DCG 型超高压圆片瓷介电容器
Type DCG supper high voltage disc ceramic capacitors
特性 Feature
■容量范围 Wide capacitance range from 100pF to 10000pF
■工作温度 Operating Temperature: -40℃~125℃
■存储温度 Storage Temperature: -10℃~40℃
应用 Applications
超高压圆片瓷介电容器具有较宽的直流额定电压范围和宽的电容量范围,适用于高压电源的
滤波电路、电视机和显示器的高压电路中。
Type DCG high voltage disc ceramic capacitors have high rated voltage, often used in filter circuit for high
voltage supply and in high voltage circuit for TV set and monitor.
产品型号Part Number
DCG
101
K
30 Y5P
V
6
B L
5
型号 Type:
DCG:超高压瓷片电容器
电容量(Capacitance):
470:47pF
内部管理代码
Interior
managing
471:470pF
472:2200pF
103:10000pF
电 容 量 允 许 偏 差
Capacitance Tolerance:
M=20%
Z=+80%-20%
K=±10%
J=±5%
尺寸代码 Size:
见规格详情
See the specification
温度特性
temperature characteristic:
Y5P,Y5U,Y5V
额定电压 Rated voltage:
V=6000VDC
U=4000VDC
位引线间距 Lead spacing:
5=5.0mm
7=7.5mm 0=10mm
引线式样 Lead style:
L、J、
见引线形状 see the lead style
Figure1-2 and figure 1-4
位引线长度/包装方法/
Lead length/package:
B=20min.mm, 6=6.0±0.5mm
0=10.0±0.5mm,8=8.0±0.5mm,
W=3.4±0.3mm, A=7.0±0.5mm, J=3.2±0.5mm
F=12.7mm 编带/扇折,V=15.0mm 编带/扇折
引线直径 Lead diameter:
CP 线:
6=0.55±0.05mm 0=1.00±0.08mm
脚型 Lead style
规格Specification
产品尺寸(mm)
额定电压
Rated
voltage
(KV)
标称容量
Nominal
capacitance
(pF)
电容量允
许偏差范
围
Tolerance
DCG101K30Y5PV6BL0A0
6000VDC
100
±10%
DCG101K30Y5PV6JK0A0
6000VDC
100
DCG102K46Y5PV6UL0A0
6000VDC
DCG221K30Y5PV6JK0A0
SHM 产品代码
SHM Part No.
温度特性
Temperature
Characteristic
厚度 引线
直径
引线直径
Tmax
Dmax.
间距
d (mm)
(mm)
(mm) F(mm)
Y5P
7.8
7.0 10.0 0.55±0.05
±10%
Y5P
7.8
7.0 10.0 0.55±0.05
1000
±10%
Y5P
12.3 7.0 10.0 0.55±0.05
6000VDC
220
±10%
Y5P
7.8
7.0 10.0 0.55±0.05
DCG221K30Y5PV6VK7A0
6000VDC
220
±10%
Y5P
7.8
7.0
7.5
0.55±0.05
DCG222M39Y5UU6JK7A0
4000VDC
2200
±20%
Y5U
10.5 6.5
7.5
0.55±0.05
DCG222M39Y5UU6WK7A0 4000VDC
2200
±20%
Y5U
10.5 6.5
7.5
0.55±0.05
DCG471K34Y5PV6BL0A0
6000VDC
470
±10%
Y5P
9.0
7.0 10.0 0.55±0.05
DCG471K34Y5PV6JK0A0
6000VDC
470
±10%
Y5P
9.0
7.0 10.0 0.55±0.05
DCG471K34Y5PV6VK7AY
6000VDC
470
±10%
Y5P
9.0
7.0 10.0 0.55±0.05
备注 DCG471K34Y5PV6VK7AY 产品的耐压=6KVDC。
散
件
编
带
散
件
散
件
编
带
散
件
编
带
散
件
散
件
散
件
散
件
编
带
电性能指标 Electrical Performance
序号
No.
项目名称 Item
1
容量和误差 C
@25℃, 1 kHz and 1 Vrms
2
损耗系数 DF
2.5% max. (Y5P, Y5U&Z5U)
3.5% max. (Y5V& Z5V)
3
绝缘电阻 IR
@500 VDC,60S
10000MΩmin
150%额定电压
无击穿或飞弧。
No visible damage
参照规格表
6KV
耐电压
Rate
Voltage
4
技术要求 Specification
4KV
5
温度特性
temperature
characteristic
SL
﹢140~-1100(10-6/℃)
X7R
±15%
Y5P
±10%
Y5U
+22% to -56%
Y5V
+22% to -82%
标志 Marking
例如 e. g
26#号产品以下
≤ 26#
正面
Front
反面
Back
B
101
4KV
空白
Blank
编带样式 Taping style
30#号产品以下
=30#
B
101 K
6KV
空白
Blank
34#产品以上
≥34#
B
102 K
6KV
SHM
空白
Blank
DCG222M39Y5UU6JK7A0 价格&库存
很抱歉,暂时无法提供与“DCG222M39Y5UU6JK7A0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.88463
- 50+0.71777
- 150+0.63440
