DTA114YE-MS
DTA114YE-MS
    MSKSEMI(美森科)
    SOT-523-3
    50V 100MA
DTA114YE-MS 数据手册
www.msksemi.com DTA114YE-MS Semiconductor Compiance FEATURES:  Built-in resistors enable the configuration of a inverter circuit without connecting external input resistors. 1. 2. 3.  IN GND OUT The bias resistors consist of thin-film resistors with complete isolation to allow positive biasing of the input. They also have the advantage of SOT-523 almost completely eliminating parasitic effects.  Only the on/off conditions need to be set for operation, making device design easy.  RoHS Compliant  Green EMC  Matte Tin(Sn) Lead Finish  Weight: approx. 0.002g ELECTRICAL SYMBOL: Marking 54 www.msksemi.com DTA114YE-MS Semiconductor Electrical Characteristics Compiance (T A = 25°C unless otherwise noted) Parameter Symbol Input Voltage Output Voltage Min Typ Max VI(on) VO= -0.3V, IO= -1mA -1.4 V VO(on) IO / II = -5mA/-0.25mA -0.3 V VI = -5V -0.88 mA VCC = -50V, VI = 0 -0.5 uA KΩ -0.3 V DC Current Gain GI Input Resistance R1 7 10 13 Resistance Ratio R2 /R1 3.7 4.7 5.7 Transition Frequency Unit VCC = -5V, IO = -100uA IO(off) Output Current Limits VI(off) II Input Current Test Condition fT VO = -5V, IO = -5mA VO = -10V, IO = -5mA f=100MHz 68 250 MHz Absolute Maximum Ratings (TA = 25°C unless otherwise noted) Symbol Parameter VCC Supply Voltage VIN Input Voltage Value Units -50 V -40 ~ +6 V IO Output Current -70 mA ICM Peak Collector Current -100 mA PD Power Dissipation 150 mW TJ Junction to Ambient 150 °C -55 to +150 °C TSTG Storage Temperature Range www.msksemi.com DTA114YE-MS Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol A A1 A2 b1 b2 c D E E1 e e1 L L1 Dimensions In Millimeters Min. Max. 0.700 0.000 0.700 0.150 0.250 0.100 1.500 0.700 1.450 0.900 0.260 0° 0.500 TYP. 0.400 REF. Dimensions In Inches Min. Max. 0.900 0.100 0.800 0.250 0.350 0.200 1.700 0.900 1.750 0.028 0.000 0.028 0.006 0.010 0.004 0.059 0.028 0.057 1.100 0.035 0.460 8° 0.010 0° 0.020 TYP. 0.016 REF. 0.035 0.004 0.031 0.010 0.014 0.008 0.067 0.035 0.069 0.043 0.018 8° REEL SPECIFICATION P/N DTA114YE-MS PKG SOT-523 QTY 3000 www.msksemi.com DTA114YE-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
DTA114YE-MS 价格&库存
很抱歉,暂时无法提供与“DTA114YE-MS”相匹配的价格&库存,您可以联系我们找货
