Preliminary Datasheet
LP4061
800mA Standalone Linear Li-Ion Battery Charger
with Dual LED Display
General Description
Features
The LP4061 is a complete constant-current constant- voltage
Programmable Charge Current Up to 800mA
linear charger for single cell lithium-ion batteries. Its SOT 23-6 &
No MOSFET, Sense Resistor or Blocking Diode Required
TDFN-8 package and low external component count make the
Constant-Current/Constant-Voltage Operation with
Thermal Regulation to Maximize
Charge Rate Without Risk of Overheating
Charges Single Cell Li-Ion Batteries Directly from USB
Port
Charge Voltage with ±1% Accuracy
ambient temperature. The charge voltage is fixed at 4.2V, and
Available in SOT23-6 & TDFN-8 2mmx2mm Package
the charge current can be programmed externally with a single
Charge Current Monitor Output for Gas Gauging
resistor. The LP4061 automatically terminates the charge cycle
Automatic Recharge
2.9V Trickle Charge Threshold
C/10 Charge Termination
LP4061 ideally suited for portable applications. Furthermore,
the LP4061 is specifically designed to work within USB power
specifications. No external sense resistor is needed, and no
blocking diode is required due to the internal MOSFET
architecture. Thermal feedback regulates the charge current to
limit the die temperature during high power operation or high
when the charge current drops to 1/10th the programmed value
after the final float voltage is reached. Other features include
charge current monitor, under-voltage lockout, automatic
recharge and a status pin to indicate charge termination and the
presence of an input voltage.
Typical Application Circuit
VIN
4
Order Information
LP4061 □ □
VCC
BAT
3
10uF
10uF
RED
1
F: Pb-Free
GREEN
Package Type
5
PROG
6
STAT1
STAT2
GND
2
2.7K
BATTERY
LP4061
B6: SOT23-6
QV:TDFN-8
Marking Information
Device
Applications
Portable Media Players/MP3 players
Cellular and Smart mobile phone
PDA/DSC
Bluetooth Applications
LP4061-04
Dec.-2018
LP4061B6F
LP4061QVF
Marking
LP4061
BCYWX
LP4061
BCYWX
Package
Shipping
SOT23-6
3K/REEL
TDFN-8
4K/REEL
Marking indication:
Y:Production year W:Production week X:Production batch.
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 8
LP4061
Functional Pin Description
Package Type
Pin Configurations
TOP VIEW
SOT23-6
&TDFN-8
STAT1
1
6
PROG
GND
2
5
STAT2
3
4
BAT
7 PROG
STAT2 2
STAT1 3
BAT
8
VCC 1
GND
6
NC
VCC
SOT23-6
NC 4
5 GND
Pin Description
Pin
SOT23-6
Name
Description
STAT1
Open-Drain Charge Status Output. When the battery is charging, the STAT pin is pulled low
by an internal N-channel MOSFET. When the charge cycle is completed, the pin is pulled
High.
TDFN-8
3
1
2
5
GND
Ground.
BAT
Charge Current Output. Provides charge current to the battery and regulates the final float
voltage to 4.2V. An internal precision resistor divider from this pin sets the float voltage
which is disconnected in shutdown mode.
VCC
Positive Input Supply Voltage. It provides power to the charger. VCC can range from 4.35V
to 6.5V and should be bypassed with at least a 1µF capacitor.
8
3
4
1
2
5
6
7
4/6
LP4061-04
STAT2
High by an internal N-channel MOSFET. When the charge cycle is completed, the pin is
pulled Low.
PROG
Charge Current Program, Charge Current Monitor and Shutdown Pin. The charge current is
programmed by connecting a 1% resistor to ground(RPROG).
NC
Dec.-2018
No Connector.
Page 2 of 8
LP4061
Function Block Diagram
VCC
TA
1200X
1X
TDIE
TTEMP
5μA
BAT
MA
R1
TTEMP
VA
CA
SCHMITT
STAT1
SHDN
C1
R3
1V
REF
1.22V
R4
C2
STAT2
C3
0.1V
R5
TO BAT
R2
3μA
VCC
2.9V
PROG
GND
Absolute Maximum Ratings Note 1
Input to GND(VCC) ------------------------------------------------------------------------------------------------------------------ -0.3V to 8V
BAT to GND ---------------------------------------------------------------------------------------------------------------------------- -0.3V to 8V
Other Pin to GND --------------------------------------------------------------------------------------------------------------------- -0.3V to 6V
BAT Short-circuit Duration --------------------------------------------------------------------------------------------------------- Continuous
Operation Temperature Range ---------------------------------------------------------------------------------------------- --40℃ to 85℃
Junction Temperature ---------------------------------------------------------------------------------------------------------------------- 150℃
Storage Temperature ----------------------------------------------------------------------------------------------------------- -65℃ to 165℃
Lead Temp (Soldering,10sec) ------------------------------------------------------------------------------------------------------------ 260℃
Note 1.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only,
and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications
is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Thermal Information
Thermal Resistance (SOT23-5, θ JA ) ----------------------------------------------------------------------------------------------- 250℃/W
Thermal Resistance (TDFN, θ JA ) ----------------------------------------------------------------------------------------------------- 76℃/W
ESD Susceptibility
HBM(Human Body Mode) ------------------------------------------------------------------------------------------------------------------- 2KV
MM(Machine Mode) -------------------------------------------------------------------------------------------------------------------------- 200V
LP4061-04
Dec.-2018
Page 3 of 8
LP4061
Electrical Characteristics
(VCC=5V, TA =25°C , unless otherwise noted)
Symbol
Parameter
VCC
ICC
Condition
Input Supply Current
Min
4.35
IBAT
Regulated Output (Float) Voltage
BAT Pin Current
Units
6.5
V
350
2000
μA
Standby Mode (Charge Terminated)
200
500
μA
25
50
μA
4.2
4.242
V
RPROG=10k, Current Mode
100
120
mA
RPROG=2k, Current Mode
500
600
mA
Standby Mode, VBAT=4.2V
-2.5
-6
μA
Shutdown Mode (RPROG NC)
± 1
± 2
μA
Sleep Mode, VCC=0V
± 1
± 2
μA
50
Shutdown Mode
0℃≤TA≤85℃, IBAT=40mA
ITRIKL
Trickle Charge Current
VBAT
很抱歉,暂时无法提供与“LP4061B6F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.61344
- 50+0.49151
- 150+0.43060
- 500+0.38492
