E2221M025A120RL
E2221M025A120RL
    RELON(瑞隆)
    插件,D5xL12mm
    直插铝电解电容 插件,D5xL12mm 220µF ±20% 25V Ф5.00 x 12.00mm 2000Hrs@105℃
E2221M025A120RL 数据手册
E2 Series ●Low ESR, high ripple current ● ● Load life of 2000 hours at 105℃ RoHS Compliant ◆ 规格表 Specifications 项目Items 特性参数Characteristics 使用温度范围 Category Temperture Range 额定工作电压范围 Rated Voltage Range 静电容量允许偏差 Capacitance tolerance 漏电流 Leakage Current 损耗角正切值tanδ Dissipation Factor 温度特性 Low Temperture Characteristics (Max.Impedance Ratio) 耐久性 Endurence 耐湿负荷特性 Damp Heat (Steady State) 浪涌电压特性 (Surge Voltage) -55 ~ +105℃ 2.5 ~ 25V ±20%(M) (at 20℃,120Hz) 施加额定工作电压2分钟后读数,小于或等于规格值 (at 20℃) I≤0.2CV 或500μA(取大值) Less than or equal to the specified value. After 2 minutes application of rated Voltage at 20℃ Rated voltage (V) 2.5 4 6.3 6.8 7.5 10 12 16 20 25 tanδ (Max.) 0.08 0.12 Z(-25℃)/Z(+20℃) ≦1.25 Z(-55℃)/Z(+20℃) ≦1.25 (at 20℃,120Hz) (100KHz) 105℃施加额定工作电压2000小时,恢复到20℃后,产品性能应满足以下要求 The specifications listed below shall be satisfied when the capacitors are restored to 20℃ after application of rated voltage for 2000 hours at 105℃. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value 在60℃ 温度,湿度90%~95%RH的环境中,施加额定电压1000小时后,恢复到20℃后,产品性能应满足以下要求 The specifications listed below shall be satisfied when the capacitors are restored to 20℃after application of rated voltage for 1000 hours at 60℃,90%~ 95% RH. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value 浪涌电压=额定电压× 1.15(V) Surge Voltage=Rated voltage × 1.15(V) 在105℃环境中,按充电30秒;放电5分30秒,连续施加浪涌电压1000次(Rc=1kΩ),待恢复后测试,应满足以下要求 The capacitors shall be subjected to 1000 cycles each consisting of charge with the surge voltages specified at 105℃ for 30 seconds through a protective resistor (Rc=1kΩ) and discharge for 5 minutes 30 seconds Appearance No significant damage Capacitance change ≦±20% of the initial value D.F.(tanδ) ≦150% of the specified value ESR ≦150% of the specified value Leakage current ≦The specified value ◆ 外形图Dimensions (mm) ΦD P Φd α - 26 - 5 2.0 0.5 6.3 2.5 0.6 8 3.5 0.6 10 5.0 0.6 (L﹤16)1.0 (16≦L﹤22)1.5 (L≧22)2.0 E2 Series ◆ 纹波电流补正系数 Rated Ripple Current Coefficient 频率Frequency(Hz) 120Hz ≦ f ﹤1kHz 1kHz≦ f ﹤ 10kHz 10kHz ≦ f ﹤ 100kHz 100kHz≦ f ﹤ 500kHz 系数 Coefficient 0.05 0.30 0.70 1.00 ◆ 尺寸与个技术参数一览表Standard Ratings Cap(uF) Rated voltage (V) 2.5 4 6.3 W Rated capacitance (uF) Case size ΦD×L(mm) ESR(mΩ) at 20℃,100 KHz Leakage Current (μA) Rated ripple current (mArms/105℃/100kHz) 560 5*8 18 500 2900 560 6.3*8 15 500 3500 680 6.3*8 15 500 3500 680 8*9 12 500 5200 820 6.3*8 15 500 3500 820 8*9 12 500 5200 1000 8*9 12 500 5500 1000 8*12 12 500 5500 1200 8*9 12 600 5500 1200 8*12 12 600 5500 1500 8*12 12 750 5500 560 6.3*8 15 500 3100 560 8*9 12 500 5100 680 6.3*8 15 544 3500 680 8*9 12 544 5100 820 6.3*9 15 656 4100 820 8*9 12 656 5100 1000 6.3*12 15 800 4100 1000 8*9 12 800 5100 1200 6.3*12 15 960 4500 1200 8*9 12 960 5100 220 5*8 18 500 2690 270 5*7 20 500 2450 270 5*8 18 500 2690 330 5*7 20 500 2450 330 5*8 18 500 2690 330 6.3*8 15 500 3100 390 5*9 16 500 3100 470 5*9 16 592 3300 470 6.3*8 15 592 4100 500 5.5*7 16 630 3500 560 5.5*8 16 706 3500 560 5*11 16 706 3500 560 6.3*8 15 706 4100 680 5*11 16 857 3500 680 6.3*8 15 857 4100 820 5.5*11 15 1033 4100 - 27 - E2 Series ◆ 尺寸与个技术参数一览表Standard Ratings Cap(uF) Rated voltage (V) 6.3 7.5 10 W Rated capacitance (uF) Case size ΦD×L(mm) ESR(mΩ) at 20℃,100 KHz Leakage Current (μA) Rated ripple current (mArms/105℃/100kHz) 820 6.3*8 15 1033 4100 820 6.3*9 15 1033 4500 820 8*9 12 1033 5100 1000 6.3*12 14 1260 4800 1000 8*9 12 1260 5100 1000 8*12 12 1260 5500 1200 6.3*12 14 1512 4800 1500 6.3*14 14 1890 5100 1200 8*12 12 1512 5500 1500 8*12 12 1890 5500 1500 10*12.5 12 1890 5900 2200 10*12.5 12 2772 5900 270 5*8 18 500 2690 330 6.3*8 16 500 3100 390 6.3*8 16 585 3500 470 6.3*8 16 705 3500 560 6.3*8 16 840 3500 680 6.3*12 16 1020 3800 680 8*9 12 1020 4800 820 6.3*12 16 1230 3800 820 8*9 12 1230 4800 1000 8*9 12 1500 4800 1000 8*12 12 1500 5100 1200 8*12 12 1800 5100 1200 10*12.5 12 1800 5500 1500 10*12.5 12 2250 5500 220 5*8 20 500 2200 220 6.3*8 16 500 2900 270 6.3*8 16 540 2900 330 6.3*8 16 660 3100 330 8*9 14 660 4800 390 6.3*8 16 780 3100 390 6.3*12 16 780 3500 470 6.3*8 16 940 3100 470 8*9 14 940 4800 560 6.3*12 16 1120 3500 560 8*9 14 1120 4800 680 6.3*12 16 1360 3500 680 8*9 14 1360 4800 820 8*9 14 1640 4800 820 8*12 14 1640 5100 - 28 - E2 Series ◆ 尺寸与个技术参数一览表Standard Ratings Cap(uF) Rated voltage (V) 10 12 16 W Rated capacitance (uF) Case size ΦD×L(mm) ESR(mΩ) at 20℃,100 KHz Leakage Current (μA) Rated ripple current (mArms/105℃/100kHz) 1000 8*12 14 2000 5100 1000 10*12.5 14 2000 5500 1200 10*12.5 14 2400 5500 1500 10*12.5 14 3000 5500 2200 10*12.5 14 4400 5500 220 5*9 20 528 2690 220 6.3*8 18 528 3160 330 5*9 20 648 2690 330 6.3*8 18 792 3200 390 6.3*8 18 936 3200 470 6.3*12 18 1128 3500 470 8*9 15 1128 4100 560 6.3*12 18 1344 3500 560 8*9 15 1344 4100 680 8*9 15 1632 4100 820 8*12 15 1968 4500 1000 8*12 15 2400 4500 1000 10*12.5 12 2400 5200 1200 10*12.5 12 2880 5200 1500 10*12.5 12 3600 5200 100 5*8 35 500 2100 150 5*8 25 500 2100 150 6.3*8 20 500 2690 180 5*9 22 576 2690 220 5*9 22 704 2690 220 6.3*8 18 704 3100 220 8*9 15 704 3500 270 5*9 22 864 2900 270 6.3*8 18 864 3100 270 8*9 15 864 3500 330 5.5*10 20 1056 3100 330 6.3*8 18 1056 3100 330 6.3*12 18 1056 3700 470 5.5*10 18 1504 3500 470 6.3*12 18 1504 3700 470 8*9 15 1504 3700 470 8*12 15 1504 4100 560 6.3*12 18 1792 3700 680 5.5*14 18 2176 3700 680 6.3*12 18 2176 3700 680 6.3*14 18 2176 4100 - 29 - E2 Series ◆ 尺寸与个技术参数一览表Standard Ratings Cap(uF) Rated voltage (V) 16 25 W Rated capacitance (uF) Case size ΦD×L(mm) ESR(mΩ) at 20℃,100 KHz Leakage Current (μA) Rated ripple current (mArms/105℃/100kHz) 680 8*12 15 2176 4100 820 6.3*14 18 2176 4100 1000 6.3*14 18 3200 4100 820 8*12 15 2624 4200 1000 8*12 15 3200 4200 1200 8*14 15 3840 4500 1500 8*14 15 4800 4900 1000 10*12.5 14 3200 4900 1500 10*12.5 14 4800 4900 2200 10*12.5 14 7040 4900 47 5*8 50 500 1050 68 5*8 50 500 1050 100 5*8 40 500 1100 100 5*9 40 500 1300 100 6.3*8 40 500 2200 150 5*11 40 750 1900 150 6.3*7 40 750 1750 220 5*11 40 1100 1900 220 6.3*7 40 1100 1750 220 5.5*8 40 1100 1900 220 6.3*8 40 1100 2200 220 6.3*12 35 1100 2900 330 5.5*11 40 1650 2500 330 6.3*9 35 1650 2900 330 6.3*12 35 1650 3100 330 8*9 30 1650 3100 330 8*12 25 1650 3800 470 6.3*12 35 2350 3500 470 6.3*14 35 2350 3800 470 8*12 25 2350 3800 470 10*12.5 20 2350 4800 560 6.3*14 35 2800 3900 560 8*12 25 2800 3900 680 6.3*14 35 3400 3900 680 6.3*16 25 3400 4200 680 8*12 25 3400 4200 820 6.3*16 25 4100 4200 820 8*12 25 4100 4200 820 8*14 25 4100 4500 820 10*12.5 20 4100 4800 1000 8*14 25 5000 4500 - 30 -
E2221M025A120RL 价格&库存
很抱歉,暂时无法提供与“E2221M025A120RL”相匹配的价格&库存,您可以联系我们找货
E2221M025A120RL
  • 5+1.26405
  • 50+1.01331
  • 150+0.90589
  • 1000+0.68754
  • 2000+0.62785
  • 5000+0.59196
库存:316
