RS3003-3.3YE3L
RS3003-3.3YE3L
    RUNIC(润石)
    SOT89-3
RS3003-3.3YE3L 数据手册
RS3003 150mA, Low Power Consumption, High Voltage CMOS LDO Regulator DESCRIPTION FEATURES • Low Power Consumption • 150mA Nominal Output Current • Low Dropout Voltage • Low Temperature Coefficient • High Input Voltage (up to 36V) • Output Voltage Accuracy:±2.5% • Operating Temperature Range: -40°C to +85°C • Micro SIZE PACKAGES: SOT23-3 、 The RS3003 series is a set of low power high voltage regulators implemented in CMOS technology. It can operate from 6.3V to 36V. which can provide 150mA output current. The device allows input voltage as high as 36V. The RS3003 series is available in several fixed output voltages. CMOS technology ensures low dropout voltage and low quiescent current. The RS3003 is available in Green SOT23-3 and SOT89-3L packages. It operates over an ambient temperature range of -40°C to +85°C. SOT89-3L and SOT89-3L(L-Type) APPLICATIONS • Audio/Video Equipment • Communication Equipment • Battery-Powered Equipment • Laptop, Palmtops, Notebook Computers RevB.2 Function Block Diagram 1 www.run-ic.com RS3003 PIN CONFIGURATIONS VOUT SAXX GND 1 2 3 VIN SOT23-3 GND VIN SAXX SAXXL 1 2 3 1 2 3 VOUT GND VIN GND VIN VOUT SOT89-3L SOT89-3L(L-Type) NOTE: XX indicate Output Voltage For example: SA33 (V OUT=3.3V) PIN DESCRIPTION PIN NAME FUNCTION SOT23-3 SOT89-3L SOT89-3L (L-Type) GND 1 2 1 Ground. VIN 3 3 2 Regulator Input. Up to 36V input voltage. At least 1μF supply bypass capacitor is recommended. VOUT 2 1 3 Regulator Output. Recommended output capacitor range:1μF to 10μF. RevB.2 2 www.run-ic.com RS3003 ABSOLUTE MAXIMUM RATINGS (1) VIN to GND.........................................................-0.3 to 40V VOUT to GND......................... -0.3V to Min (VIN + 0.3V,7V) Power Dissipation, PD @ TA = 25°C SOT23-3 ……….……………………………………..... 0.31W SOT89-3L ……….………………………………………. 1.3W SOT89-3L(L-Type) ……….………………………….…. 0.6W Junction Temperature..............................................+150°C Operating Temperature Range ...................-40°C to +85°C Package Thermal Resistance @ TA = 25°C SOT23-3………………….……………………….… 320°C/W SOT89-3L……….…………......................................75°C/W SOT89-3L(L-Type) ……….……………………...… 165°C/W Storage Temperature Range.....................-65°C to +150°C Lead Temperature (Soldering, 10s) ……...…….........260°C ESD Susceptibility HBM ….......................................................................1000V MM ……………………….........………………...……….100V ESD SENSITIVITY CAUTION ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because very small parametric changes could cause the device not to meet its published specifications. (1) Stresses above these ratings may cause permanent damage. Exposure to absolute maximum conditions for extended periods may degrade device reliability. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those specified is not implied. PACKAGE/ORDERING INFORMATION PRODUCT RS3003-3.3 RS3003-5.0 ORDERING NUMBER VOUT(V) PACKAGE LEAD PACKAGE MARKING PACKAGE OPTION RS3003-3.3YF3 3.3 SOT23-3 SA33 XXXX Tape and Reel,3000 RS3003-3.3YE3 3.3 SOT89-3L SA33 XXXX Tape and Reel,1000 RS3003-3.3YE3L 3.3 SOT89-3L (L-Type) SA33L XXXX Tape and Reel,1000 RS3003-5.0YF3 5.0 SOT23-3 SA50 XXXX Tape and Reel,3000 RS3003-5.0YE3 5.0 SOT89-3L SA50 XXXX Tape and Reel,1000 RS3003-5.0YE3L 5.0 SOT89-3L (L-Type) SA50L XXXX Tape and Reel,1000 NOTE: XXXXX = Date Code and Vendor Code. 3 www.run-ic.com RS3003 ELECTRICAL CHARACTERISTICS (VIN = VOUT + 2V or 6.3V, whichever is greater, CIN = COUT = 1μF, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.) PARAMETER Input Voltage SYMBOL VIN Output Voltage Accuracy CONDITIONS TEMP MIN VOUT = 3.3V FULL 6.3 IOUT = 1mA +25°C -2.5 VIN = VOUT + 2V or 6.3V No load Ground Pin Current VIN = 36V +25°C IOUT = 50mA Maximum Output Current (1) Dropout Voltage (2) Line Regulation VDROP MAX UNITS 36 V 0 2.5 % 11 18 16 25 μA 11 VIN = VOUT + 2V or 6.3V, whichever is greater +25°C IOUT = 150mA +25°C 1300 1800 mV +25°C 0.005 0.012 %/V ΔVOUT VIN = VOUT + 2V or 6.3V to 36V, ΔVIN × VOUT IOUT = 1mA Load Regulation ΔVOUT VIN = VOUT +2V or 6.3V, IOUT = 1mA to150mA Power Supply Rejection Ratio PSRR VOUT = 3.3V, IOUT = 10mA Output Voltage Temperature Coefficient (3) TYP f = 217Hz f = 1KHz ΔVOUT IOUT = 1mA ΔTA × VOUT +25°C +25°C FULL 150 mA 10 65 63 70 25 mV dB ppm/°C NOTES: 1. Maximum output current is affected by the PCB layout, size of metal trace, the thermal conduction path between metal layers, ambient temperature and the other environment factors of system. Attention should be paid to the dropout voltage when VIN < VOUT + VDROP. 2. The dropout voltage is defined as VIN - VOUT, when VOUT is 100mV below the value of VOUT for VIN = VOUT (NOMINAL) + 2V or 6.3V, whichever is greater. 3. Output voltage temperature coefficient is defined as the worst-case voltage change divided by the total temperature range. 4 www.run-ic.com RS3003 TYPICAL CHARACTERISTICS VIN = VOUT (NOMINAL) + 2V or 6.3V, whichever is greater, VOUT = 3.3V, CIN = COUT = 1μF, TA = 25°C unless otherwise noted. Line-Transient Response Load-Transient Response IOUT=10mA to 100mA VIN=6.3V to 7.3V,IOUT=50mA 100mV/div VOUT 50mA/div 1V/div VOUT 100mV/div VIN IOUT Time(2ms/div) Time(1ms/div) Output Short Waveform Power-Up/Power-Down Output Waveform VOUT 2V/div 100mA/div 2V/div VIN 2V/div VOUT IOUT VIN=0 to 6.3V,IOUT=50mA Time(2ms/div) Time(2ms/div) Dropout Voltage vs. Temperature 600 Dropout Voltage vs. Output Current 1600 IOUT=50mA Dropout Voltage(mV) Dropout Voltage(mV) 550 500 450 400 350 300 1200 800 400 0 -50 -25 0 25 50 75 100 0 Temperature(℃) 5 25 50 75 100 Output Current(mA) 125 150 www.run-ic.com RS3003 APPLICATION NOTES Input Capacitor and Output Capacitor For proper operation, using a ceramic capacitor (CIN) between 1μF and 10μF between the input pin and ground. The input capacitor must be located a distance of not more than 0.5 inch from the input pin of the IC and returned to a clean analog ground. The capacitor with larger value and lower ESR (equivalent series resistance) provides better PSRR and linetransient response. The output capacitor must meet both requirements for minimum amount of capacitance and ESR in all LDOs application for stable operation, use a ceramic capacitor (COUT) between 1μF and 10μF. Larger values in this range will help improve load transient response and reduce noise. Output capacitors of other dielectric types may be used, but are not recommended as their capacitance can deviate greatly from their rated value over temperature. VIN VIN CIN 1μF VOUT RS3003 VOUT COUT 1μF GND Typical Application Circuit 6 www.run-ic.com RS3003 PACKAGE OUTLINE DIMENSIONS SOT23-3 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 L A1 Symbol c θ Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 7 www.run-ic.com RS3003 SOT89-3L D 2.0 A D1 3.0 E E1 0.7 45° b1 L e 1.5 b c 1.5 e1 1.0 RECOMMENDED LAND PATTERN (Unit: mm) Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.400 1.600 0.055 0.063 b 0.320 0.520 0.013 0.020 b1 0.400 0.580 0.016 0.023 c 0.350 0.440 0.014 0.017 D 4.400 4.600 0.173 0.181 D1 1.550 REF 0.061 REF E 2.300 2.600 0.091 0.102 E1 3.940 4.250 0.155 0.167 e 1.500 BSC 0.060 BSC e1 3.000 BSC 0.118 BSC L 0.900 1.200 8 0.035 0.047 www.run-ic.com
RS3003-3.3YE3L
物料型号:RS3003系列
器件简介:RS3003系列是一款采用CMOS技术实现的低压差线性稳压器,可提供高达150mA的输出电流,适用于6.3V至36V的输入电压范围。
引脚分配: - SOT23-3封装:1. VIN(输入电压),2. VOUT(输出电压),3. GND(地) - SOT89-3L封装:1. GND,2. VIN,3. VOUT - SOT89-3L(L-Type)封装:与SOT89-3L相同
参数特性: - 低功耗 - 低降压电压 - 高输入电压(高达36V) - 输出电压精度:±2.5% - 工作温度范围:-40°C至+85°C - 封装类型:SOT23-3、SOT89-3L和SOT89-3L(L-Type)
功能详解:RS3003系列具有低功耗、低降压电压和高精度输出电压等特点,适用于多种电子设备,包括音视频设备、通信设备、电池供电设备、笔记本电脑等。
应用信息:适用于音频/视频设备、通信设备、电池供电设备、笔记本电脑、掌上电脑、笔记本电脑等。
封装信息:RS3003系列提供多种固定输出电压版本,采用绿色SOT23-3和SOT89-3L封装,可在-40°C至+85°C的环境温度范围内工作。
RS3003-3.3YE3L 价格&库存
很抱歉,暂时无法提供与“RS3003-3.3YE3L”相匹配的价格&库存,您可以联系我们找货
