ORPC-817SC-TP-C-G-(GK)
    ORIENT(奥伦德)
    SOP-4
    光电耦合器 5000Vrms IF=60mA VR=6V SOP-4
ORPC-817SC-TP-C-G-(GK) 数据手册
Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) ORIENT Photo coupler Product Data Sheet Part Number: ORPC-817-(GK) Customer: Date: SHENZHEN ORIENT COMPONENTS CO ., LTD Block A3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD TEL:0755-29681817 FAX:0755-29681200 www.orient-opto.com Copyright© 2019 Orient .All rights Reserved 1 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 1. Features (1) (2) (3) (4) (5) Current transfer ratio ( CTR : MIN. 50% at IF = 5mA, VCE = 5V ) High input-output isolation voltage ( Viso = 5,000Vrms ) Response time ( tr : TYP. 4µs at VCE = 2V, IC = 2mA, RL = 100Ω) ESD pass HBM 8000V/MM 2000V Safety approval UL approved (No.E323844) VDE approved(No.40029733) CQC approved (No.CQC09001029446) CE approved (No.AC/0431008) State Grid approved (No.SGCM013420170152 ) (6) In compliance with RoHS, REACH standards (7) MSL Class Ⅰ 2. Description (1) ORPC-817-(GK) photo coupler consist of one piece of GaAs emitter and one piece of NPN transistor. (2) Packaged in a 4-pin DIP package and available in wide-lead spacing and SMD option. 3. Applications (1) Switching power supply (2) Ammeter (3) Computer (4) Instrumental application, measurement machine (5) Signal transforming systems (6) Imbursement equipments, duplicating machine, automat (7) Family-use electric equipments, such as fans 4. Functional Diagram Copyright© 2019 Orient .All rights Reserved 2 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 5. Absolute Maximum Ratings at Ta=25℃ Parameter Symbol Rated Value Unit Forward Current IF 60 mA Peak forward current (100μs pulse, 100Hz frequency) IFP 1 A Reverse Voltage VR 6 V Input Power PI 70 mW Collector and emitter Voltage VCEO 80 Emitter and collector Voltage VECO 7 Collector Current IC 50 mA Output Power PO 150 mW Total Consume Power Ptot 200 mW *1 Isolation Voltage Viso 5,000 Vrms Max Insulation Voltage (Insulating oil test) V IOTM 10,000 V Rated Impulse Insulation Voltage VIORM 630 V Operation Temperature Topr -55 to + 125 Storage Temperature Tstg -55 to + 150 *2 Soldering Temperature Tsol 260 Input Output V ℃ *1.AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter onthe secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. Soldering time is 10 seconds Copyright© 2019 Orient .All rights Reserved 3 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 6. Electro-Optical Characteristics (Ta=25℃ unless specified otherwise) Parameter Symbol Condition Forward Voltage VF IF=20mA --- 1.2 1.4 V Reverse Current IR VR=5V --- --- 5 μA Input Capacitance Ct V=0, f=1KHz --- 30 250 pF Dark Current ICEO VCE=20V, IF=0mA --- --- 100 nA Collector and Emitter attenuation Voltage BV CEO IC=0.1mA IF=0mA 80 --- --- V Emitter and Collector attenuation Voltage BV ECO IE=0.1mA IF=0mA 7 --- --- V *1 Current transfer ratio CTR 50 --- 600 % Collector Current IC 2.5 --- 30 mA --- 0.1 0.2 V --- Ω Input Output Collector and Emitter Saturation Voltage Transforming Characteristics IF=5mA VCE=5V Min Typ.* Max Unit V CE(sat) IF=20mA IC= 1mA Isolation Impedance Riso DC500V 40~60%R.H. Floating Capacitance Cf V=0, f=1MHz --- 0.6 1.0 pF Cut-off Frequency fc VCE=5V, IC=2mA RL=100Ω,-3dB --- 80 --- kHz Rise Time tr --- 4 18 μs Fall Time tf --- 3 18 μs VCE=2V, IC=2mA RL=100Ω 5×1010 1×1012 *1 Current Conversion Ratio = IC / IF × 100% , CTR Tolerance:±3%. Copyright© 2019 Orient .All rights Reserved 4 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 7. Rank Table of Current Transfer Ratio CTR Rank Min. Max. L 50 100 A 80 160 B 130 260 C 200 400 D 300 600 CTR Rank Min. Max. A5 4 20 B5 6.5 34 C5 10 52 D5 15 78 A6 24 72 B6 40 120 C6 70 140 D6 90 270 A7 40 105 B7 65 170 C7 100 260 D7 150 390 Copyright© 2019 Orient .All rights Reserved Condition Unit IF=5mA, VCE=5V, Ta=25℃ % Condition Unit IF=0.1mA, VCE=5V, Ta=25℃ IF=0.5mA, VCE=5V, Ta=25℃ % IF=1mA, VCE=5V, Ta=25℃ 5 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 8. Order Information Part Number ORPC-817XT-V-W-Y-Z-(GK) Note X = Lead form option (S, M or none) T = CTR Rank (L, A, B, C, D, A5, B5, C5...) V = Tape and reel option (TP,TP1 or none). W = Lead frame (F:Iron , C:copper) Y = ‘V’ code for VDE safety (This options is not necessary). Z = ‘G’ code for Halogen free (Copper for HF only). GK = Field Code. * VDE Code can be selected. Option Description Packing quantity None Standard DIP-4 100 units per tube M Wide lead bend (0.4 inch spacing) 100 units per tube S(TP) Surface mount lead form (low profile) + TP tape & reel option 2000 units per reel S(TP1) Surface mount lead form (low profile) + TP1 tape & reel option 2000 units per reel Copyright© 2019 Orient .All rights Reserved 6 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 9. Naming Rule (1) ORIENT PHOTOCOUPLER. (2) 817 denotes Device Part Number. (3) denotes Rank Code.(Number not mark, L,A,B,C or D only ) (4) denotes Lead Frame Code. (5) denotes Year Code. (6) denotes Week Code. (7) denotes Day Code. (8) denotes VDE Code. (Optional) (9) denotes HF Code. (Copper for HF only) (10) Anode. (11) Identification. * VDE Mark can be selected. Copyright© 2019 Orient .All rights Reserved 7 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 10. Package Dimension (Unit:mm) (1) ORPC-817 (2) ORPC-817M Copyright© 2019 Orient .All rights Reserved 8 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) (3) ORPC-817S 11. Taping Dimensions (1)ORPC-817S-TP Copyright© 2019 Orient .All rights Reserved 9 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) (2)ORPC-817S-TP1 Description Symbol Dimension in mm (inch) Tape wide W 16±0.3 (.63) Pitch of sprocket holes P0 4±0.1 (.15) Distance of compartment F P2 7.5±0.1 (.295) Distance of compartment to compartment P1 8±0.1 (.472) 2±0.1 (.0079) Package Type Quantities(pcs) 12. TP/TP1 2000 Recommended Foot Print Patterns (Mount Pad) (Unit:mm) Copyright© 2019 Orient .All rights Reserved 10 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 13. Package Dimension DIP Type Packing Information Packing type Tube Qty per Tube 100pcs Small box (Inner) Dimension 525*128*60mm Large box (Outer) Dimension 545*290*335mm The Amount per Inner Box 5,000pcs The Amount per Outer Box 50,000pcs SOP Type Packing Information Packing type Reel type Tape Width 16mm Qty per Reel 2,000pcs Small box (inner) Dimension 345*345*58.5mm Large box (Outer) Dimension 620x360x360mm Max qty per small box 4,000pcs Max qty per large box 40,000pcs (2)Packing Label Sample Note: 1. 2. Material Code :Product ID. P/N :Contents with "Order Information" in the specification. 3. Lot No. :Product data. 4. D/C :Product weeks. 5. Quantity :Packaging quantity. Copyright© 2019 Orient .All rights Reserved 11 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 14. Reliability Test NO. 1 ITEMS RSH 耐焊接热 Reliability Testing QTY. (Pcs) 22 Condition 260±5℃ Process 10s/3 次 Device Standard 锡炉 JESD22-A106 高温烤箱 测试仪 JESD22-A103 低温箱 测试仪 JESD22-A119 168 hrs 2 HTSL 高温存储 77 125℃ 500 hrs 1000 hrs 168 hrs 3 LTSL 低温存储 77 -55℃ 500 hrs 1000 hrs 4 5 TC 温度循环 TS 温度冲击 77 H:125℃ 15min ∫5min L:-55℃ 15min 300 cycle 冷热冲击机 JESD22-A104 77 H:100℃ 5min ∫15s L:-40℃ 5min 300 cycle 冷热冲击机 JESD22-A106 高温烤箱 测试仪、老 化电路板 JESD22-A108 ESD静电测 试仪 JESD22-A114 锡炉 JESD22-B102 高温烤箱 ,测试仪 JESD22-A103 恒温恒湿 机,测试仪 JESD22-A101 压力锅 JESD22-A102 168 hrs 6 7 8 9 10 11 HTOL 高温操作 ESD-HBM 人体模式 SD 可焊性 HTRB 高温反向偏压 H3TRB 温湿度反向偏 压,寿命试验 Autoclave 压力锅 110°C IF=10mA Vce=5V 500 hrs 22 ≥8KV 1Cycle 1次 22 Pb-free 245±5℃ 5S/1次 77 HTRB @125℃ Vce=80v 77 77 77 H3TRB 85℃,85%RH Vce=80v Ta=121 ℃,100%RH,2atm Copyright© 2019 Orient .All rights Reserved 1000 hrs 168 hrs 500 hrs 1000 hrs 168 hrs 500 hrs 1000 hrs 96hrs 12 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 15. Temperature Profile Of Soldering (1).IR Reflow soldering (JEDEC-STD-020C compliant) One time soldering reflow is recommended within the condition of temperature and time profile shown below. Do not solder more than three times. Profile item Conditions Preheat - Temperature Min (T Smin ) 150˚C - Temperature Max (T Smax ) 200˚C - Time (min to max) (ts) 90±30 sec Soldering zone - Temperature (TL ) 217˚C - Time (t L ) 60 sec Peak Temperature 260˚C Peak Temperature time 20 sec Ramp-up rate 3˚C / sec max. Ramp-down rate from peak temperature 3~6˚C / sec Reflow times ≤3 Copyright© 2019 Orient .All rights Reserved 13 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) (2).Wave soldering (JEDEC22A111 compliant) One time soldering is recommended within the condition of temperature. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 25 to 140˚C Preheat time 30 to 80 sec (3).Hand soldering by soldering iron Allow single lead soldering in every single process. One time soldering is recommended. Copyright© 2019 Orient .All rights Reserved Temperature 380+0/-5˚C Time 3 sec max 14 V2 Shenzhen Orient Components Co ., Ltd ORPC-817-(GK) 16. Characteristics Curves Copyright© 2019 Orient .All rights Reserved 15 V2 Shenzhen Orient Components Co ., Ltd Copyright© 2019 Orient .All rights Reserved 16 ORPC-817-(GK) V2
ORPC-817SC-TP-C-G-(GK) 价格&库存
很抱歉,暂时无法提供与“ORPC-817SC-TP-C-G-(GK)”相匹配的价格&库存,您可以联系我们找货
