Rev 1.1
DIO8650E
Single Stage Fly-back & PFC Controller With Primary Side
Control For LED Lighting
Features
Descriptions
Primary side control eliminates the
The DIO8650E is a single stage Fly-back and PFC
opto-coupler
controller targeting at LED lighting applications.
Valley turn-on of the primary MOSFET to
achieve lower switching losses
The DIO8650E is a primary side controller without
Power factor >0.95 @230VAC
applying any secondary feedback circuit for low
THD < 10% @230VAC
cost, and drives the Fly-back converter in the
Reliable short LED and Open LED protection
quasi-resonant mode to achieve higher efficiency.
Quick start up:V VIN,OVP, then
set VIN=15V
1.6
2
2.5
mA
IQ
Quiescent Current
No switching
0.26
mA
IVIN
Operation current
CL=100pF,f=15kHz
0.36
mA
Error Amplifier Section
VREF
Internal reference voltage
0.294
0.3
0.306
V
ZCS pin Section
VZCS,OVP
ZCS pin OVP voltage threshold
1.5
V
VFAST_ST
Fast start up threshold
0.55
V
Current limit reference voltage
0.45
V
K2
CC Feed forward coefficient
0.1
RK2
CC Feed forward resistor RK2
340
Ω
15.7
µs
Leading edge blanking time
300
ns
TOFF,MAX
Max OFF time
151
µs
TLEB.ZCD
ZCD Blanking Time
2
µs
115
kHz
Current Sense Section(Source PIN of integrated MOSFET)
VCS.LMT
PWM Section
TON.MAX
TLEB
fMAX
Max on time
COMP high clamp
After turn off
Maximum switching frequency
Gate Driver
VGATE_CLAMP
Output Clamp Voltage
VCC=20V
12
V
TRISING
rising time from 10% to 90%
CLOAD=1nF
410
ns
TFALLING
falling time from 90% to 10%
CLOAD=1nF
50
ns
150
°C
Thermal Section
TSD
www.dioo.com
Thermal Shutdown Temperature
© 2017 DIOO MICROCIRCUITS CO., LTD
DIO8650E• Rev. 1.1
Single Stage Flyback & PFC Controller With Primary Side Control For LED Lighting
Electrical Characteristics
DIO8650E
Figure 3 Typical fly-back application
www.dioo.com
DIO8650E• Rev. 1.1
Typical Application
DIO8650E
Application Information
Start up
After AC or DC supply is powered on, the capacitor CVIN across VIN and GND pin is charged up by BUS voltage
through a start up resistor RST. Once VVIN rises up to VVIN-ON, the internal blocks start to work and PWM output is
enabled.
Shut down
After AC supply or DC BUS is powered off, the energy stored in the BUS capacitor will be discharged. When the
auxiliary winding of Fly-back transformer can’t supply enough energy to VIN pin, VVIN will drop down. Once VVIN is
below VVIN-OFF, the IC will stop working and VCOMP will be discharged to zero.
Primary-side constant-current control
Primary side control is applied to eliminate secondary feedback circuit or opto-coupler, which reduces the circuit
cost.
www.dioo.com
DIO8650E• Rev. 1.1
Figure 4 Typical buck-boost application
DIO8650E
QR mode operation provides low turn-on switching losses for Fly-back converter.
Over Voltage Protection (OVP) & Open LED Protection (OLP)
The output voltage is reflected by the auxiliary winding voltage of the Fly-back transformer, and both ZCS pin and
VIN pin provide over voltage protection function. When the load is null or large transient happens, the output
voltage will exceed the rated value. When VVIN exceeds VVIN,OVP or VZCS exceeds VZCS,OVP, the over voltage
protection is triggered and the IC will discharge VVIN by an internal current source IVIN,OVP. Once VVIN is below
VVIN,OFF, the IC will shut down and be charged again by BUS voltage through start up resistor. If the overvoltage
condition still exists, the system will operate in hiccup mode.
Short Circuit Protection (SCP)
When the output is shorted to ground, the output voltage is clamped to zero. The voltage of the auxiliary winding
is proportional to the output winding, so valley signal cannot be detected by ZCS. Without valley detection,
MOSFET cannot be turned ON until maximum off time tOFF,MAX is matched. If MOSFET is turned ON by tOFF,MAX
64 times continuously, IC will be shut down and enter into hiccup mode. If the output voltage is not low enough to
disable valley detection in short condition, VVIN will dropdown without auxiliary winding supply. Once VVIN is below
VVIN,OFF, the IC will shut down and be charged again by the BUS voltage through the start up resistor. If the short
circuit condition still exists, the system will operate in hiccup mode.
www.dioo.com
DIO8650E• Rev. 1.1
Quasi-Resonant Operation
DIO8650E
COMMON DIMENSIONS
(UNITS OF MEASURE=MILLIMETER)
Symbol
MIN
NOM
MAX
A
1.25
A1
A2
1.00
1.10
1.20
A3
0.60
0.65
0.70
b
0.36
0.50
b1
0.36
0.38
0.45
c
0.14
0.20
c1
0.14
0.15
0.16
D
2.826
2.926
3.026
E
2.60
2.80
3.00
E1
1.526
1.626
1.726
e
0.90
0.95
1.00
e1
1.80
1.90
2.00
L
0.35
0.45
0.60
L1
0.59REF
L2
0.25BSC
R
0.10
R1
0.10
0.25
Θ
0°
8°
Θ1
3°
5°
7°
Θ2
6°
14°
www.dioo.com
DIO8650E• Rev. 1.1
Physical Dimensions: SOT-23-6
DIO8650E
COMMON DIMENSIONS
Symbol
MIN
NOM
MAX
A
1.35
1.55
1.75
A1
0.10
0.15
0.25
A2
1.25
1.40
1.65
A3
0.50
0.60
0.70
b
0.38
0.51
b1
0.37
0.42
0.47
c
0.17
0.25
c1
0.17
0.20
0.23
D
4.80
4.90
5.00
E
5.80
6.00
6.20
E1
3.80
3.90
4.00
e
1.27BSC
L
0.45
0.60
0.80
L1
1.04REF
L2
0.25BSC
R
0.07
R1
0.07
h
0.30
0.40
0.50
0°
8°
Θ
15°
17°
19°
Θ1
11°
13°
15°
Θ2
15°
17°
19°
Θ3
11°
13°
15°
Θ4
www.dioo.com
DIO8650E• Rev. 1.1
Physical Dimensions: SOIC-8
DIO8650E
Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses on
industry markets, such as, cell phone, handheld products, laptop, and medical equipment and so on. Dioo’s product families include
analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product
families.
For additional product information, or full datasheet, please contact with our Sales Department or Representatives.
www.dioo.com
DIO8650E• Rev. 1.1
CONTACT US
很抱歉,暂时无法提供与“DIO8650ECST6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.77091
- 50+0.75384
- 150+0.74240
