TAK CHEONG
SOT-523
Digital Transistor (Built-in Resistors)
DTA144EE
SE MI COND U CTO R
Green Product
PNP Silicon Surface Mount Transistor
Absolute Maximum Ratings (TA = 25°C unless otherwise noted)
Parameter
Symbol
Value
Units
-50
V
-40 ~ +10
V
VCC
Supply Voltage
VIN
Input Voltage
IO
Output Current
-30
mA
ICM
Peak Collector Current
-100
mA
PD
Power Dissipation
150
mW
TJ
Junction to Ambient
150
°C
-55 to +150
°C
TSTG
Storage Temperature Range
3
2
1.
2.
3.
IN
GND
OUT
1
SOT-523 (SC-75A)
These ratings are limiting values above which the serviceability of the device may be impaired.
FEATURES:
ELECTRICAL SYMBOL:
Built-in resistors enable the configuration of a inverter circuit without
connecting external input resistors.
The bias resistors consist of thin-film resistors with complete isolation
to allow positive biasing of the input. They also have the advantage of
almost completely eliminating parasitic effects.
Only the on/off conditions need to be set for operation, making device
design easy.
RoHS Compliant
Green EMC
Matte Tin(Sn) Lead Finish
Device Type
Device Marking
Weight: approx. 0.002g
DTA144EE
16
DEVICE MARKING CODE:
DB Number: DB-258
April 2018, Revsion B
Page 1
TAK CHEONG
SE MI COND U CTO R
Electrical Characteristics (TA = 25°C unless otherwise noted)
Parameter
Symbol
VI(off)
VCC= -5V, IO= -100uA
VI(on)
VO= -0.3V, IO=-2mA
VO(on)
Input Voltage
Output Voltage
Input Current
Output Current
II
IO(off)
Limits
Test Condition
Min
Typ
-0.5
V
-3
V
IO / II = -10mA/-0.5mA
-0.3
V
VI = -5V
-0.18
mA
VCC = -50V, VI = 0
-0.5
uA
KΩ
DC Current Gain
GI
Input Resistance
R1
32.9
47
61.1
Resistance Ratio
R2 /R1
0.8
1
1.2
Transition Frequency
fT
Unit
Max
VO = -5V, IO = -5mA
68
VO = -10V, IO = -5mA
250
MHz
f=100MHz
SOT-523 Package Outline
MILLIMETERS
INCHES
DIM
MIN
MAX
MIN
MAX
A
0.70
0.90
0.028
0.035
A1
0.00
0.10
0.000
0.004
A2
0.70
0.80
0.028
0.031
b1
0.15
0.25
0.006
0.010
b2
0.25
0.35
0.010
0.014
c
0.10
0.20
0.004
0.008
D
1.50
1.70
0.059
0.067
E
0.70
0.90
0.028
0.035
E1
1.45
1.75
0.057
0.069
e
0.50 TYP.
0.020 TYP.
Typical Soldering Pattern:
e1
0.90
L
L1
θ
1.10
0.035
0.40 REF.
0.10
O
0.016 REF.
0.30
O
8
0.004
O
8O
NOTES:
1. Above package outline conforms to JEITA EAIJ ED-7500A SC-75A.
2. Dimensions are exclusive of Burrs, Mold Flash & Tie Bar extrusions.
DB Number: DB-258
Page 2
TAK CHEONG
DISC LA I MER NOTIC E
NOTICE
The information presented in this document is for reference only. Tak Cheong reserves the right to make
changes without notice for the specification of the products displayed herein.
The product listed herein is designed to be used with ordinary electronic equipment or devices, and not
designed to be used with equipment or devices which require high level of reliability and the malfunction of with
would directly endanger human life (such as medical instruments, transportation equipment, aerospace
machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Tak Cheong Semiconductor
Co., Ltd., or anyone on its behalf, assumes no responsibility or liability for any damagers resulting from such
improper use of sale.
This publication supersedes & replaces all information reviously supplied. For additional information, please visit
our website http://www.takcheong.com, or consult your nearest Tak Cheong’s sales office for further assistance.
Number: DB-100
April 14, 2008 / A
很抱歉,暂时无法提供与“DTA144EE”相匹配的价格&库存,您可以联系我们找货
