MT851X
Uni-polar, Hall-Effect Switch IC
1 Product Description
The MT851X family is produced by BCD technology
with both high performance and high reliability. The
Hall IC internally includes an on-chip Hall voltage
generator, a voltage regulator for operation with
supply voltage of 3.0V to 24V, temperature
compensation circuitry, small-signal amplifier, Hall IC
with dynamic offset cancellation system, Schmitt
trigger and an open collector output. It also includes
an clamp diode at output and reversed power supply
protection enhances the robustness of Hall IC.
The Hall IC designed to respond to a single poles.
While the magnetic flux density(B) is larger than
operating point (BOP), the output will be turned on
(Low), the output is held until the magnetic flux
density(B) is lower than releasing point (BRP), then
turn off (High).
The MT851X family provides a variety of packages to
customers: SOT-23/SOT-23 (Thin Outline) for surface
mount and flat TO-92 for through-hole mount. All
packages are RoHS compliant.
4 Applications
Automotive, Home appliances, Industrial
Speed Detection
Position Detection
Magnetic Encoder
Solid-State Switch
Proximity Switch
5. Pin Configuration and Functions
2 Features
SOT-23
(Thin Outline)
1
2
3
Flat TO-92
1
3
2
Description
Power
Output
Ground
SOT-23
Thin Outline
Top-View
22
OUT
GND
3
3
11
Vcc
TO-92
Top-View
Figure.1
magntek.com.cn | Magnetic Tech Makes Magic Change
Open-Drain
按钮
MT851XET
SOT-23 (Thin Outline), tape & reel
(3000pcs/bag)
3
OUT
SOT-23, tape & reel
(3000pcs/bag)
2
22
MT851XAT
1
33
Flat TO-92, bulk packaging
(1000pcs/bag)
SOT-23
GND
MT851XA
GND
Vcc
Description
Out
SOT-23
Top-View
3 Product Overview of MT851X
Part No.
VCC
11
BCD Technology
Uni-polar Switch
3.0~24V Operating Vcc Range
-40℃~150℃ Operating Temperature
Package Option:
Flat TO-92
SOT-23
Magnetic Sensitivity Option:
MT8511 (BOP=28Gs, BRP=18Gs)
MT8512 (BOP=120Gs, BRP=90Gs)
Open-Drain Output
-16V Reversed Power Supply Protection
Output Limiting Current Protection
RoHS Compliant: (EU)2015/863
按钮
1
OUT
3
GND
2
Vcc
1
Pin Configuration & Functions
Rev
1.2
MT851X
Uni-polar, High Voltage Hall-Effect Switch IC
Table of Contents
1
Product Description………...…….……………….……...…………………………………….…….………1
2
Features……………………………….……..……………………………………………………………….…….1
3
Product Overview of MT851X ..…………………………………………………………………………1
4
Applications……………………………………………………………………………………………………….1
5
Pin Configuration and Functions…………………………………………………….………………….1
6
Definition of Switching Function……………………………………………………………………….3
7
Function Description……...…………………………………………………………………………………..3
8
Feature Description……………………………………………………………………………………………3
9
Functional Block Diagram…………………………………………………………………………………..4
10
Electrical and Magnetic Characteristics………………………………………………………………4
10.1 Absolute Maximum Ratings……………………………………………………………………………….4
10.2 Electrical Specifications……………………………………………………………………………………..5
10.3 Magnetic Characteristics……………………………………………………………………………………5
10.4 ESD Ratings………………………………………………………………………………………………………..5
10.5 Characteristic Performance………………………………………………………………….…………….6
10.6 Typical Output Waveform…………………………………………………………………………………..7
11
Typical Application Circuit………………………………………………………………………………….7
12
Package Material Information……………………………………………………………………………8
12.1 SOT-23 Package Information……………………………...………………………………………………8
12.2 SOT-23 (Thin Outline) Package Information……...……………………………………………….9
12.3 Flat TO-92 Package Information……………………………………………………………………….10
13
1
2
3
Copy Rights and Disclaimer………………………………………………………..…………………..11
Originally Version
1.1 Version
1.2 Version
Reversion History
Add MT8512 Series
Update the marking spec of SOT-23 & SOT-23 (Thin Outline)
2
Rev
1.2
MT851X
6 Definition of Switching Function
Figure.2 & Figure.3 shows the device functionality and hysteresis
Vcc
Vcc
North
Figure.2
BOP
South
BRP
North
Switching Function Uni-polar (North)
BOP
South
Switching Function Uni-polar (South)
Figure.3
SOT-23
BRP
SOT-23 (Thin Outline) / Flat TO-92
7 Function Description
BOP: Operating Point, Magnetic flux density applied on the branded side of the package which turns the
output driver ON (VOUT=Low)
BRP: Releasing Point, Magnetic flux density applied on the branded side of the package which turns the
output driver OFF (VOUT=High)
BHYST: Hysteresis Window, |BOP - BRP|
Devices that have a lower magnetic threshold (VOUT=High) detect magnets at a farther distance. Higher
thresholds (VOUT=Low) generally require a closer distance or larger magnet.
8 Feature Description
S
N
N
N
S
S
SOT-23
Flat TO-92
Figure.4
Motion
The MT851X device is sensitive to the magnetic field component that is perpendicular to the top of the
package
SOT-23
(Thin Outline)
S
N
N
N
S
S
SOT-23
Flat TO-92
PCB
PCB
VOUT = Low
VOUT= High
SOT-23
(Thin Outline)
Flux Direction Polarity
3
Rev
1.2
MT851X
9 Functional Block Diagram
Vcc
Reference
Dynamic
Offset
Cancelation
Regulator
Limiting
Current
Protection
ESD
Out
Hall Plate
ITA
COMP
Output Driver
ESD
GND
Figure.5
10 Electrical and Magnetic Characteristics
Absolute maximum ratings are limited values to be applied individually, and beyond which the
serviceability of the circuit may be impaired. Functional operability is not necessarily implied. Exposure to
absolute maximum rating conditions for an extended period of time may affect device reliability.
Symbol
Parameters
Min
Max
Units
VCC
Supply Voltage
30
V
VRCC
Reverse Battery Voltage
-16
V
VOUT
Output Voltage
30
V
IOUT
Continuous Output Current
55
mA
TA
Operating Ambient Temperature
-40
150
TS
Storage Temperature
-50
150
TJ
Junction Temperature
165
B
Magnetic Flux Density
No Limit
4
Gs
Rev
1.2
MT851X
At TA=-40~150 ℃, Vcc=3.0V~24V (unless otherwise specified)
Symbol
Parameters
Test Condition
Min
Typ
Max
Unit
VCC
Supply Voltage
Operating
3.0
24
V
ICC
Supply Current
BBOP,
VOUT=Vcc
50
mA
VDSON
Output Saturation Voltage
IOUT=20mA,
B>BOP
0.4
V
IOFF
Output Leakage Current
VOUT=24V,
B5V/uS
B>BOP (MAX)
15
us
FC
Chopping Frequency
400
KHz
FS
Sampling Frequency
25
KHz
Thermal Resistance of SOT-23
301
℃/W
Thermal Resistance of SOT-23 (Thin Outline)
301
℃/W
Thermal Resistance of TO-92
230
℃/W
RTH
At VCC=3.0V~24V (unless otherwise specified)
Part No.
MT8511 Series
MT8512 Series
Symbol
Min
Typ
Max
Unit
BOP, TA =25℃
18
28
38
Gs
BRP, TA =25℃
8
18
28
Gs
BHYST, TA =25℃
3
10
17
Gs
BOP, TA =25℃
90
120
150
Gs
BRP, TA =25℃
60
90
120
Gs
BHYST, TA =25℃
15
30
45
Gs
Level
Unit
10.4 ESD Ratings
Symbol
VESD
Reference
Human-body model (HBM)
AEC-Q100-002
Class H2
Grade
Charged-device model (CDM)
AEC-Q100-011
Class C3
Grade
5
Rev
1.2
MT851X
At VCC=5V
Supply Current (mA)
1.4
1.2
1
0.8
0.6
0.4
0.2
-20
55
85
125
150
Temperature ℃
Supply Current vs. Temperature
35
160
30
140
Magnetic Field Intensity (Gs)
Figure.6
25
Bop
10
Brp
5
MT8511
Figure.7
-20
55
85
125
80
60
Bop
40
Brp
-40
-20
MT8512
Temperature ℃
25
55
85
125
150
125
150
Temperature ℃
Magnetic Characteristics vs. Temperature (BOP & BRP)
16
14
12
10
8
6
4
2
100
45
40
35
30
25
10
-40
MT8511
Figure.8
120
-20
55
85
125
150
-40
MT8512
Temperature ℃
-20
55
85
Temperature ℃
Magnetic Characteristics vs. Temperature (BHYST)
6
Rev
1.2
MT851X
MT8511A as example
B
BOP
BRP
T
V
High
Low
Figure.9
T
Digital Output vs. Magnetic Flux Density
11 Typical Application Circuit
MT8511AT as example
Note: Recommended value for RL is 1KOhms to 10KOhms
C1=100nF
Vcc
1
RL
按钮
Vcc
OUT
3
GND
GND
2
Out
C2=1nF
Figure.10
7
Rev
1.2
MT851X
12 Package Material Information (For Reference Only – Not for Tooling Use)
3
XXXX
按钮
Product ID
按钮
2
1
OUT
Vcc
Figure.11
DateCode:
Y: Year W: Week
YW
GND
XXXX YW
SOT-23 Chip Marking Spec
Sensing
Center
Figure.12
SOT-23 Package Drawing
Symbol
Dimensions in Millimeters
Dimensions in Inches
Min
Max
Min
Max
A
1.300
0.0512
A1
0.000
0.150
0.0000
0.0059
A2
1.000
1.200
0.0394
0.0472
b
0.300
0.500
0.0118
0.0197
c
0.080
0.220
0.0031
0.0087
D
2.800
3.000
0.1102
0.1181
E
1.500
1.700
0.0591
0.0669
E1
2.600
3.000
0.1024
0.1181
e
0.870
1.030
0.0343
0.0406
e1
1.820
1.980
0.0717
0.0780
L
0.300
0.600
0.0118
0.0236
θ
0︒
8︒
0︒
8︒
x
1.450 TYP
0.057 TYP
y
0.800 TYP
0.032 TYP
z
0.600 TYP
0.024 TYP
8
Rev
1.2
MT851X
GND
XXXX YW
3
Product ID
22
11
OUT
Vcc
Figure.13
YW
3
XXXX
按钮
DateCode:
Y: Year W: Week
SOT-23 (Thin Outline) Chip Marking Spec
Sensing
Center
Figure.14
SOT-23 (Thin Outline) Package Drawing
Symbol
Min
Max
Min
Max
A
0.900
1.150
0.035
0.045
A1
0.000
0.100
0.000
0.004
A2
0.900
1.050
0.035
0.041
b
0.300
0.500
0.012
0.020
c
0.080
0.150
0.003
0.006
D
2.800
3.000
0.110
0.118
E
1.200
1.400
0.047
0.055
E1
2.250
2.550
0.089
0.100
e
e1
0.950 TYP
1.800
L
0.037 TYP
2.000
0.071
0.550 REF
0.079
0.022 REF
L1
0.300
0.500
0.012
0.020
θ
0︒
8︒
0︒
8︒
x
1.460 TYP
0.057 TYP
y
0.650 TYP
0.026 TYP
z
0.500 TYP
0.020 TYP
9
Rev
1.2
MT851X
XXXX
XXXX
YWW
Product ID
YWW
DateCode: week (01~55)
DateCode: year (0~9)
3 OUT
2 GND
1 Vcc
Figure.15
Flat TO-92 Chip Marking Spec
Sensing
Center
Figure.16
Flat TO-92 Package Drawing
Symbol
Min
Max
Min
Max
A
1.420
1.620
0.056
0.064
A1
0.660
0.860
0.026
0.034
b
0.350
0.480
0.013
0.019
b1
0.400
0.510
0.016
0.020
c
0.330
0.510
0.013
0.020
D
3.900
4.100
0.154
0.161
D1
2.280
2.680
0.090
0.106
E
3.050
3.250
0.120
0.128
e
1.270 TYP
0.050 TYP
e1
2.440
2.640
0.096
0.104
L
14.350
14.750
0.565
0.581
θ
45︒ TYP
45︒ TYP
x
2.025 TYP
0.080 TYP
y
1.545 TYP
0.061 TYP
z
0.500 TYP
0.020 TYP
10
Rev
1.2
MT851X
13 Copy Rights and Disclaimer
1. This document may not be reproduced or duplicated, in any form, in whole or in part without prior
written consent of MagnTek . Copyrights © 2019, MagnTek Incorporated.
2. MagnTek reserves the right to make changes to the information published in this document at
anytime without notice.
3. MagnTek’s products are limited for use in normal commercial applications. MagnTek’s products
are not to be used in any device or system, including but not limited to medical life support
equipment and system.
For the latest version of this document, please visit our website: www.magntek.com.cn
11
Rev
1.2
很抱歉,暂时无法提供与“MT8512AT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.49178
- 50+1.95912
- 150+1.73081
- 500+1.54872
- 3000+1.42182
- 6000+1.34579
