TD817C1(SL)(T1)-FGV
TD817C1(SL)(T1)-FGV
    LIGHTNING(天电光电)
    SMD-4P
    光电耦合器 5KV SMD-4
TD817C1(SL)(T1)-FGV 数据手册
TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler SCHEMATIC Description The TD817 series combine an AlGaAs infrared emitting diode as the emitter which is optically coupled to a silicon planar phototransistor 1 4 2 3 detector in a plastic DIP4 package with different lead forming options. With the robust coplanar double mold structure, TD817 series provide the most stable isolation feature. Features  High isolation 5000 VRMS  CTR flexibility available see order information PIN DEFINITION 1. Anode 2. Cathode 3. Emitter 4. Collector PACKAGE OUTLINE  DC input with transistor output  Operating temperature range - 55 °C to 110 °C  REACH compliance  Halogen free  MSL class 1  Regulatory Approvals  UL - UL1577  VDE - EN60747-5-5(VDE0884-5)  CQC - GB4943.1, GB8898  cUL- CSA Component Acceptance Service Notice No. 5A Applications  Switch mode power supplies  Programmable controllers  Household appliances  Office equipment Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 1 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler ABSOLUTE MAXIMUM RATINGS PARAMETER SYMBOL VALUE UNIT NOTE INPUT Forward Current IF 60 mA Peak Forward Current IFP 1 A Reverse Voltage VR 6 V Input Power Dissipation PI 100 mW Collector - Emitter Voltage VCEO 35 V Emitter - Collector Voltage VECO 7 V Collector Current IC 50 mA Output Power Dissipation PO 150 mW Total Power Dissipation Ptot 200 mW Isolation Voltage Viso 5000 Vrms Operating Temperature Topr -55~110 °C Storage Temperature Tstg -55~125 °C Soldering Temperature Tsol 260 °C 1 OUTPUT COMMON 2 Note 1. 100μs pulse, 100Hz frequency Note 2. AC For 1 Minute, R.H. = 40 ~ 60% Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 2 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler ELECTRICAL OPTICAL CHARACTERISTICS at Ta=25°C PARAMETER SYMBOL MIN TYP. MAX. UNIT TEST CONDITION NOTE INPUT Forward Voltage VF - 1.2 1.4 V IF=10mA Reverse Current IR - - 10 μA VR=6V Input Capacitance Cin - 6 - pF V=0, f=1kHz OUTPUT Collector Dark Current ICEO - - 100 nA VCE=20V, IF=0 Collector-Emitter Breakdown Voltage BVCEO 35 - - V IC=0.1mA, IF=0 Emitter-Collector Breakdown Voltage BVECO 7 - - V IE=0.1mA, IF=0 TRANSFER CHARACTERISTICS Current Transfer Ratio TD817 50 - 600 TD817A 80 - 160 130 - 260 TD817C 200 - 400 TD817D 300 - 600 - 0.06 TD817B CTR % IF=5mA, VCE=5V 0.2 V IF=20mA, IC=1mA - Ω DC500V, 40 ~ 60% R.H. Collector-Emitter Saturation Voltage VCE(sat) Isolation Resistance RISO Floating Capacitance CIO - 0.5 1 pF V=0, f=1MHz Response Time (Rise) tr - 3 18 μs Response Time (Fall) tf - 4 18 μs VCE=2V, IC=2mA RL=100Ω Cut-off Frequency fc - 80 - kHz 10^12 10^14 VCE=2V, IC=2mA RL=100Ω,-3dB 3 3 4 Note 3. Fig.12&13 Note 4. Fig.14 Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 3 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler CHARACTERISTIC CURVES Fig.1 Forward Current vs. Ambient Temperature Fig.2 Collector Power Dissipation vs. Ambient Temperature Fig.3 Forward Current vs. Forward Voltage Fig.4 Collector Dark Current vs. Ambient Temperature Fig.5 Collector Current vs. Collector-emitter Voltage Fig.6 Collector Current vs. Collector-emitter Voltage Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 4 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler CHARACTERISTIC CURVES Fig.7 Normalized Current Transfer Ratio vs. Forward Current Fig.8 Normalized Current Transfer Ratio vs. Ambient Temperature Fig.9 Collector-emitter Saturation Voltage vs. Ambient Temperature Fig.10 Switching Time vs. Load Resistance Fig.11 Frequency Response Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 5 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler TEST CIRCUITS Fig.12 Test Circuits of Response Time Fig.13 Curves of Response Time Fig.14 Test Circuits of Frequency Response Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 6 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Standard DIP – Through Hole (DIP Type) Gullwing (400mil) Lead Forming – Through Hole (M Type) Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 7 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Surface Mount Lead Forming (S Type) Surface Mount (Low Profile) Lead Forming (SL Type) Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 8 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler PACKAGE DIMENSIONS (Dimensions in mm unless otherwise stated) Surface Mount (Gullwing) Lead Forming (SLM Type) RECOMMENDED SOLDER MASK (Dimensions in mm unless otherwise stated) Surface Mount Lead Forming & Surface Mount (Low Profile) Lead Forming Surface Mount (Gullwing) Lead Forming Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 9 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler TUBE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Standard DIP / M Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 10 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler BOX SPECIFICATIONS (Tube Type) Inner Box  L x W x H = 52.5cm x 10.7cm x 4.7cm Outer Box  L x W x H = 53.5cm x 23.5cm x 25.5cm Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 11 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option S(T1) & SL(T1) Option S(T2) & SL(T2) Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 12 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option S(T3) & SL(T3) Option S(T4) & SL(T4) Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 13 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler CARRIER TAPE SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option SLM(T1) Option SLM(T2) Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 14 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler REEL SPECIFICATIONS (Dimensions in mm unless otherwise stated) Option S & Option SL Option SLM Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 15 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler BOX SPECIFICATIONS (Reel Type) Inner Box  L x W x H = 36cm x 36cm x 6.9cm Outer Box  L x W x H = 45cm x 38cm x 38cm Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 16 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler ORDERING AND MARKING INFORMATION MARKING INFORMATION TD 817 X F V Y A WW ORDERING INFORMATION : Company Abbr. : Part Number : CTR Rank : Leadframe Option : VDE Option : Fiscal Year : Manufacturing Code : Work Week LABEL INFORMATION TD817X(Y)(Z)-FGV TD – Company Abbr. 817 – Part Number X – Rank (A/B/C/D or None) Y – Lead Form Option (M/S/SL/SLM/None) Z – Tape and Reel Option (T1/T2/T3/T4) F – Leadframe Option (F:Iron, None:Copper) G – Green V – VDE Option (V or None) Packing Quantity Option Quantity Quantity – Inner box Quantity – Outer box None 100 Units/Tube 32 Tubes/Inner box 10 Inner box/Outer box = 32k Units M 100 Units/Tube 32 Tubes/Inner box 10 Inner box/Outer box = 32k Units S(T1) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units S(T2) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units S(T3) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units S(T4) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units SL(T1) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units SL(T2) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units SL(T3) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units SL(T4) 1000 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 15k Units SLM(T1) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units SLM(T2) 1500 Units/Reel 3 Reels/Inner box 5 Inner box/Outer box = 22.5k Units Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 17 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler REFLOW INFORMATION REFLOW PROFILE Profile Feature Sn-Pb Assembly Profile Pb-Free Assembly Profile Temperature Min. (Tsmin) 100 150°C Temperature Max. (Tsmax) 150 200°C Time (ts) from (Tsmin to Tsmax) 60-120 seconds 60-120 seconds Ramp-up Rate (tL to tP) 3°C/second max. 3°C/second max. Liquidous Temperature (TL) 183°C 217°C Time (tL) Maintained Above (TL) 60 – 150 seconds 60 – 150 seconds Peak Body Package Temperature 235°C +0°C / -5°C 260°C +0°C / -5°C Time (tP) within 5°C of 260°C 20 seconds 30 seconds Ramp-down Rate (TP to TL) 6°C/second max 6°C/second max Time 25°C to Peak Temperature 6 minutes max. 8 minutes max. Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 18 TD817 Series www.tdled.com DIP4, DC Input, Photo Transistor Coupler DISCLAIMER  LIGHTNING is continually improving the quality, reliability, function and design. LIGHTNING reserves the right to make changes without further notices.  The characteristic curves shown in this datasheet are representing typical performance which are not guaranteed.  LIGHTNING makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product. To the maximum extent permitted by applicable law, LIGHTNING disclaims (a) any and all liability arising out of the application or use of any product, (b) any and all liability, including without limitation special, consequential or incidental damages, and (c) any and all implied warranties, including warranties of fitness for particular  The products shown in this publication are designed for the general use in electronic applications such as office automation, equipment, communications devices, audio/visual equipment, electrical application and instrumentation purpose, non-infringement and merchantability.  This product is not intended to be used for military, aircraft, automotive, medical, life sustaining or lifesaving applications or any other application which can result in human injury or death.  Please contact LIGHTNING sales agent for special application request.  Immerge unit’s body in solder paste is not recommended.  Parameters provided in datasheets may vary in different applications and performance may vary over time. All operating parameters, including typical parameters, must be validated in each customer application by the customer’s technical experts. Product specifications do not expand or otherwise modify LIGHTNING’s terms and conditions of purchase, including but not limited to the warranty expressed therein.  Discoloration might be occurred on the package surface after soldering, reflow or long-time use. It neither impacts the performance nor reliability. Document No:DWI-001 Rev: A00 Release Date: 2021/6/16 19
TD817C1(SL)(T1)-FGV 价格&库存
很抱歉,暂时无法提供与“TD817C1(SL)(T1)-FGV”相匹配的价格&库存,您可以联系我们找货
