MT6111AT
MT6111AT
    MAGNTEK(麦歌恩)
    SOT-23
    Hall,全极开关,磁阻一维感应开关,磁阻开关
MT6111AT 数据手册
MT611X Omni-polar, Low Power AMR Switch IC 1 Product Description The MT611X family is produced with monolithic technology. Which built AMR sensor & ASIC on one chip. The IC internally includes a Wheatstone bridge with magnetic film, a voltage regulator for operating with supply voltage from 1.8V to 5.5V, a sleep/awake logic for low power consumption requirement, small signal amplifier and Schmitt trigger comparator with dynamic offset cancellation, and an output driver with open-drain output. When combined with a magnet, it becomes a noncontact switch with low power consumption, high sensitivity and high reliability. A horizontal magnetic field parallel to the electrode of the package can be detected by an arbitrary polarity. 4 Application The MT611X family provides a variety of packages to customers: SOT-23 for surface mount and flat TO-92 for through-hole mount. All packages are RoHS compliant. ■ ■ ■ ■ ■ ■ ■ 2 Features ■ ■ ■ ■ ■ ■ ■ ■ ■ 5. Pin Configuration and Functions VCC Out GND SOT-23 1 2 3 Flat TO-92 1 3 2 Description Power Output Ground Open-Drain SOT-23 Top-View GND ■ Monolithic Technology AMR (Anisotropic Magneto Resistance) Omni-polar Switch 1.8~5.5V Operating Vcc Range -40℃~125℃ Operating Temperature Package Option: SOT-23 Flat TO-92 Magnetic Sensitivity Option: BOP=±18Gs, BRP=±13Gs Open-Drain Output Low Power Consumption: Average Supply Current =1.3uA (Typ) RoHS Compliant: (EU)2015/863 Home appliances, Industrial Position Detection Proximity Switch Smart Meter Speed Detection Handheld Device Consumer Device 3 按钮 3 Product Overview of MT611X Flat TO-92, bulk packaging (1000pcs/bag) MT6111AT SOT-23, tape & reel (3000pcs/bag) TO-92 Top-View Figure.1 magntek.com.cn | Magnetic Tech Makes Magic Change OUT MT6111A Vcc Description 2 1 Part No. 1 OUT 3 GND 2 Vcc 1 Pin Configuration & Functions Rev 1.2 MT611X Omni-polar, Low Power AMR Switch IC Table of Contents 1 Production Description………….……………….……...…………………………………….…….………1 2 Features……………………………….……..……………………………………………………………….…….1 3 Product Overview of MT611X ..…………………………………………………………………………1 4 Applications……………………………………………………………………………………………………….1 5 Pin Configuration and Functions…………………………………………………….………………….1 6 Definition of Switching Function……………………………………………………………………….3 7 Function Description…......…………………………………………………………………………………..3 8 Feature Description……………………………………………………………………………………………3 9 Functional Block Diagram…………………………………………………………………………………..4 10 Electrical and Magnetic Characteristics………………………………………………………………4 10.1 Absolute Maximum Ratings……………………………………………………………………………….4 10.2 Electrical Specifications………………………………….………………………………………………..5 10.3 Magnetic Characteristics……………………………………………………………………………………5 10.4 ESD Ratings………………………………………………………………………………………………………..5 10.5 Characteristic Performance………………………………………………………………….…………….6 10.6 Typical Output Waveform…………………………………………………………………………………..7 11 Typical Application Circuit………………………………………………………………………………….7 12 Power on Output Waveform………………………………………………………………………………8 13 Package Material Information……………………………………………………………………………9 13.1 SOT-23 Package Information……………………………...………………………………………………9 13.2 Flat TO-92 Package Information……………..………………………………………………………10 14 1 2 3 Copy Rights and Disclaimer……………………………………………………………………………..11 Originally Version 1.1 Version 1.2 Version Reversion History Update TPO from 100us to 50us Update the marking spec of SOT-23 magntek.com.cn | Magnetic Tech Makes Magic Change 2 Rev 1.2 MT611X Omni-polar, Low Power AMR Switch IC 6 Definition of Switching Function Figure.2 shows the device functionality and hysteresis Vcc North Figure.2 BOP N BRP N BRP S South BOP S Omni-polar Switching Function 7 Function Description BOP: Operating Point, Magnetic flux density applied on the branded side of the package which turns the output driver ON (VOUT=Low) BRP: Releasing Point, Magnetic flux density applied on the branded side of the package which turns the output driver OFF (VOUT=High) BHYST: Hysteresis Window, |BOP - BRP| 8 Feature Description The MT611X device is sensitive to the magnetic field that is parallel to the package Motion Flat TO-92 SOT-23 25° GND S or N 25° 3 按钮 S or N N or S 25° N or S 1 2 Vcc OUT 25° Top View magntek.com.cn | Magnetic Tech Makes Magic Change 3 3 OUT Flux Direction Polarity 2 GND 1 Vcc Figure.3 Rev 1.2 MT611X Omni-polar, Low Power AMR Switch IC 9 Functional Block Diagram Vcc Sleep/Awake Logic Regulator Dynamic Offset Cancellation Out ESD AMR AMP COMP Output Driver GND Figure.4 Functional Block Diagram 10 Electrical and Magnetic Characteristics 10.1 Absolute Maximum Ratings Absolute maximum ratings are limited values to be applied individually, and beyond which the serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to absolute maximum rating conditions for an extended period of time may affect device reliability. Symbol Parameters Min Max Units VCC Supply Voltage - 7 V VRCC Reverse Battery Voltage -0.5 - V VOUT Output Voltage -0.5 7 V IOUT Continuous Output Current - 40 mA TA Operating Ambient Temperature -40 125 ℃ TS Storage Temperature -50 150 ℃ TJ Junction Temperature - 165 ℃ B Magnetic Flux Density magntek.com.cn | Magnetic Tech Makes Magic Change 3000 4 Gs Rev 1.2 MT611X Omni-polar, Low Power AMR Switch IC 10.2 Electrical Specifications At TA=-40~125℃, VCC=1.8V~5.5V (unless otherwise specified) Symbol Parameters Test Condition Min Typ Max Unit VCC Supply Voltage Operating 1.8 - 5.5 V ICC Supply Current VCC=3.6V - 1.3 2.0 uA VDSON Output Saturation Voltage VCC>=1.8V, IOUT=15mA, ∣B∣>∣BOP∣ VCC>=3.3V, IOUT=30mA, ∣B∣>∣BOP∣ - - 0.4 V IOFF Output Leakage Current VOUT=5.5V, ∣B∣3.6V/us, B>BOP(MAX) - - 50 us FSW Switching Frequency VCC=3.6V - 20 - Hz TAW Awake Time VCC=3.6V - 12 - Us TSL Sleep Time VCC=3.6V - 50 - ms D.C. Duty Cycle VCC=3.6V - 0.02 - % Thermal Resistance of SOT-23 - 301 - ℃/W Thermal Resistance of Flat TO-92 - 230 - ℃/W RTH 10.3 Magnetic Characteristics At VCC=1.8V~5.5V (unless otherwise specified) Part No. Symbol MT6111 Series Min Typ Max Unit BOP, TA =25℃ - ±18 ±25 Gs BRP, TA =25℃ ±3 ±13 - Gs - 5 - Gs BHYST, TA =25℃ 10.4 ESD Ratings Symbol VESD Reference Values Unit Human-body model (HBM) AEC-Q100-002 ±8000 V Charged-device model (CDM) AEC-Q100-011 ±1000 V magntek.com.cn | Magnetic Tech Makes Magic Change 5 Rev 1.2 MT611X Omni-polar, Low Power AMR Switch IC 10.5 Characteristic Performance Supply Current (uA) At VCC=3.6V, B∣BOP∣ ∣B∣
MT6111AT 价格&库存
很抱歉,暂时无法提供与“MT6111AT”相匹配的价格&库存,您可以联系我们找货
MT6111AT
  • 5+1.03767
  • 50+1.01326
  • 150+0.99695
库存:207
