MST5633BTS
MST5633BTS
    MST(迈尔斯通)
    SOT-89-3
    3.3V 150MA 60V
MST5633BTS 数据手册
MST56XXB 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator Milestone Semiconductor Inc.  Description  Features The MST56XXB series is a high input voltage (60V),  Low Quiescent Current:2uA low quiescent current, High PSRR linear regulator  High Input Voltage Rating:Up to 80V (LDO) able to provide 150mA load current.  Output Current:150mA The LDO features very fast response against line  High PSRR:70dB at 1Khz voltage transient and load current transient, and  Dropout Voltage: ensures no overshoot voltage during the LDO start 70mV@10mA up and short circuit recovery. 700mV@100mA The device features integrated short-circuit and thermal shutdown protection.  Fixed Output Voltages: 3.0V, 3.3V, 3.6V and 5.0V The device is available with fixed output voltages  High-accuracy Output Voltage: ±2% of 3.0V, 3.3V, 3.6V and 5.0V, and available in  Good Transient Response SOT23 and SOT89 packages.  Integrated Short-Circuit Protection  Integrated Thermal Protection  Available Packages:  Application  Battery-powered equipment  Smoke detector and sensor  Micro controller Applications  Home Appliance  Application Circuits MST MST56XXBTE MST56XXBTE-A MST56XXBTE-B MST56XXBTE-C MST56XXBTS MST56XXBTS-A MST56XXBTS-B MST56XXBTS-C MST56XXBTG www.mst-ic.com SOT23-3 SOT89-3 SOT23-5 -1- MST56XXB Milestone Semiconductor Inc.  Packages And Pin Assignment 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator  Pin Descriptions MST56XXBTE 1 2 3 MST56XXBTS 1 3 2 MST SOT23-3 MST56XXBTE-A 2 1 3 SOT89-3 MST56XXBTS-A 3 1 2 MST56XXBTE-B 3 2 1 MST56XXBTS-B SOT23-5 MST56XXBTG 1 2 3 4 5 2 3 1 MST56XXBTE-C PIN NAME MST56XXBTS-C PIN DESCRIPTION NAME www.mst-ic.com 3 1 2 2 1 3 GND VOUT VIN GND VOUT VIN PIN NAME VIN GND NC NC VOUT DESCRIPTION Ground Pin Output Pin Input Pin Ground Pin Output Pin Input Pin DESCRIPTION Input Pin Ground Pin No Connection No Connection Output Pin -2- MST56XXB Milestone Semiconductor Inc.  Functional Block Diagram 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator  Absolute Maximum Ratings Item Voltage Current Temperature Thermal Resistance (Junction to Ambient) Power Dissipation Electrostatic discharge rating MST Description Min Max Unit VIN to GND -0.3 80 V VOUT to GND VOUT to VIN Peak output current Operating Ambient Temperature Storage Temperature Operating virtual junction Temperature SOT89 -0.3 -35 -40 -40 - SOT23 SOT89 SOT23 Human Body Model(HBM) Charged Device Model(MM) www.mst-ic.com 6 0.3 Internally limited 380 6 100 600 300 V 85 ℃ 150 ℃ 150 180 V ℃ ℃/W ℃/W mW mW kV V -3- MST56XXB Milestone Semiconductor Inc.  Electrical Characteristics 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator (At TA=25°C, CIN=1uF, VIN=VOUTNOM+1.0V, COUT=10uF, unless otherwise noted) Symbol VIN Parameter Input Voltage IGND Quiescent Current IOUT_MAX Output Current VOUT Output Voltage VDROP Dropout Voltage(1) ΔVOUT(ΔIOUT) Load Regulation ILIMIT Current Limit ΔVOUT(ΔVIN) TSHDN PSRR Line Regulation Test Conditions VIN=12V, No load VIN=12V, IOUT=10mA IOUT=10mA , VIN=VOUTNOM-0.1V IOUT=100mA , VIN=VOUTNOM-0.1V VIN=12V, 1mA≤IOUT≤100mA IOUT=1mA, VOUTNOM+0.5V≤VIN≤60V Shutdown, temperature increasing Thermal Shutdown Temperature Reset, temperature decreasing Vin=12V , Iout=10mA F=1Khz,Vout=3.3V MIN 5 — VOUTNOM * 0.98 — — — TYP MAX UNIT VOUTNOM VOUTNOM * 1.02 V 70 — — 2 150 700 — 0.02 — 250 — — — — 0.01 150 140 70 60 — V uA — mA — mV mV — %/mA — mA — — — — %/V ℃ dB Note:(1) Dropout Voltage is the voltage difference between the input and the output at which the output voltage drops 2% below its nominal value. MST www.mst-ic.com -4- MST56XXB Milestone Semiconductor Inc. 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator  Typical Performance Characteristics Test Condition: TA=25°C,Vin=12V, IOUT=1mA, COUT=10uF, unless otherwise noted Frequency(Hz) Input Voltage(V) MST www.mst-ic.com -5- MST56XXB 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator Milestone Semiconductor Inc. Line Transient Response Line Transient Response 3.3V VOUT 3.3V 24V VIN 24V 0V VOUT 0V 5V 5V VIN=5 to24V VOUT=3.3V 0V VIN VIN=24 to5V VOUT=3.3V 0V Time(10us/div) Time(4us/div) Load Transient Response Load Transient Response 90mA IOUT 90mA 0mA 0mA 180mV 0V VOUT 0V VIN 5V IOUT VOUT -220mV 5V VIN=5V VOUT=0V IOUT=0mA to90mA 0V VIN=5V VOUT=0V IOUT=90mA to 0mA 0V Time(20us /div) VIN Time(200us/div) Start Up Start Up 3.3V VOUT 100mA IOUT VOUT 3.3V 0mA 0V 24V VIN 0V 24V VIN VIN=24V VIN=24V VOUT=3.3V 0V Time(100us/div) Time(100us/div) Short Circuit Protection Short Circuit Protection 3.3V 3.3V 0V VOUT 0V 80mA IOUT 80mA 0mA VIN VIN=5V VOUT=3.3V to short IOUT 5V 0V Time(10ms/div) MST VOUT 0mA 5V 0V VIN=24V VOUT=3.3V VOUT=3.3V IOUT=100mA IOUT=100mA 0V VIN VIN=5V VOUT=short to3.3V Time(10ms/div) www.mst-ic.com -6- MST56XXB Milestone Semiconductor Inc.  Functional Description 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator Input Capacitor A 1μF ceramic capacitor is recommended to connect between VIN and GND pins to decouple input power supply glitch and noise. The amount of the capacitance may be increased without limit. This input capacitor must be located as close as possible to the device to assure input stability and less noise. For PCB layout, a wide copper trace is required for both VIN and GND. Output Capacitor An output capacitor is required for the stability of the LDO. The recommended minimum output capacitance is 1μF, ceramic capacitor is recommended, and temperature characteristics are X7R or X5R. Higher capacitance values help to improve load/line transient response. The output capacitance may be increased to keep low undershoot/overshoot. Place output capacitor as close as possible to VOUT and GND pins. Current Limit and Short Circuit Protection When output current at VOUT pin is higher than current limit threshold or the VOUT pin is direct short to GND, the current limit protection will be triggered and clamp the output current at a pre-designed level to prevent over-current and thermal damage. Thermal Protection The MST56XXB has internal thermal sense and protection circuits. When excessive power dissipation happens on the device, such as short circuit at the output pin or very heavy load current with a large voltage drop across the device, the internal thermal protection circuit will be triggered, and it will shut down the power MOSFET to prevent the LDO from damage. As soon as excessive thermal condition is removed and the temperature of the device drops down, the thermal protection circuit will lease the control of the power MOSFET, and the LDO device goes to normal operation. MST www.mst-ic.com -7- MST56XXB Milestone Semiconductor Inc. 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator  Ordering And Marking Information  Package Outline Dimensions SOT23-3 MST www.mst-ic.com -8- MST56XXB Milestone Semiconductor Inc. SOT89-3 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator SOT23-5 MST www.mst-ic.com -9- MST56XXB 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator Milestone Semiconductor Inc.  Packing Information W P D Type W(mm) P(mm) D(mm) Qty (pcs) SOT23-3 8.0±0.1 mm 4.0±0.1 mm 180±1 mm 3000pcs SOT23-5 8.0±0.1 mm 4.0±0.1 mm 180±1 mm 3000pcs SOT89-3 12.0±0.1 mm 4.0±0.1 mm 180±1 mm 1000pcs MST www.mst-ic.com - 10 - MST56XXB Milestone Semiconductor Inc. 60V/150mA/2uA IQ/Fast Transient High PSRR Linear Voltage Regulator IMPORTANT NOTICE MST INCORPORATED MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARDS TO THIS DOCUMENT, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION). MST Incorporated and its subsidiaries reserve the right to make modifications, enhancements, improvements, corrections or other changes without further notice to this document and any product described herein. MST Incorporated does not assume any liability arising out of the application or use of this document or any product described herein; neither does MST Incorporated convey any license under its patent or trademark rights, nor the rights of others. Any Customer or user of this document or products described herein in such applications shall assume all risks of such use and will agree to hold MST Incorporated and all the companies whose products are represented on MST Incorporated website, harmless against all damages. MST Incorporated does not warrant or accept any liability whatsoever in respect of any products purchased through unauthorized sales channel. Should Customers purchase or use MST Incorporated products for any unintended or unauthorized application, Customers shall indemnify and hold MST Incorporated and its representatives harmless against all claims, damages, expenses, and attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized application. Products described herein may be covered by one or more United States, international or foreign patents pending. Product names and markings noted herein may also be covered by one or more United States, international or foreign trademarks. MST www.mst-ic.com - 11 -
MST5633BTS 价格&库存
很抱歉,暂时无法提供与“MST5633BTS”相匹配的价格&库存,您可以联系我们找货
MST5633BTS
  • 5+1.66007
  • 50+1.30626
  • 150+1.15463
库存:312
