SC4003UA
SC4003UA
    SEMIMENT(赛卓)
    TO-92S-3
    线性霍尔效应传感器
SC4003UA 数据手册
Features Applications  3.5 to 10.5V wide supply voltage range  Angular position  4.5mA power consumption for 5 VDC  Position sensing  Output voltage proportional to magnetic  Over-current detection flux density  BLDC motor current monitoring  -40℃ to 150℃ wide ambient temperature range  Weigh and liquid level sensing  Fast power-on time  Resistant to mechanical stress  3-pin SIP and SOT89-3 package are available Description The SC400X family is high performance small versatile linear Hall-Effect devices which are operated by the magnetic field from a permanent magnet or an electromagnet. The ratio metric output voltage is set by Output State the supply voltage and varies in proportion to the strength of the magnetic. The quiescent output voltage of the SC4002 and SC4003 is 50% of the supply voltage, and the sensitivity is 3.125mV/Gs, 5.0mV/Gs and 2.5mV/Gs respectively. The SC400X family provides low-noise output with temperature compensation. The linear position sensor ICs have an operating temperature range of -40℃ to 150℃, appropriate for industrial environments. These devices are available in a 3-pin SIP and SOT89 packages. Both packages are lead (Pb) free, with 100% matte tin leadframe plating. Device Information Part Number Packing Mounting SC4002UA 1000 pieces/Bag SIP3 -40℃ to 150℃ 4002 SC4002BU 1000 pieces/Reel 3-pin SOT89 -40℃ to 150℃ 4002 SC4003UA 1000 pieces/Bag SIP3 -40℃ to 150℃ 4003 SC4005UA 1000 pieces/Bag SIP3 -40℃ to 150℃ 4005 -2- Ambient, TA Marking Terminal Configuration and Functions Terminal Type Description 1 PWR 3.5 to 10.5 V power supply GND 2 Ground Ground terminal OUT 3 Output Output terminal Name Number VCC -3- Absolute Maximum Ratings over operating free-air temperature range Parameter Symbol Min. Max. Units Power supply voltage VCC -0.5 30.0 V Output terminal voltage VOUT -0.3 30.0 V Supply current ICC -- 20 mA Output current IOUT -- 2 mA Operating ambient temperature TA -40 150 ℃ Operating junction temperature TJ -50 165 ℃ TSTG -65 175 ℃ Storage temperature Note: Stresses above those listed here may cause permanent damage to the device. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ESD Protection Human Body Model (HBM) tests according to: standard EIA/JESD22-A114-B HBM Parameter HBM ESD stress voltage Symbol Min. Max. Units VESD -4000 4000 V -4- Operating Characteristics over operating free-air temperature range (VCC=5V,unless otherwise noted) Parameter Symbol Test Conditions Min. Typ. Max. Units Supply voltage VCC TJ
SC4003UA 价格&库存
很抱歉,暂时无法提供与“SC4003UA”相匹配的价格&库存,您可以联系我们找货
