SSP6206-33PR
SSP6206-33PR
    SIPROIN(矽朋)
    SOT-89-3
    3.3V 300MA 8V
SSP6206-33PR 数据手册
SSP6206 300mA Low Power LDO Features  Low power consumption  Low Quiescent Current: 3.5uA at 6V  Low voltage drop  Output voltage accuracy: tolerance ±2%  Low temperature coefficient Applications  Battery-powered equipment  Portable AV systems  Reference voltage sources  Mobile phones  Cameras,video cameras  Portable games General Description current limiter’s foldback circuit operates as a consumption, short circuit protection as well as the output 3 terminal, positive voltage regulators manufactured using CMOS and laser trimming technologies. The series provides large voltage . with a significantly small dropout current limiter for the output pin. Output voltages are internally by laser trimming technologies. It is selectable in 0.1V increments within a range of PR O currents IN SSP6206 series are a highly precise, lower 1.2V to 5.0V. SSP6206 series are available in The SSP6206 consists of a current limiter circuit, SOT-23,SOT23-3 and SOT89 packages. a driver transistor, a precision reference voltage and an error correction circuit. The series is compatible with low ESR ceramic capacitors. The SI Typical Application Ver1.5 1 Shanghai Siproin Microelectronics Co. SSP6206 300mA Low Power LDO Order Information SSP6206-①②③④ Designator ① ② ③ ④ Symbol Description Integer Output Voltage(1.2V~5.0V) N Package:SOT23 M Package:SOT23-3 P Package:SOT89 R RoHS / Pb Free G Halogen Free PR O Block Diagram IN Note:”①②” stands for output voltages. Other voltages can be specially customized. SI Pin Assignment Ver1.5 2 Shanghai Siproin Microelectronics Co. SSP6206 300mA Low Power LDO Marking Rule Product code Product name (2) (3) (4) SSP6206-12YR 6 5 B X SSP6206-15YR 6 5 E X SSP6206-18YR 6 5 K X SSP6206-25YR 6 5 T X SSP6206-28YR 6 5 X X SSP6206-30YR 6 5 Z X SSP6206-33YR 6 6 2 X SSP6206-36YR 6 SSP6206-50YR 6 IN (1) 6 5 X 6 M X PR O Note: Y: Representative product packaging , Absolute Maximum Ratings Parameter Symbol Ratings Units VIN 8 V Output Current IOUT 300* mA Output Voltage VOUT VSS-0.3~VIN+0.3 V Topr 0.20 0.25 0.50 -40~+85 W W W ℃ Tstg -55~+125 ℃ SI Input Voltage SOT-23 Power Dissipation SOT23-3 SOT89 Operating Temperature Range Pd Storage Temperature Range *IOUT=Pd/(VIN-VOUT) Ver1.5 3 Shanghai Siproin Microelectronics Co. SSP6206 300mA Low Power LDO Electrical Characteristics SSP6206 for any output voltage Parameter Symbol Output Voltage Vout Output (Ta=25℃) Conditions Vin=Vout+1V 1.0mA≤Iout≤30mA Iout Vin-Vout=1V Low dropout*2 Vdrop Line Regulation △Vout1/(Vin·Vout) Load Regulation △Vout /ΔIout 1.6V≤Vin≤8V Iout=40mA Vin= Vout+1V 1.0mA≤Iout≤80mA Iout=30mA Supply Current Input Voltage PSRR 0℃≤Ta≤70℃ Vout×0.98 -- Vout×1.02 V -- 300 -- mA 0.2 %/V -- 0.05 -- 12 30 mV -- ±100 -- Ppm/℃ Iss1 -- -- 3.5 5 uA Vin -- -- 6 8 V -- 50 -- dB -- 30 -- uVrms PSRR EN F=1KHz Vin=Vout+1V BW=10Hz~100KHz SI Output Noise Unit PR O △Vout/(Ta·Vout) Coefficiency Max. Refer to the next table Output voltage Temperature Typ. IN Current*1 Min. Electrical Characteristics by Output Voltage: Dropout Voltage Vdif(V) Output Voltage Vout(V) Conditions Vout≤1.5V 1.8 ≤ Vout ≤ 2 Iout=100 mA 2.8 ≤ Vout ≤ 5.0 Ver1.5 4 Typ. Max. 0.35 0.57 0.28 0.42 0.19 0.35 Shanghai Siproin Microelectronics Co. SSP6206 300mA Low Power LDO Package Information SI PR O IN 3-pin SOT23 Outline Dimensions Ver1.5 5 Shanghai Siproin Microelectronics Co. SSP6206 300mA Low Power LDO SI PR O IN 3-pin SOT23-3 Outline Dimensions Ver1.5 6 Shanghai Siproin Microelectronics Co. SSP6206 300mA Low Power LDO SI PR O IN 3-pin SOT89 Outline Dimensions Ver1.5 7 Shanghai Siproin Microelectronics Co.
