 1.3 | 2021-09-28 LS R976   Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version on the OSRAM OS website. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Product and functional safety devices/applications or medical devices/applications OSRAM OS components are not developed, constructed or tested for the application as safety relevant component or for the application in medical devices. OSRAM OS products are not qualified at module and system level for such application. In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.   18 Version 1.3 | 2021-09-28 LS R976   Glossary 1) Brightness: Brightness groups are tested at a current pulse duration of 25 ms and a tolerance of ±11 %. 2) Reverse Operation: This product is intended to be operated applying a forward current within the specified range. Applying any continuous reverse bias or forward bias below the voltage range of light emission shall be avoided because it may cause migration which can change the electro-optical characteristics or damage the LED. 3) Wavelength: Wavelengths are tested at a current pulse duration of 25 ms and a tolerance of ±1 nm. 4) Forward Voltage: Forward voltages are tested at a current pulse duration of 1 ms and a tolerance of ±0.1 V. 5) Thermal Resistance: Rth max is based on statistic values (6σ). 6) Thermal Resistance: RthJA results from mounting on PC board FR 4 (pad size ≥ 5 mm² per pad) 7) Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 8) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit. 9) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 10) Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.   19 Version 1.3 | 2021-09-28 LS R976   Revision History Version Date Change 1.2 2020-04-07 Dimensional Drawing Taping 1.3 2021-09-28 Brand   20 Version 1.3 | 2021-09-28 LS R976     Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 21 Version 1.3 | 2021-09-28
LS R976-NR-1 价格&库存
很抱歉,暂时无法提供与“LS R976-NR-1”相匹配的价格&库存,您可以联系我们找货
LS R976-NR-1
  • 1+2.68255
  • 30+2.59005
  • 100+2.40505
  • 500+2.22004
  • 1000+2.12754
库存:3
LS R976-NR-1
  • 5+2.50352
  • 10+1.32888
  • 25+1.12599
  • 50+0.92310
  • 100+0.71902
  • 150+0.70479
  • 200+0.69055
  • 250+0.67631
库存:4504
LS R976-NR-1
  • 5+2.50352
  • 10+1.32888
  • 25+1.12599
  • 50+0.92310
  • 100+0.71902
  • 150+0.70479
  • 200+0.69055
  • 250+0.67631
库存:4504
