Preliminary Datasheet
LP6498A
600KHz 36V/1.2A Synchronous Step-down Converter
General Description
The
LP6498A
Input Voltage Range: 4.5V to 30V
Output Voltage Range: 0.8V to 12V
4.5V to 30V.1.2A continuous output current .The
1200mA Load Current
converter
Up to 93% Efficiency
600KHz Switching Frequency
minimum number of readily available standard
Short Circuit Protection
external components.over current protection and
Thermal Fault Protection
S O T 2 3 - 6 Package
RoHS Compliant and 100% Lead (Pb)-Free
regulator
is
from
a
Features
synchronous
a
high
step-down
voltage
input
supply.Operating with an input voltage range from
integrates
a
main
switch
and
a
synchronous rectifier for high efficiency without an
external Schottky diode. LP6498A Requires a
thermal shutdown . output short circuit protection.
The LP6498A converters are available in the
industry standard SOT23-6 packages.
Typical Application Circuit
Order Information
LP6498A
VIN
F: Pb-Free
Vout
VIN
SW
22uF
15uH
22uF
Package Type
EN
NC
GND
FB
R1
B6:SOT23-6
R2
Applications
Marking Information
Car Charger / Adaptor
Pre-Regulator for Linear Regulators
Distributed Power Systems
USB Dedicated Charging Ports (DCP)
LP6498A-00
Mar.-2018
Device
LP6498AB6F
Marking
LPS
AOYWX
Package
SOT23-6
Shipping
3K/REEL
Marking indication:
Y: Year code. W: Week code. X: Batch numbers.
Email: marketing@lowpowersemi.com
www.lowpowersemi.com
Page 1 of 7
LP6498A
Functional Pin Description
Package Type
SOT23-6(Top View)
Pin Configurations
NC
1
6
SW
GND
2
5
VIN
FB
3
4
EN
Pin Description
PIN
Name
Description
1
NC
No connection.
2
GND
Ground.
3
FB
4
EN
Enable Pin
5
VIN
Voltage supply.
6
SW
Switch Mode Connection to Inductor. This pin connects to the drains of the
Feedback Input.
Vout = (
R1
+ 1) × VFB
R2
internal main and synchronous power MOSFET switches.
LP6498A-00
Mar.-2018
Page 2 of 7
LP6498A
Function Diagram
VIN
CURRENT
SENSE
EN
REF
LDO
PG
OSC
ISUM
SOFT
START
0.8V
SW
EA
FB
PWM
CONTROL
LOGIC
DRIVER
NG
PROTECT
GND
Absolute Maximum Ratings Note 1
VIN\SW \EN to GND ---------------------------------------------------------------------------------------------- -0.3V to 36V
VOUT\LED\RV\FB to GND--------------------------------------------------------------------------------------- -0.3V to 6.5V
Maximum Junction Temperature -------------------------------------------------------------------------------------- 150°C
Storage Temperature ------------------------------------------------------------------------------------------ -65℃ to 165℃
Operating Ambient Temperature Range (TA) ------------------------------------------------------------- -20℃ to 85°C
Maximum Soldering Temperature (at leads, 10 sec) ------------------------------------------------------------- 260°C
Note 1. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and
functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied.
Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Thermal Information
Maximum Power Dissipation (SOT23-6, PD, TA=25℃) ------------------------------------------------------------ 0.6W
Thermal Resistance (SOT23-6, θJA) ------------------------------------------------------------------------------ 200℃/W
ESD Susceptibility
HBM(Human Body Mode) -------------------------------------------------------------------------------------------------- 2KV
MM(Machine Mode) --------------------------------------------------------------------------------------------------------- 200V
LP6498A-00
Mar.-2018
Page 3 of 7
LP6498A
Electrical Characteristics
VIN=12V, VEN=5V, TA=25℃, unless otherwise noted
Symbol
Parameter
Condition
Min
Typ
VIN
Input Voltage
4.5
VFB
Feedback Threshold Voltage Accuracy
0.784
IQ
Quiescent Current
Iload=0mA
8
mA
VUVLO
VIN Under Voltage Lockout Threshold
VIN Rising
4
V
VUVLO-HYS
UVLO Hysteresis
0.5
V
ILIM
P-Channel Current Limit
0.8
TJ=25℃
2.4
TJ=150℃
1.6
Max
Units
30
V
0.816
V
A
RDS(ON)_H
High-Side Switch On Resistance
240
mΩ
RDS(ON)_L
Low-Side Switch On Resistance
130
mΩ
THICCUP
Hiccup Time
6
mS
TSS
Soft-start Time
0.8
mS
fOSC
Oscillator Frequency
600
KHz
tSD
Over-Temperature Shutdown Threshold
150
THYS
Over-Temperature Shutdown Hysteresis
LP6498A-00
Mar.-2018
Page 4 of 7
LP6498A
Typical Operating Characteristics
Efficiency VS Iout
100
90
80
Efficiency(%)
70
60
50
40
VIN=8V
30
VIN=12V
VIN=18V
10
VIN=24V
0.20
0.40
0.60
0.80
1.00
1.20
1.40
IOut(A)
LP6498A-00
Mar.-2018
Page 5 of 7
LP6498A
Operation Information
Layout Guidance
Functional Description
When laying out the PCB board, the following layout guideline
The LP6498A is a switch-mode step-down DC-DC converter.
The device operates at a fixed 600KHz switching frequency,
and uses a slope compensated current mode architecture.
This step-down DC-DC converter can supply up to 1.2A
output current at input voltage range from 4.5V to 30V. It
minimizes external component size and optimizes efficiency
at the heavy load range. The integrated slope compensation
allows the device to remain stable over a wider range of
inductor values so that smaller values (6.8μH to 22μH) with
should be followed to ensure proper operation of the
LP6498A:
1. The power traces, including the GND trace, the SW trace
and the IN trace should be kept short, direct and wide to allow
large current flow. The L connection to the SW pins should be
as short as possible. Use several VIN pads when routing
between layers.
2. The input capacitor (CIN) should connect as closely as
possible to VIN and GND to get good power filtering.
lower DCR can be used to achieve higher efficiency.
LP6498A-00
Mar.-2018
Page 6 of 7
LP6498A
Packaging Information
SOT23-6
LP6498A-00
Mar.-2018
Page 7 of 7
很抱歉,暂时无法提供与“LP6498AB6F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.72270
- 200+0.49830
- 1500+0.45210
- 3000+0.42240
- 国内价格
- 5+0.95667
- 50+0.75449
- 150+0.65340
- 500+0.57759
- 3000+0.48946
