MT8382ET
MT8382ET
    MAGNTEK(麦歌恩)
    SOT-23
    锁存开关
MT8382ET 数据手册
MT838X Latch, High Voltage Hall-Effect Switch IC 1 Product Description The MT838X family is produced by BCD technology with both high performance and high reliability. The Hall IC internally includes an on-chip Hall voltage generator, a voltage regulator for operation with supply voltage of 3.8V to 60V, temperature compensation circuitry, smallsignal amplifier, Hall IC with dynamic offset cancellation system, Schmitt trigger and an open collector output. It also includes an clamp diode at output and reversed power supply protection enhances the robustness of Hall IC. The Hall IC designed to respond to alternating north and south poles. While the magnetic flux density(B) is larger than operating point (BOP), the output will be turned on (Low), the output is held until the magnetic flux density(B) is lower than releasing point (BRP), then turn off (High). 4 Applications The MT838X family provides a variety of packages to customers: SOT-23/SOT-89B/SOT-23 (Thin Outline) for surface mount and flat TO-92 for through-hole mount. All packages are RoHS compliant. ■ ■ ■ ■ ■ 2 Features ■ AEC-Q100 Automotive Qualified MT838XAT & MT838XET ■ BCD Technology ■ Latch Switch ■ 3.8~60V Operating Vcc Range ■ -40℃~150℃ Operating Temperature ■ Package Option: Flat TO-92 SOT-23 SOT-23 (Thin Outline) SOT-89B ■ Magnetic Sensitivity Option: MT8381 (BOP=50Gs, BRP=-50Gs) MT8282 (BOP=20Gs, BRP=-20Gs) ■ Internal 10K pull-up resistor ■ -20V Reversed Power Supply Protection ■ Output Limiting Current Protection ■ RoHS Compliant: (EU)2015/863 5. Pin Configuration and Functions 2 3 SOT-23 (Thin Outline) 1 2 3 SOT-89B 1 3 2 Flat TO-92 1 3 2 Description Power Internal Pull-up Resistor Ground 2 OUT 2 GND Vcc OUT 1 按钮 OUT 1 3 按钮 Vcc 3 按钮 GND TO-92 Top-View SOT-23, tape & reel (3000pcs/bag) SOT-23 (Thin Outline), tape & reel (3000pcs/bag) SOT-89B, tape & reel (1000pcs/bag) magntek.com.cn | Magnetic Tech Makes Magic Change SOT-89B Top-View SOT-23 Thin Outline Top-View 22 MT838XBT 1 3 3 MT838XET SOT-23 GND MT838XAT GND Vcc MT838XA Flat TO-92, bulk packaging (1000pcs/bag) Out 11 Description VCC SOT-23 Top-View 3 Product Overview of MT838X Part No. Automotive, Home appliances, Industrial Speed Detection Magnetic Encoder Brushless DC Motor Communication Figure.1 1 OUT 3 GND 2 Vcc 1 Pin Configuration & Functions Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC Table of Contents 1 Product Description………….……………...…….……...…………………………………….…….………1 2 Features……………………………….……..……………………………………………………………….…….1 3 Product Overview of MT838X ..…………………………………………………………………………1 4 Applications……………………………………………………………………………………………………….1 5 Pin Configuration and Functions…………………………………………………….………………….1 6 Definition of Switching Function……………………………………………………………………….3 7 Functional Description…...…………………………………………………………………………………..3 8 Feature Description……………………………………………………………………………………………3 9 Functional Block Diagram…………………………………………………………………………………..4 10 Electrical and Magnetic Characteristics………………………………………………………………4 10.1 Absolute Maximum Ratings……………………………………………………………………………….4 10.2 Electrical Specifications….………………………………………………………………………………..5 10.3 Magnetic Characteristics………………………………………………………………………….…………5 10.4 ESD Ratings………………………………………………………………………………………………………..5 10.5 Characteristic Performance………………………………………………………………….…………….6 10.6 Typical Output Waveform…………………………………………………………………………………..7 11 Package Material Information……………………………………………………………………………8 11.1 SOT-23 Package Information……………………………...………………………………………………8 11.2 SOT-23 (Thin Outline) Package Information……………………………...………………………9 11.2 SOT-89B Package Information……...…………………………………………………………………10 11.3 Flat TO-92 Package Information……………………………………………………………………….11 12 Copy Rights and Disclaimer……………………………………………………………………………..12 1 2 3 4 Originally Version 1.1 Version 1.2 Version 1.3 Version 5 1.4 Version 6 7 1.5 Version 1.6 Version Reversion History magntek.com.cn | Magnetic Tech Makes Magic Change Update MT8382 Series Remove Typical Application Circuit Update AEC-Q100 Automotive on MT831XAT Update RoHS compliant to (EU)2015/863 Update AEC-Q100 Logo Update Copy Rights and Disclaimer Update AEC-Q100 Automotive on MT831XET Update the marking spec of SOT-23 & SOT23 (Thin Outline) 2 Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC 6 Definition of Switching Function Figure.2 & Figure.3 shows the device functionality and hysteresis Vcc North Vcc BRP Figure.2 BOP South North Switching Function of Flat TO-92 & SOT-89B BOP Figure.3 South BRP Switching Function of SOT-23 & SOT-23 (Thin Outline) 7 Function Description BOP: Operating Point, Magnetic flux density applied on the branded side of the package which turns the output driver ON (VOUT=Low) BRP: Releasing Point, Magnetic flux density applied on the branded side of the package which turns the output driver OFF (VOUT=High) BHYST: Hysteresis Window, |BOP - BRP| Devices that have a lower magnetic threshold (VOUT=High) detect magnets at a farther distance. Higher thresholds (VOUT=Low) generally require a closer distance or larger magnet. 8 Feature Description S N N N N S S S SOT-23 Flat TO-92 SOT-89B Figure.4 Motion The MT838X device is sensitive to the magnetic field component that is perpendicular to the top of the package SOT-23 (Thin Outline) N S S S S N N N SOT-23 Flat TO-92 SOT-89B PCB PCB VOUT = Low VOUT= High SOT-23 (Thin Outline) Flux Direction Polarity magntek.com.cn | Magnetic Tech Makes Magic Change 3 Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC 9 Functional Block Diagram Reference Dynamic Offset Cancelation Regulator 10KΩ Vcc Limiting Current Protection Out ESD ESD Hall Plate ITA COMP Output Driver GND Figure.5 Functional Block Diagram 10 Electrical and Magnetic Characteristics 10.1 Absolute Maximum Ratings Absolute maximum ratings are limited values to be applied individually, and beyond which the serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to absolute maximum rating conditions for an extended period of time may affect device reliability. Symbol Parameters Min Max Units VCC Supply Voltage - 65 V VRCC Reverse Battery Voltage -20 - V VOUT Output Voltage - 65 V IOUT Continuous Output Current - 40 mA TA Operating Ambient Temperature -40 150 ℃ TS Storage Temperature -50 150 ℃ TJ Junction Temperature - 165 ℃ B Magnetic Flux Density magntek.com.cn | Magnetic Tech Makes Magic Change No Limit 4 Gs Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC 10.2 Electrical Specifications At TA=-40~150 ℃, VCC=3.8V~60V (unless otherwise specified) Symbol Parameters Test Condition Min Typ Max Unit VCC Supply Voltage Operating 3.8 - 60 V ICC Supply Current BBOP, VOUT=Vcc - 50 - mA VDSON Output Saturation Voltage IOUT=15mA, B>BOP - - 0.4 V IOFF Output Leakage Current VOUT=60V - - 10 uA TR Output Rise Time RL=1KOhm, CL=20pF - - 1.0 us TF Output Fall Time RL=1KOhm, CL=20pF - - 1.0 us TPO Power on Time dVcc/dt>5V/uS B>BOP(MAX) - - 10 us FC Chopping Frequency - 800 - KHz FS Sampling Frequency - 200 - KHz RPU Internal pull-up Resistor RTH 10 KOhm Thermal Resistance of SOT-23 - 301 - ℃/W Thermal Resistance of SOT-23 (Thin Outline) - 301 - ℃/W Thermal Resistance of Flat TO-92 - 230 - ℃/W Thermal Resistance of SOT-89B - 230 - ℃/W 10.3 Magnetic Characteristics At VCC=3.8V~60V (unless otherwise specified) Part No. MT8381 Series MT8382 Series Symbol Min Typ Max Unit BOP, TA =25℃ 35 50 65 Gs BRP, TA =25℃ -65 -50 -35 Gs BHYST, TA =25℃ 70 100 130 Gs BOP, TA =25℃ 10 20 30 Gs BRP, TA =25℃ -30 -20 -10 Gs BHYST, TA =25℃ 20 40 60 Gs 10.4 ESD Ratings Symbol VESD Reference Values Unit Human-body model (HBM) AEC-Q100-002 Class II Grade Charged-device model (CDM) AEC-Q100-011 Class C6 Grade magntek.com.cn | Magnetic Tech Makes Magic Change 5 Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC 10.5 Characteristic Performance At VCC=5V Supply Current (mA) 6 5 4 3 2 1 0 -40 25 85 125 150 Temperature ℃ Figure.6 Supply Current vs. Temperature MT8381 MT8382 30 45 30 15 Bop 0 -15 -40 Brp 25 85 125 150 -30 -45 Magnetic Field Intensity (Gs) Magnetic Field Intensity (Gs) 60 15 Bop 0 -40 Brp 25 85 125 150 -15 -60 -75 Figure.7 -30 Temperature ℃ Magnetic Characteristics vs. Temperature (BOP & BRP) MT8381 MT8382 80 Magnetic Field Intensity (Gs) Magnetic Field Intensity (Gs) 120 100 80 60 40 20 0 70 60 50 40 30 20 10 0 -40 25 85 125 150 -40 Temperature ℃ Figure.8 Temperature ℃ 25 85 125 150 Temperature ℃ Magnetic Characteristics vs. Temperature (BHYST) magntek.com.cn | Magnetic Tech Makes Magic Change 6 Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC 10.6 Typical Output Waveform MT8381A as example B BOP T BRP V High Low Figure.9 T Digital Output vs. Magnetic Flux Density magntek.com.cn | Magnetic Tech Makes Magic Change 7 Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC 11 Package Material Information (For Reference Only – Not for Tooling Use) 11.1 SOT-23 Package Information 3 XXXX 按钮 Product ID 按钮 2 1 OUT Vcc Figure.10 DateCode: Y: Year W: Week YW GND XXXX YW SOT-23 Chip Marking Spec Sensing Center Figure.11 SOT-23 Package Drawing Symbol Dimensions in Millimeters Dimensions in Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950 TYP 0.037 TYP e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0︒ 8︒ 0︒ 8︒ x 1.460 TYP 0.057 TYP y 0.800 TYP 0.032 TYP z 0.600 TYP 0.024 TYP magntek.com.cn | Magnetic Tech Makes Magic Change 8 Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC 11.2 SOT-23 (Thin Outline) Package Information GND XXXX YW 3 Product ID 22 11 OUT Vcc Figure.12 YW 3 XXXX 按钮 DateCode: Y: Year W: Week SOT-23 (Thin Outline) Chip Marking Spec Sensing Center Figure.13 SOT-23 (Thin Outline) Package Drawing Symbol Dimensions in Millimeters Dimensions in Inches Min Max Min Max A 0.900 1.150 0.035 0.045 A1 0.000 0.100 0.000 0.004 A2 0.900 1.050 0.035 0.041 b 0.300 0.500 0.012 0.020 c 0.080 0.150 0.003 0.006 D 2.800 3.000 0.110 0.118 E 1.200 1.400 0.047 0.055 E1 2.250 2.550 0.089 0.100 e e1 0.950 TYP 1.800 L 0.037 TYP 2.000 0.071 0.550 REF 0.079 0.022 REF L1 0.300 0.500 0.012 0.020 θ 0︒ 8︒ 0︒ 8︒ x 1.460 TYP 0.057 TYP y 0.650 TYP 0.026 TYP z 0.500 TYP 0.020 TYP magntek.com.cn | Magnetic Tech Makes Magic Change 9 Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC 11.3 SOT-89B Package Information XXXX XXXX YWW Product ID 3 2 1 按钮 YWW OUT GND Vcc DateCode: week (01~55) DateCode: year (0~9) Figure.14 SOT-89B Chip Marking Spec Sensing Center Figure.15 SOT-89B Package Drawing Symbol Dimensions in Millimeters Dimensions in Inches Min Max Min Max A2 1.220 1.420 0.048 0.056 A1 0.000 0.100 0.000 0.004 b 0.300 0.500 0.012 0.020 c 0.052 0.252 0.002 0.010 D 4.400 4.600 0.173 0.181 b1 1.600 1.800 0.063 0.071 E 2.400 2.600 0.094 0.102 HE 4.000 4.400 0.157 0.173 e 1.400 1.600 0.055 0.063 L 0.350 0.550 0.014 0.022 x 2.250 TYP 0.089 TYP y 1.250 TYP 0.049 TYP z 0.300 TYP 0.012 TYP magntek.com.cn | Magnetic Tech Makes Magic Change 10 Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC 11.4 Flat TO-92 Package Information XXXX XXXX YWW Product ID YWW DateCode: week (01~55) DateCode: year (0~9) 3 OUT 2 GND 1 Vcc Figure.16 Flat TO-92 Chip Marking Spec Sensing Center Figure.17 Flat TO-92 Package Drawing Symbol Dimensions in Millimeters Dimensions in Inches Min Max Min Max A 1.420 1.620 0.056 0.064 A1 0.660 0.860 0.026 0.034 b 0.350 0.480 0.013 0.019 b1 0.400 0.510 0.016 0.020 c 0.330 0.510 0.013 0.020 D 3.900 4.100 0.154 0.161 D1 2.280 2.680 0.090 0.106 E 3.050 3.250 0.120 0.128 e 1.270 TYP 0.050 TYP e1 2.440 2.640 0.096 0.104 L 14.350 14.750 0.565 0.581 θ 45︒ TYP 45︒ TYP x 2.025 TYP 0.080 TYP y 1.545 TYP 0.061 TYP z 0.500 TYP 0.020 TYP magntek.com.cn | Magnetic Tech Makes Magic Change 11 Rev 1.6 MT838X Latch, High Voltage Hall-Effect Switch IC 12 Copy Rights and Disclaimer 1. This document may not be reproduced or duplicated, in any form, in whole or in part without prior written consent of MagnTek . Copyrights © 2019, MagnTek Incorporated. 2. MagnTek reserves the right to make changes to the information published in this document at anytime without notice. 3. MagnTek’s products are limited for use in normal commercial applications. MagnTek’s products are not to be used in any device or system, including but not limited to medical life support equipment and system. For the latest version of this document, please visit our website: www.magntek.com.cn magntek.com.cn | Magnetic Tech Makes Magic Change 12 Rev 1.6
