DTC143ZE
DTC143Z E
NPN Silicon Epitaxial Planar Digital Transistor
FEATURES
Built-in bias resistors enable the configuration of an inverter circuit
without connecting external input resistors(see equivalent circuit)
The bias resistors consist of thin-film resistors with complete isolation
to allow negative biasing of the input.They also have the advantage of
almost completely eliminating parasitic effects
Only the on/off conditions need to be set for operation, making device
design easy
PIN CONNENCTIONS and MARKING
ORDERING INFORMATION
Part Number
MARKING
Package
Packing Method
Pack Quantity
DTC143ZE
E23
SOT-523
Reel
3000pcs/Reel
DTC143ZUA
E23
SOT-323
Reel
3000pcs/Reel
DTC143ZKA
E23
SOT-23-3L
Reel
3000pcs/Reel
DTC143ZCA
E23
SOT-23
Reel
3000pcs/Reel
www.tw-gmc.com
1
DTC143ZE
MAXIMUM RATINGS(Ta=25℃ unless otherwise noted)
Symbol
VCC
Supply Voltage
VIN
Input Voltage
IO
Output Current
PD
Power Dissipation
TJ,Tstg
Limits(DTC143Z□)
Parameter
M
100
E
150
Operation Junction
and
Storage Temperature Range
UA
CA
KA
Unit
SA
50
V
-5~+30
V
100
mA
200
200
200
300
mW
-55~+150
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Input voltage
Output voltage
Input current
Symbol
Conditions
VI(off)
VCC=5V,IO=100µA
VI(on)
VO=0.3V ,IO=5mA
VO(on)
IO/II=5mA/0.25mA
II
Min
Typ
Max
0.5
V
1.3
V
0.3
V
VI=5V
1.8
mA
VCC=50V,VI=0
0.5
μA
kΩ
0.1
Output current
IO(off)
DC current gain
GI
Input resistance
R1
3.29
4.7
6.11
Resistance ratio
R2/R1
8
10
12
Transition frequency
www.tw-gmc.com
fT
Unit
VO=5V,IO=10mA
VO=10V ,IO=5mA,f=100MHz
2
80
250
MHz
DTC143ZE
I
Typical Characteristics
REVERSE VOLTAGE
www.tw-gmc.com
VR
(V)
AMBIENT TEMPERATURE
Ta
3
DTC143ZE
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
SOT-523
D
E
B
A
X
HE
v M A
3
Q
A
1
A1
2
e1
bp
c
w M B
Lp
e
detail X
1 mm
scale
DIMENSIONS (mm are the original dimensions)
www.tw-gmc.com
UNIT
A
A1
max
bp
c
D
E
e
e1
HE
Lp
Q
v
w
mm
0.95
0.60
0.1
0.30
0.15
0.25
0.10
1.8
1.4
0.9
0.7
1
0.5
1.75
1.45
0.45
0.15
0.23
0.13
0.2
0.2
4
很抱歉,暂时无法提供与“DTC143ZE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.36960
- 200+0.12320
- 1500+0.07689
- 3000+0.06105
- 国内价格
- 50+0.12675
- 500+0.10051
- 3000+0.08107
- 6000+0.07232
- 24000+0.06474
- 51000+0.06056
