SSP6206
300mA Low Power LDO
Features
Low power consumption
Low Quiescent Current: 3.5uA at 6V
Low voltage drop
Output voltage accuracy: tolerance ±2%
Low temperature coefficient
Applications
Battery-powered equipment
Portable AV systems
Reference voltage sources
Mobile phones
Cameras,video cameras
Portable games
General Description
current limiter’s foldback circuit operates as a
consumption,
short circuit protection as well as the output
3
terminal,
positive
voltage
regulators manufactured using CMOS and laser
trimming technologies. The series provides large
voltage .
with a
significantly small dropout
current limiter for the output pin. Output voltages
are internally by laser trimming technologies. It is
selectable in 0.1V increments within a range of
PR
O
currents
IN
SSP6206 series are a highly precise, lower
1.2V to 5.0V. SSP6206 series are available in
The SSP6206 consists of a current limiter circuit,
SOT-23,SOT23-3 and SOT89 packages.
a driver transistor, a precision reference voltage
and an error correction circuit.
The series is
compatible with low ESR ceramic capacitors. The
SI
Typical Application
Ver1.5
1
Shanghai Siproin Microelectronics Co.
SSP6206
300mA Low Power LDO
Order Information
SSP6206-①②③④
Designator
① ②
③
④
Symbol
Description
Integer
Output Voltage(1.2V~5.0V)
N
Package:SOT23
M
Package:SOT23-3
P
Package:SOT89
R
RoHS / Pb Free
G
Halogen Free
PR
O
Block Diagram
IN
Note:”①②” stands for output voltages. Other voltages can be specially customized.
SI
Pin Assignment
Ver1.5
2
SSP6206
300mA Low Power LDO
Marking Rule
Product code
Product name
(2)
(3)
(4)
SSP6206-12YR
6
5
B
X
SSP6206-15YR
6
5
E
X
SSP6206-18YR
6
5
K
X
SSP6206-25YR
6
5
T
X
SSP6206-28YR
6
5
X
X
SSP6206-30YR
6
5
Z
X
SSP6206-33YR
6
6
2
X
SSP6206-36YR
6
SSP6206-50YR
6
IN
(1)
6
5
X
6
M
X
PR
O
Note: Y: Representative product packaging ,
Absolute Maximum Ratings
Parameter
Symbol
Ratings
Units
VIN
8
V
Output Current
IOUT
300*
mA
Output Voltage
VOUT
VSS-0.3~VIN+0.3
V
Topr
0.20
0.25
0.50
-40~+85
W
W
W
Tstg
-55~+125
SI
Input Voltage
SOT-23
Power Dissipation
SOT23-3
SOT89
Operating Temperature Range
Pd
Storage Temperature Range
*IOUT=Pd/(VIN-VOUT)
Ver1.5
3
SSP6206
300mA Low Power LDO
Electrical Characteristics
SSP6206 for any output voltage
Parameter
Symbol
Output Voltage
Vout
Output
(Ta=25℃)
Conditions
Vin=Vout+1V
1.0mA≤Iout≤30mA
Iout
Vin-Vout=1V
Low dropout*2
Vdrop
Line Regulation
△Vout1/(Vin·Vout)
Load Regulation
△Vout /ΔIout
1.6V≤Vin≤8V
Iout=40mA
Vin= Vout+1V
1.0mA≤Iout≤80mA
Iout=30mA
Supply Current
Input Voltage
PSRR
0℃≤Ta≤70℃
Vout×0.98
Vout×1.02
V
300
mA
0.2
%/V
0.05
12
30
mV
±100
Ppm/℃
Iss1
3.5
5
uA
Vin
6
8
V
50
dB
30
uVrms
PSRR
EN
F=1KHz
Vin=Vout+1V
BW=10Hz~100KHz
SI
Output Noise
Unit
PR
O
△Vout/(Ta·Vout)
Coefficiency
Max.
Refer to the next table
Output voltage
Temperature
Typ.
IN
Current*1
Min.
Electrical Characteristics by Output Voltage:
Dropout Voltage Vdif(V)
Output Voltage Vout(V)
Conditions
Vout≤1.5V
1.8 ≤ Vout ≤ 2
Iout=100 mA
2.8 ≤ Vout ≤ 5.0
Ver1.5
4
Typ.
Max.
0.35
0.57
0.28
0.42
0.19
0.35
SSP6206
300mA Low Power LDO
Package Information
SI
PR
O
IN
3-pin SOT23 Outline Dimensions
Ver1.5
5
SSP6206
300mA Low Power LDO
SI
PR
O
IN
3-pin SOT23-3 Outline Dimensions
Ver1.5
6
SSP6206
300mA Low Power LDO
SI
PR
O
IN
3-pin SOT89 Outline Dimensions
Ver1.5
7
很抱歉,暂时无法提供与“SSP6206-12PR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.51128
- 50+0.40241
- 150+0.34798
- 1000+0.30305
- 2000+0.27044
- 5000+0.25402
