MMDTC114EE
MMDTC114EE
    ST(先科)
    SOT-523-3
    50V 100MA
MMDTC114EE 数据手册
MMDTC114EE NPN Silicon Epitaxial Planar Digital Transistor Features Collector (Output) • With built-in bias resistors • Simplify circuit design Base (Input) • Reduce a quantity of parts and R1 R2 manufacturing process Emitter (Common) Absolute Maximum Ratings (Ta = 25 ) Parameter Symbol Value Unit VCEO 50 V Input Voltage VI - 10 to + 40 V Collector Current IC 100 mA Power Dissipation Ptot 150 mW Tj 150 Tstg - 55 to + 150 Symbol Max. Unit RθJA 833 /W Collector Emitter Voltage Junction Temperature Storage Temperature Range Thermal Characteristics Parameter Thermal Resistance from Junction to Ambient 1) 1) Device mounted on FR-4 substrate PC board, 2oz copper, with minimum recommended pad layout. 1/4 ® Dated:17/01/2022 Rev:03 MMDTC114EE Characteristics at Ta = 25 Parameter Symbol Min. Typ. Max. Unit DC Current Gain at VCE = 5 V, IC = 5 mA hFE 30 - - - Collector Base Cutoff Current at VCB = 50 V ICBO - - 500 nA Emitter Base Cutoff Current at VEB = 5 V IEBO - - 0.88 mA VCE(sat) - - 0.3 V Input on Voltage at VCE = 0.3 V, IC = 10 mA VI(on) - - 3 V Input off Voltage at VCE = 5 V, IC = 100 µA VI(off) 0.5 - - V Transition frequency at VCE = 10 V, -IE = 5 mA, f = 100 MHz fT - 250 - MHz Input Resistance R1 7 10 13 KΩ Resistance Ratio R2 / R1 0.8 1 1.2 - Collector Emitter Saturation Voltage at IC = 10 mA, IB = 0.5 mA 2/4 ® Dated:17/01/2022 Rev:03 MMDTC114EE Electrical Characteristics Curves Fig 1. Power Derating Curve Fig. 2 Output Characteristics Curve Fig. 3 Output Current vs. VI(ON), Input Voltage Fig. 4 Output Current vs. VI(OFF), Input Voltage Fig. 6 Vo(oN) vs. Output Current Fig. 5 DC Current Gain vs. Output Current 3/4 ® Dated:17/01/2022 Rev:03 MMDTC114EE Package Outline (Dimensions in mm) SOT-523 0.3±0.05 0.1 MAX. 0.8±0.1 1.6±0.1 0.17 MIN. 1.0±0.05 0.1±0.05 1.6±0.1 0.2±0.05 0.5±0.1 0.75±0.1 Recommended Soldering Footprint 1.3 0.7 0.7 0.7 0.6 1 Packing information SOT-523 Pitch Reel Size Package Tape Width (mm) mm inch mm inch SOT-523 8 4 ± 0.1 0.157 ± 0.004 178 7 Per Reel Packing Quantity 4,000 Marking information " RJ " = Part No. " YM " = Date Code Marking RJ " Y " = Year " M " = Month Font type: Arial 4/4 ® Dated:17/01/2022 Rev:03
MMDTC114EE 价格&库存
很抱歉,暂时无法提供与“MMDTC114EE”相匹配的价格&库存,您可以联系我们找货
