WNM4002-3/TR
WNM4002-3/TR
    KUU(永裕泰)
    SOT-523-3
    1个N沟道 耐压:30V 电流:100MA
WNM4002-3/TR 数据手册
WNM4002-3/TR 150mW SOT-523 SURFACE MOUNT Plastic Package N-Channel MOSFET Absolute Maximum Ratings Symbol 3 TA = 25°C unless otherwise noted Parameter VDS Drain-Source Voltage VGS Continuous Gate-Source Voltage Value Units 30 V ±20V V ID Continuous Drain Current 100 mA PD Power Dissipation 150 mW RθJA Thermal Resistance from Junction to Ambient 833 °C /W TSTG Storage Temperature Range -55 to +150 °C +150 °C TJ Operating Junction Temperature 2 1. Gate 2. Source 3. Drain 1 SOT-523 These ratings are limiting values above which the serviceability of the device may be impaired. Specification Features: ƒ ƒ ƒ Electrical Symbol: Low On-resistance Fast Switching Speed KN Low Voltage Drive Makes This Device Ideal for Portable Equipment ƒ ƒ ƒ ƒ ƒ Device Marking Code: Easily Designed Drive Circuits Easy to Parallel RoHS Compliant & Green EMC Matte Tin(Sn) Lead Finish Weight: approx. 0.002g 1/3 WNM4002-3/TR Electrical Characteristics (TA = 25°C unless otherwise noted) Off Characteristics Symbol BVDSS Parameter Test Condition Drain-Source Breakdown Voltage VGS=0V, ID=10uA IGSS Gate-Body Leakage VDS=0V, VGS=±20V IDSS Zero Gate Voltage Drain Current VDS=30V, VGS=0V Limits Min Typ Max 30 Unit Volts ±1 uA 1 µA On Characteristics Symbol Parameter Test Condition Vth(GS) Gate-Threshold Voltage VDS= 3V, ID=100uA RDS(on) Drain-Source On-Resistance Limits Min Typ Unit 1.5 Volts VGS=4V, ID=10mA 8 Ω VGS=2.5V, ID=1mA 13 Ω gfs Forward Trans Conductance VDS=3V, ID=10mA VSD Drain-Source Diode Forward Voltage IS=115mA, VGS=0V 0.8 Max 20 ms 1.2 V Dynamic Characteristics Symbol Parameter Ciss Input Capacitance Coss Output Capacitance Crss Reverse Transfer Capacitance Test Condition Limits Min VDS = 5V VGS = 0V f = 1.0MHz Typ Max Unit 13 pF 9 pF 4 pF Switching Characteristics Symbol tD(on) tD(off) Parameter Turn-on Time Turn-off Time Test Condition VDD=5V, RL=500Ω, ID=10mA, VGs=5V, RG = 10Ω 2/3 Limits Min Typ Max Unit 15 nS 80 nS WNM4002-3/TR SOT-523 Package Outline DIM MILLIMETERS MIN MAX MIN MAX A 0.70 0.90 0.028 0.035 A1 0.00 0.10 0.000 0.004 A2 0.70 0.80 0.028 0.031 b1 0.15 0.25 0.006 0.010 b2 0.25 0.35 0.010 0.014 c 0.10 0.20 0.004 0.008 D 1.50 1.70 0.059 0.067 E 0.70 0.90 0.028 0.035 E1 1.45 1.75 0.057 0.069 e Typical Soldering Pattern: INCHES e1 0.50 TYP. 0.90 L 0.020 TYP. 1.10 0.035 0.40 REF. L1 0.10 θ 0 O 0.043 0.016 REF. 0.30 8 O 0.004 0 O 0.012 8 O NOTES: 1. Above package outline conforms to JEITA EAIJ ED-7500A SC-75A. 2. Dimensions are exclusive of Burrs, Mold Flash & Tie Bar extrusions. 3/3
WNM4002-3/TR 价格&库存
很抱歉,暂时无法提供与“WNM4002-3/TR”相匹配的价格&库存,您可以联系我们找货
