H70xxA-1
Low Power Voltage Detector
H70xxA-1
General Description
The H70XXA-1 series devices are a set of three
terminal low power voltage detectors implemented in
CMOS technology. Each voltage detector in the
series detects a particular fixed voltage ranging from
2.2V to 7.0V. The voltage detectors consist of a highprecision and low power consumption standard
voltage source as well as a comparator, hysteresis
circuit, and an output driver. CMOS technology
ensures low power consumption.
Although
designed
primarily
as
fixed
voltage
detectors, these devices can be used with external
components to detect user specified threshold
voltages .
Features
● Low power consumption
● Low temperature coefficient
● Built-in hysteresis characteristic
● High input voltage (up to 15V)
● Output voltage accuracy: tolerance ±1% or ±2%
● TO92, SOT89 ,SOT23 and SOT23-3 package
Applications
Battery checkers
Level selectors
Power failure detectors
Microcomputer reset
Battery memory backup
Non-volatile RAM signal storage protectors
上海矽朋微电子有限公司
V2.0
第 1 页 共 19 页
H70xxA-1
Order Information
Part No
Detectable
Voltage
Hysteresis Width
Tolerance
H7022A-1
H7024A-1
H7027A-1
H7030A-1
H7033A-1
H7036A-1
H7039A-1
H7040A-1
H7044A-1
H7050A-1
H7070A-1
2.2V
2.4V
2.7V
3.0V
3.3V
3.6V
3.9V
4.0V
4.4V
5.0V
7.0V
0.11V
0.12V
0.135V
0.15V
0.165V
0.18V
0.195V
0.2V
0.22V
0.25V
0.35V
±2%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
±2%
Package
TO92
SOT89
SOT23-3
SOT23
Manner of Packing
Devices per bag/reel
Bag
1000PCS/bag
Reel
1000PCS/reel
Reel
3000PCS/reel
Reel
3000PCS/reel
Note:H70①②A-1③④⑤
Designator
Symbol
①②
Integer
③
④
⑤
上海矽朋微电子有限公司
Description
Output Voltage(2.2~7.0V)
N
NMOS
C
CMOS
T
Package:TO-92
P
Package:SOT89
M
Package:SOT23-3
N
Package:SOT23
R
RoHS / Pb Free
G
Halogen Free
V2.0
第 2 页 共 19 页
H70xxA-1
Block Diagram and Pin Arrangement Diagram
Pin Assignment
Pin No.
Pin Name
1
VOUT
2
VIN
Supply Voltage Input.
3
GND
Ground connection.
上海矽朋微电子有限公司
Description
Output.
V2.0
第 3 页 共 19 页
H70xxA-1
Output Table & Curve
V DD
V OUT
V DD ≤V DET (-)
V SS
V DD >V DET (+)
Hi-Z
Functional Description
The H70XXA-1 series devices are a set of three terminal low power voltage detectors
implemented in CMOS technology. Each voltage detector in the series detects a
particular fixed voltage ranging from 2.2V to 7.0V.
Absolute Maximum Ratings
Parameter
Symbol
Value
Unit
VIN
-0.3~16
V
Operating Temperature
Tamb
-40~85
Storage Temperature
Tstg
-50~125
Note: These are stress ratings only. Stresses exceeding the range specified under “Absolute
Maximum Ratings” may cause substantial damage to the device. prolonged exposure to
extreme conditions may affect device reliability.
Thermal Information
Parameter
Thermal Resistance (Junction to
Ambient) (Assume no ambient
airflow, no heat sink)
Power Dissipation
上海矽朋微电子有限公司
Symbol
θ JA
PD
V2.0
Package
Max.
Unit
SOT23
500
℃/W
SOT89
200
℃/W
TO92
200
℃/W
SOT23
0.20
W
SOT89
0.50
W
TO92
0.50
W
第 4 页 共 19 页
H70xxA-1
Electrical Characteristics
H7022A-1XXX,Ta=25 ℃
Parameter
Symbol
Test Conditions
Min.
Typ.
Max.
Unit
2.156
2.200
2.244
V
0.02*
V DET
0.05*
V DET
0.10*
V DET
V
IDD
8V
No Load
2
3
μA
V DD
1.5
16
V
Output Sink
Current
I OL
2V
V OUT =0.2V
0.5
1
mA
Temperature
Coefficient
VDET
Ta
0℃
很抱歉,暂时无法提供与“H7044A-1NPR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.64001
- 50+0.50264
- 150+0.43395
- 1000+0.38243
- 2000+0.34118
- 5000+0.32055
