GRF4005
GRF4005
    GUERRILLARF
    DFN6
    RF放大器 DFN-6 1.8V~5.5V 170mA
GRF4005 数据手册
Released GRF4005 Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz Product Description GRF4005 is a broadband low noise gain block designed for small cell, wireless infrastructure and other high performance applications. With simple external matching, it exhibits outstanding broadband NF, linearity and return losses over wide fractional bandwidths with a single match. Configured as a first stage LNA, linear driver or cascaded gain block, GRF4005 offers high levels of reuse both within a design and across platforms. The device is operated from a supply voltage (VDD) of 1.8 to 5.5 V. IDDQ can be adjusted over a wide range for optimal efficiency and linearity. Features Reference: 5V/170mA/2.5 GHz • EVB NF: 0.88 dB • Gain: 12.8 dB • OP1dB: 27.5 dBm • OIP3: 42.0 dBm • Flexible Bias Voltage and Current • Process: GaAs pHEMT Consult with the GRF applications engineering team for custom tuning/evaluation board data and device sparameters. Applications • Linear Driver Amplifier • Small Cells and Cellular Repeaters • Distributed Antenna Systems • First/Second Stage LNA Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 1 GRF4005 Released Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz Absolute Ratings: Parameter Supply Voltage RF Input Power: (Load VSWR < 2:1; VDD: 5.0 volts) Symbol Min. Max. Unit VDD 0 6.0 V 22 dBm 105 °C PIN MAX Operating Temperature (Package Heat Sink) TAMB -40 Maximum Channel Temperature (MTTF > 10^6 Hours) Maximum Dissipated Power TMAX 170 °C PDISS MAX 0.85 W Electrostatic Discharge: Charged Device Model: CDM 1500 V Human Body Model: HBM 500 V Storage Temperature TSTG -65 Moisture Sensitivity Level MSL Storage: 150 °C 1 -- Caution! ESD Sensitive Device Exceeding Absolute Maximum Rating conditions may cause permanent damage to the device. Note: For manufacturing information, see the Guerrilla-RF.com website for the following document located on the GRF4005 landing page: Manufacturing Note—MN-001 Product Tape and Reel, Solderability and Package Outline Specification: Link to manufacturing note Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 2 Released GRF4005 Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz Pin Out (Top View) Pin Assignments: Pin Name 1 VENABLE 2 NC 3 Description Note No Connect or Ground VENABLE and series resistor set IDDQ. VENABLE < =0.2 volts disables device. On -die pull-down resistor will turn the part off if this node is allowed to float. No internal connection to die RF_In LNA RF input An external DC blocking cap must be used. 4 RF_Out LNA RF output VDD must be applied through a choke to this pin 5 NC No Connect or Ground No internal connection to die 6 NC No Connect or Ground No internal connection to die PKG BASE GND Ground Provides DC and RF ground for LNA, as well as thermal heat sink. Recommend multiple 8 mil vias beneath the package for optimal RF and thermal performance. Refer to evaluation board top layer graphic on schematic page. Enable Voltage Input Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 3 GRF4005 Released Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz Nominal Operating Parameters: Parameter Symbol Specification Min. Typ. Max. Unit Test Frequency FTEST Gain S21 Evaluation Board Noise Figure NF 0.88 OIP3 42.0 dBm 27.5 dBm Output 3rd Order Intercept Output 1dB Compression Power OP1dB 11.8 26.0 2500 MHz 12.8 dB 1.05 dB Switching Rise Time TRISE 500 ns Switching Fall Time TFALL 500 ns Supply Current Leakage Current IDD 145 Condition VDD = 5.0 V, TA = 25°C Incudes Board Losses +2.0 dBm POUT per tone at 2 MHz Spacing (2499 and 2501 MHz) 170 195 mA Target IDDQ: 170 mA ILEAKAGE 4.5 20 uA VDD: 5.0V; VENABLE: 0.0V jc 87 ᵒC/W On standard Evaluation Board TCHANNEL 160 (See note) ᵒC VDD: 5.0 V; IDDQ: 170 mA; No RF; PDISS: 850 mW Thermal Data Thermal Resistance: (Infra-Red Scan) Channel Temperature @ +85 C Reference (Package heat sink) Note: MTTF >10^6 hours for TCHANNEL < =170 degrees C. Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 4 Released GRF4005 Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz GRF4005 Evaluation Board Measured Data (1.7 to 2.7 GHz Tune): Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 5 Released GRF4005 Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz GRF4005 Evaluation Board Measured Data (1.7 to 2.7 GHz Tune): Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 6 Released GRF4005 Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz GRF4005 Evaluation Board S-Pars and Stability Mu Factor: (1.7 — 2.7 GHz Tune) Note: Mu factor >= 1.0 implies unconditional stability. Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 7 Released GRF4005 Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz GRF4005 Application Schematic GRF400X Evaluation Board Assembly Diagram Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 8 GRF4005 Released Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz GRF4005 Standard Evaluation Board BOM: (1.7 to 2.7 GHz Tune) Component Type Manufacturer Family Value Package Size Substitution M1 Inductor Coilcraft HPA 3.3 nH 0402 ok M2 Capacitor Murata GJM 2.0 pF 0402 ok M3 Capacitor Murata GJM 1.5 pF 0402 ok M5 (See curves) Resistor: 5% Various — — 0402 ok M7 Capacitor Murata GRM 0.1 uF 0402 ok M8 Capacitor Murata GRM 27 pF 0402 ok M10 Inductor Coilcraft HPA 18.0 nH 0402 ok M11 Capacitor Murata GJM 1.0 pF 0402 ok M12 Capacitor Murata GJM 15 pF 0402 ok Evaluation Board: GRF400X_RevC Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 9 Released GRF4005 Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz 1.5 mm DFN-6 Suggested PCB Footprint (Top View) 1.5 mm DFN-6 Package Dimensions Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 10 Released GRF4005 Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz Tape and Reel Information: Guerrilla RF’s Tape and Reel specification complies with the Electronics Industries Association (EIA) standards for ‘Embossed Carrier Tape of Surface Mount Components for Automatic Handling”. Reference EIA-481. See the table on the following page for Tape and Reel specifications along with units per reel. Devices are loaded with pins down into the carrier pocket with protective cover tape, wound into a plastic reel. Each reel will be packaged in a cardboard box. There will be product labels on the reel, the protective ESD bag and the outside surface of the box. Tape and Reel Packaging with Reel Diameter Noted (D) Carrier Tape Width (W), Pitch (P), Feed Direction and Pin 1 Quadrant Information Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 11 GRF4005 Released Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz Tape and Reel Specification and Device Package Information Table Package Type Dimensions Leads (mm) Carrier Tape Weight Width (W) Pocket Pitch (P) (mg) (mm) Reel Diameter (D) (mm) Pin 1 Quadrant (inches) Units per Reel QFN 2.0 x 2.0 x 0.50 12 7 8 4 Q1 7 2500 QFN 3.0 x 3.0 x 0.85 16 24 12 8 Q1 7 1500 DFN 1.5 x 1.5 x 0.45 6 4 8 4 Q1 7 2500 DFN 2.0 x 2.0 x 0.75 8 12 8 4 Q1 7 2500 LFM 3.5 x 3.5 x 0.75 See note TBD 12 8 Q2 7 1500 LFM 4.0 x 4.0 x 0.75 See note TBD 12 8 Q2 7 1500 Note: Lead count may vary. Reference applicable product data sheet Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 12 Released Data Sheet Release Status: GRF4005 Broadband LNA/Linear Driver Tuning Range: 0.1—3.8 GHz Notes Advance S-parameter and NF data based on EM simulations for the fully packaged device using foundry supplied transistor s-parameters. Linearity estimates based on device size, bias condition and experience with related devices. Preliminary All data based on evaluation board measurements in the Guerrilla RF Applications Lab. Released All data based on device qualification data. Typically, this data is nearly identical to the data found in the preliminary version. Max and min values for key RF parameters are included. Information in this datasheet is specific to the Guerrilla RF, Inc. (“Guerrilla RF”) product identified. This datasheet, including the information contained in it, is provided by Guerrilla RF as a service to its customers and may be used for informational purposes only by the customer. Guerrilla RF assumes no responsibility for errors or omissions on this datasheet or the information contained herein. Information provided is believed to be accurate and reliable, however, no responsibility is assumed by Guerrilla RF for its use, nor for any infringement of patents, or other rights of third parties, resulting from its use. Guerrilla RF assumes no liability for any datasheet, datasheet information, materials, products, product information, or other information provided hereunder, including the sale, distribution, reproduction or use of Guerrilla RF products, information or materials. No license, whether express, implied, by estoppel, by implication or otherwise is granted by this datasheet for any intellectual property of Guerrilla RF, or any third party, including without limitation, patents, patent rights, copyrights, trademarks and trade secrets. All rights are reserved by Guerrilla RF. All information herein, products, product information, datasheets, and datasheet information are subject to change and availability without notice. Guerrilla RF reserves the right to change component circuitry, recommended application circuitry and specifications at any time without prior notice. Guerrilla RF may further change its datasheet, product information, documentation, products, services, specifications or product descriptions at any time, without notice. Guerrilla RF makes no commitment to update any materials or information and shall have no responsibility whatsoever for conflicts, incompatibilities, or other difficulties arising from any future changes. GUERRILLA RF INFORMATION, PRODUCTS, PRODUCT INFORMATION, DATASHEETS AND DATASHEET INFORMATION ARE PROVIDED “AS IS” AND WITHOUT WARRANTY OF ANY KIND, WHETHER EXPRESS, IMPLIED, STATUTORY, OR OTHERWISE, INCLUDING FITNESS FOR A PARTICULAR PURPOSE OR USE, MERCHANTABILITY, PERFORMANCE, QUALITY OR NON-INFRINGEMENT OF ANY INTELLECTUAL PROPERTY RIGHT; ALL SUCH WARRANTIES ARE HEREBY EXPRESSLY DISCLAIMED. GUERRILLA RF DOES NOT WARRANT THE ACCURACY OR COMPLETENESS OF THE INFORMATION, TEXT, GRAPHICS OR OTHER ITEMS CONTAINED WITHIN THESE MATERIALS. GUERRILLA RF SHALL NOT BE LIABLE FOR ANY DAMAGES, INCLUDING BUT NOT LIMITED TO ANY SPECIAL, INDIRECT, INCIDENTAL, STATUTORY, OR CONSEQUENTIAL DAMAGES, INCLUDING WITHOUT LIMITATION, LOST REVENUES OR LOST PROFITS THAT MAY RESULT FROM THE USE OF THE MATERIALS OR INFORMATION, WHETHER OR NOT THE RECIPIENT OF MATERIALS HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. Customers are solely responsible for their use of Guerrilla RF products in the Customer’s products and applications or in ways which deviate from Guerrilla RF’s published specifications, either intentionally or as a result of design defects, errors, or operation of products outside of published parameters or design specifications. Customers should include design and operating safeguards to minimize these and other risks. Guerrilla RF assumes no liability or responsibility for applications assistance, customer product design, or damage to any equipment resulting from the use of Guerrilla RF products outside of stated published specifications or parameters. Guerrilla RF Proprietary Information. Guerrilla RFTM and the composite logo of Guerrilla RFTM are trademarks of Guerrilla RF, Inc. ©2014 Guerrilla RF, Inc. All rights reserved. Revision Date: 10/01/19 Please contact Guerrilla RF at (+1) 336-510-7840 or sales@guerrilla-rf.com 13
GRF4005 价格&库存
很抱歉,暂时无法提供与“GRF4005”相匹配的价格&库存,您可以联系我们找货
