Preliminary Datasheet
LP4057
600mA Standalone Linear Li-Ion Battery Charger
General Description
Features
The LP4057 is a complete constant-current/constant- voltage
Programmable Charge Current Up to 600mA
linear charger for single cell lithium-ion batteries. Its
No MOSFET, Sense Resistor or Blocking Diode Required
package
and low external component count make the LP4057 ideally
Constant-Current/Constant-Voltage Operation with
suited for portable applications. Furthermore, the LP4057 is
specifically designed to work within USB power specifications.
No external sense resistor is needed, and no blocking diode is
required due to the internal MOSFET architecture. Thermal
feedback regulates the charge current to limit the die
temperature during high power operation or high ambient
Thermal Regulation to Maximize
Charge Rate Without Risk of Overheating
4.2V Charge Voltage with ± 1% Accuracy
Charge Current Monitor Output for Gas Gauging
Automatic Recharge
temperature. The charge voltage is fixed at 4.2V, and the
3V Trickle Charge Threshold
charge current can be programmed externally with a single
Charging OTP
resistor. The LP4057 automatically terminates the charge cycle
Package in SOT23-6
when the charge current drops to 1.5/10th the programmed
value after the final float voltage is reached. When the input
supply (wall adapter or USB supply) is removed, the LP4057
Applications
automatically enters a low current state, dropping the battery
Portable Media Players/MP3 players
drain current to less than 1µA. Other features include charge
Cellular and Smart mobile phone
current monitor, automatic recharge and a status pin to indicate
PDA/DSC
charge termination and the presence of an input voltage.
Bluetooth Applications
Marking Information
Order Information
LP4057
Part
Marking
Package
Shipping
LPS
LP4057B6F
F: Pb-Free
Package Type
B6 : SOT23-6
BMYWX
LPS
SOT23-6
3K/REEL
BCYWX
Marking indication:
Y:Production year W:Production week
X:Production batch.
LP4057-01
Sep.-2021
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 8
LP4057
Functional Pin Description
SOT23-6
Package Type
Pin
Configurations
CHRG
1
6
ISET
GND
2
5
FULL
BAT
3
4
IN
SOT23-6
(Top View)
Pin
Name
Description
Open-Drain Charge Status Output. When the battery is charging, the CHRG
1
CHRG
pin is pulled low by an internal N-channel MOSFET. When the charge cycle is
completed, the pin is pulled High.
2
GND
3
BAT
4
IN
Ground.
Charge Current Output. Provides charge current to the battery and regulates
the final float voltage to 4.2V.
Positive Input Supply Voltage.
Open-Drain Charge Status Output. When the battery is charging, the FULL pin
5
FULL
is pulled High by an internal N-channel MOSFET. When the charge cycle is
completed, the pin is pulled Low.
Charge Current Program and Charge Current Monitor Pin. The charge current
is programmed by connecting a 1% resistor, RISET, to ground. When charging in
6
ISET
constant-current mode, this pin servos to 1V. In all modes, the voltage on this
pin can be used to measure the charge current using the following formula:
IBAT=1000/RISET
LP4057-01
Sep.-2021
Page 2 of 8
LP4057
Typical Application Circuit
LP4057B6F
VIN
4
IN
BAT
VBAT
3
RIN
1Ω
VIN
6
CIN
10uF
ISET
2K
RSET
FULL
2
GND
CBAT
10uF
CHRG
5
1
LED1
LED2
Functional Block Diagram
CC/CV
REGULATOR
IN
3.8V
BAT
UVLO
SOFT-STRAT
BAT
CV
LOOP
CHRG
FULL
CHARGER
CONTROL
CHARGE
STATE
(LP4057B6F)
VRECHAGR
RECHARGE
BAT
3V
TDIE
TRICKLE CHARGE
125℃
100mV
1V
TERMINATION
1000/IBAT
GND
ISET
LP4057-01
Sep.-2021
Page 3 of 8
LP4057
Absolute Maximum Ratings Note1
Input to GND(VIN) --------------------------------------------------------------------------------------------------- -0.3V to 10V
Other Pin to GND ------------------------------------------------------------------------------------------------------ -0.3V to 8V
BAT Short-circuit Duration ------------------------------------------------------------------------------------------- Continuous
Maximum Junction Temperature (TJ)
Maximum Soldering Temperature (at leads, 10 sec)
---------------------------------------------------------------------------------- 125℃
-------------------------------------------------------------- 260℃
Note1. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. Exposure to absolute
maximum rating conditions for extended periods may affect device reliability.
Thermal Information
Maximum Power Dissipation (, TA=25°C) ----------------------------------------------------------------------------- 0.45W
Thermal Resistance (JA) ------------------------------------------------------------------------------------------------ 250℃/W
ESD Susceptibility
HBM(Human Body Model) ---------------------------------------------------------------------------------------------------- 2KV
MM(Machine Model) ------------------------------------------------------------------------------------------------------------ 200V
Recommended Operating Conditions
Ambient Temperature Range ------------------------------------------------------------------------------------ -20℃ to 85℃
LP4057-01
Sep.-2021
Page 4 of 8
LP4057
Electrical Characteristics
(TA = 25℃. VIN = 5V, unless otherwise noted.)
SYMBOL
PARAMETER
VIN
Adapter/USB Voltage Range
IIN
Input Supply Current
Standby Mode (Charge Terminated)
VFLOAT
Regulated Output (Float) Voltage
IBAT = 40mA
IBAT
BAT Pin Current
CONDITIONS
MIN
TYP.
MAX
UNITS
4.5
5
6.5
V
50
4.158
4.2
RISET = 10K,Current Mode
100
RISET = 2K,Current Mode
500
Standby Mode, VBAT = 4.2V
Sleep Mode, VIN = 0V
uA
4.242
V
mA
±1
uA
VTRIKL
Trickle Charge Threshold Voltage
RISET = 10k, VBAT Rising
3
V
VTRHYS
Trickle Charge Hysteresis Voltage
RISET = 10K
150
mV
ITRIKL
Trickle charge current
VBAT < VTRIKL, RISET =10K
40
VBAT < VTRIKL, RISET=2K
200
VUV
VIN Undervoltage Lockout Threshold
From VIN Low to High
3.8
V
VUVHYS
VIN Undervoltage Lockout Hysteresis
200
mV
VASD
VIN–VBAT Lockout Threshold Voltage
150
mV
ITERM
C/10 Termination Current Threshold
15
% IBAT
VISET
ISET Pin Voltage
RISET = 10K,Charge Mode
1
V
VSTAT
STAT1/STAT2 Pin Output Low Voltage
ISTAT = 5mA
0.5
V
ISTAT
STAT1/2 Pin Weak Pull-Down Current
ICHRG = 5V
5
uA
ΔVRECHRG
Recharge Battery Threshold Voltage
VFLOAT - VRECHRG
LP4057-01
Sep.-2021
200
mA
mV
Page 5 of 8
Applications Information
The LP4057 is a single cell lithium-ion battery charger using a
constant-current/constant-voltage algorithm. It can deliver up
to 600mA of charge current (using a good thermal PCB layout)
with a final float voltage accuracy of ± 1%. The LP4057
includes an internal P-channel power MOSFET and thermal
regulation circuitry. No blocking diode or external current
sense resistor is required; thus, the basic charger circuit
requires only three external components. Furthermore, the
LP4057 is capable of operating from a USB power source.
Normal Charge Cycle
A charge cycle begins when the voltage at the VIN pin rises
Charge Status Indicator (CHRG/FULL)
The charge status output has two different states: strong
pull-down (~5mA) and high impedance. The strong pull-down
state indicates that the LP4057 is in a charge cycle. High
impedance indicates that the charge cycle complete or the
LP4057 is in under voltage lockout mode: either VIN is less
than 150mV above the BAT pin voltage or insufficient voltage
is applied to the IN pin. A microprocessor can be used to
distinguish between these two states.
Charge Stage
CHRG
FULL
Charging
Low
High
Charge Complete
High
Low
above the UVLO threshold level and a 1% program resistor is
connected from the ISET pin to ground or when a battery is
connected to the charger output. If the BAT pin is less than
2.9V, the charger enters trickle charge mode.
When the BAT pin voltage rises above 2.9V, the charger
enters constant-current mode, where the programmed charge
current is supplied to the battery. When the BAT pin
approaches the final float voltage (4.2V), the LP4057 enters
constant-voltage mode and the charge current begins to
decrease. When the charge current drops to 1.5/10 of the
programmed value the charge cycle ends.
Charge Termination
A charge cycle is terminated when the charge current falls to
1.5/10th the programmed value after the final float voltage is
reached. This condition is detected by using an internal,
filtered comparator to monitor the ISET pin. When the ISET
pin voltage falls below 100mV for longer than TTERM (typically
1ms), charging is terminated. The charge current is latched off
and the LP4057 enters standby mode, where the input supply
current drops to 50µA. When charging, transient loads on the
BAT pin can cause the ISET pin to fall below 150mV for short
Programming Charge Current
periods of time before the DC charge current has dropped to
The charge current is programmed using a single resistor
1.5/10th the programmed value. The 1ms filter time (TTERM) on
from the ISET pin to ground. The battery charge current is
the termination comparator ensures that transient loads of this
1000 times the current out of the ISET pin. The program
nature do not result in premature charge cycle termination.
resistor and the charge current are calculated using the
Once the average charge current drops below 1.5/10th the
following equations:
programmed value, the LP4057 terminates the charge cycle
RISET=1000÷IBAT,
and ceases to provide any current through the BAT pin. In this
state, all loads on the BAT pin must be supplied by the battery.
IBAT=1000÷RISET
The LP4057 constantly monitors the BAT pin voltage in
The charge current out of the BAT pin can be determined at
standby mode. If this voltage drops below the 4.0V recharge
any time by monitoring the ISET pin voltage using the
threshold (VRECHRG), another charge cycle begins and current
following equation:
is once again supplied to the battery. To manually restart a
IBAT=VISET÷RISET×1000
LP4057-01
Sep.-2021
charge cycle when in standby mode, the input voltage must
be removed and reapplied.
Page 6 of 8
Thermal Limit
IN Bypass Capacitor
An internal thermal feedback loop reduces the programmed
Many types of capacitors can be used for input bypassing;
charge current if the die temperature attempts to rise above a
however, caution must be exercised when using multilayer
preset value of approximately 125℃. This feature protects the
ceramic capacitors. Because of the self-resonant and high Q
LP4057 from excessive temperature and allows the user to
characteristics of some types of ceramic capacitors, high
push the limits of the power handling capability of a given
voltage transients can be generated under some start-up
circuit board without risk of damaging the LP4057. The charge
conditions, such as connecting the charger input to a live
current can be set according to typical (not worst-case)
power source. Adding a 1.5Ω resistor in series with an X5R
ambient temperature with the assurance that the charger will
ceramic capacitor will minimize start-up voltage transients.
automatically reduce the current in worst-case conditions.
Automatic Recharge
Layout Considerations
Once the charge cycle is terminated, the LP4057 continuously
monitors the voltage on the BAT pin using a comparator with
keep their traces short and wide.
a 2ms filter time (TRECHARGE). A charge cycle restarts when the
battery voltage falls below 4.0V (which corresponds to
For the main current paths as indicated in bold lines,
Put the input capacitor as close as possible to the device
pins (IN and GND).
Connect all analog grounds to a command node and
approximately 80% to 90% battery capacity). This ensures
then connect the command node to the power ground
that the battery is kept at or near a fully charged condition and
behind the output capacitors.
eliminates the need for periodic charge cycle initiations.
CHRG output enters a strong pull-down state during recharge
cycles.
Power Dissipation
The conditions that cause the LP4057 to reduce charge
current through thermal feedback can be approximated by
considering the power dissipated in the IC. Nearly all of this
power dissipation is generated by the internal MOSFET—this
is calculated to be approximately:
PD=(VIN-VBAT) × IBAT
LP4057-01
Sep.-2021
Page 7 of 8
Packaging Information
SOT23-6
A
D
B
C
A1
b
1.00
2.60
e
H
0.95
L
0.5
Recommended Land Pattern
SYMBOL
MILLIMETER
MIN
NOM
MAX
A
0.889
1.100
1.295
A1
0.000
0.050
0.152
B
1.397
1.600
1.803
b
0.28
0.35
0.559
C
2.591
2.800
3.000
D
2.692
2.920
3.120
e
LP4057-01
0.95BSC
H
0.080
0.152
0.254
L
0.300
0.450
0.610
Sep.-2021
Page 8 of 8
很抱歉,暂时无法提供与“LP4057B6F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.46640
- 200+0.15510
- 1500+0.09713
- 3000+0.07689
- 国内价格
- 10+0.26601
- 100+0.20877
- 300+0.18015
