SK6152
SK6152
    SUNTEK(洺太电子)
    SOT23-6
    SK6152是一款高度集成的升压转换器,设计用于需要高电压和高效率解决方案的应用。它集成了一个20V的功率开关,可以从锂离子电池或两节串联的碱性电池输出高达18V的电压。该器件的工作频率为1.2MHz...
SK6152 数据手册
SK6152 18V Output 1.2MHz Boost Regulator General Description Features The SK6152 is a highly integrated boost converter designed for applications requiring high voltage and high efficiency solution. The SK6152 integrates a 20V power switch, it can output up to 18V from input of a Li+ battery or two cell alkaline batteries in series. The SK6152 operates with a switching frequency at 1.2MHz. This allows the use of small external components. SK6152 has typical 4A switch current limit. It has 1.5mS built-in soft start time to minimize the inrush current. The SK6152 also implements output short circuit protection, output over-voltage protection and thermal shutdown. The SK6152 is available in a small SOT23-6 package. ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ 2.3V to 5.5V Input Voltage Up to 18V Output Voltage Integrated 60mΩ Power MOSFET 1.2MHz Fixed Switching Frequency Internal 4A Switch Current Limit Power Save Operation Mode at Light Load Internal 1.5mS Soft Start Time Up to 85% Efficiency@3.6V Input 12V Output Output Short Circuit Protection Output Over-Voltage Protection Thermal Shutdown Protection Output Adjustable from 0.6V -40°C to +85°C Temperature Range Available in SOT23-6 Package Applications ⚫ ⚫ ⚫ ⚫ Wearable Devices Sensor Power Supply Battery-Powered Equipment Portable Medical Equipment Typical Application Circuit ON/ OFF VIN C1 22μF/25V Ceramic EN FB IN GND NC SW R1 100k 1% R2 3.48k 1% C2 22μF/25V Ceramic L1 4.7μH D1 VOUT18V Typical Application Circuit 上海洺太电子科技有限公司 -1- SUNTEK MICRO LTD Pin Configuration TOP VIEW SW 1 6 NC GND 2 5 IN FB 3 4 EN SOT23-6 Pin Description Pin Name Function 1 SW Power Switch Output. SW is the drain of the internal MOSFET switch. Connect the power inductor and output rectifier to SW 2 GND 3 FB Feedback Input. The FB voltage is 0.6V. Connect a resistor divider to FB 4 EN Regulator On/Off Control Input. A high input at EN turns on the converter, and a low input turns it off. When not used, connect EN to the input supply for automatic startup 5 IN Input Supply Pin 6 NC Not Connection Ground Pin Ordering Information Part Number Package Mark Quantity/ Reel SK6152 SOT23-6 KHXXX 3000 SK6152 devices are Pb-free and RoHS compliant. 上海洺太电子科技有限公司 -2- SUNTEK MICRO LTD Absolute Maximum Ratings (1) (2) Item Min Max Unit VIN EN voltage -0.3 6 V SW voltage -0.3 19 V SW voltage (10ns transient) -5 20 V All Other Pins –0.3 6 V Power dissipation (3) Internally Limited Operating junction temperature, TJ -40 150 °C Storage temperature, Tstg –65 150 °C 260 °C Lead Temperature (Soldering, 10sec.) Note (1): Exceeding these ratings may damage the device. Note (2): The device is not guaranteed to function outside of its operating conditions. Note (3): The maximum allowable power dissipation is a function of the maximum junction temperature, TJ(MAX), the junction-to-ambient thermal resistance, RθJA, and the ambient temperature, TA. The maximum allowable power dissipation at any ambient temperature is calculated using: PD (MAX) = (TJ(MAX) − TA)/RθJA. Exceeding the maximum allowable power dissipation causes excessive die temperature, and the regulator goes into thermal shutdown. Internal thermal shutdown circuitry protects the device from permanent damage. Thermal shutdown engages at TJ=160°C (typical) and disengages at TJ= 130°C (typical). ESD Ratings Item Description Value Unit V(ESD-HBM) Human Body Model (HBM) ANSI/ ESDA/JEDEC JS-001-2014 Classification, Class: 2 ±2000 V V(ESD-CDM) Charged Device Mode (CDM) ANSI/ESDA/JEDEC JS-002-2014 Classification, Class: C0b ±200 V ILATCH-UP JEDEC STANDARD NO.78E APRIL Temperature Classification, Class: I ±150 mA Min Max Unit –40 125 °C Operating temperature range -40 85 °C Input voltage VIN 2.3 5.5 V 18 V 1 A 2016 Recommended Operating Conditions Item Operating junction temperature (1) Output voltage VOUT Typical Output Current IOUT 0 Note (1): All limits specified at room temperature (TA = 25°C) unless otherwise specified. All room temperature limits are 100% production tested. All limits at temperature extremes are ensured through correlation using standardStatistical Quality Control (SQC) methods. All limits are used to calculate Average Outgoing Quality Level (AOQL). 上海洺太电子科技有限公司 -3- SUNTEK MICRO LTD Thermal Information Item Description (1)(2) Value Unit 105 °C/W RθJA Junction-to-ambient thermal resistance RθJC(top) Junction-to-case (top) thermal resistance 55 °C/W RθJB Junction-to-board thermal resistance 17.5 °C/W ψJT Junction-to-top characterization parameter 3.5 °C/W ψJB Junction-to-board characterization parameter 17.5 °C/W Note (1): The package thermal impedance is calculated in accordance to JESD 51-7. Note (2): Thermal Resistances were simulated on a 4-layer, JEDEC board Electrical Characteristics (1)(2) VIN=5V, TA=25°C, unless otherwise specified. Parameter Test Conditions Input voltage range Min Typ. 2.3 Output voltage range Max Unit 5.5 V 18 V Supply Current (Quiescent) VFB =110% 150 200 µA Supply Current (Shutdown) VEN =0 or EN = GND 0.1 1 µA 600 612 mV 60 120 mΩ Feedback Voltage 588 SW On Resistance Current Limit 4 A Output Over Voltage Protection Threshold 19 V Output Over voltage protection hysteresis 800 mV Switching Frequency 1.2 MHz 90 % 100 nS Maximum Duty Cycle Duty cycle=50% VFB=90% Minimum On-Time EN Rising Threshold 1.2 V EN Falling Threshold 0.8 EN Threshold Hysteresis 100 Wake up VIN Voltage Under-Voltage Lockout Threshold Shutdown VIN Voltage 2.0 mV 2.2 V 1.8 V 200 mV Soft Start 1.5 mS Thermal Shutdown 160 ℃ Thermal Hysteresis 30 ℃ Hysteresis VIN voltage 1.6 V Note (1): MOSFET on-resistance specifications are guaranteed by correlation to wafer level measurements. Note (2): Thermal shutdown specifications are guaranteed by correlation to the design and characteristics analysis. 上海洺太电子科技有限公司 -4- SUNTEK MICRO LTD Typical Performance Characteristics (1) (2) Note (1): Performance waveforms are tested on the evaluation board. Note (2): VIN =5V, VOUT=12V, TA = +25ºC, unless otherwise noted. Efficiency vs. Load Current Load Regulation Line Regulation VOUT=12V VOUT=12V VOUT=12V Output Ripple Voltage Output Ripple Voltage Output Ripple Voltage VIN=5V, VOUT=12V, IOUT=0A VIN=5V, VOUT=12V, IOUT=200mA VIN=5V, VOUT=12V, IOUT=400mA Enable Startup at No Load Enable Shutdown at No Load Enable Startup at Heavy Load VIN=5V, VOUT=12V VIN=5V, VOUT=12V VIN=5V, VOUT=12V, IOUT=400mA Enable Shutdown at Heavy Load Power Up at No Load Power Up at Heavy Load VIN=5V, VOUT=12V, IOUT=400mA VIN=5V, VOUT=12V, IOUT=0A VIN=5V, VOUT=12V, IOUT=400mA 上海洺太电子科技有限公司 -5- SUNTEK MICRO LTD Functional Block Diagram Block Diagram Functions Description Under-Voltage Lockout (UVLO) Under-voltage lockout (UVLO) protects the chip from operating at an insufficient supply voltage. UVLO protection monitors the internal regulator voltage. When the voltage is lower than UVLO threshold voltage, the device is shut off. When the voltage is higher than UVLO threshold voltage, the device is enabled again. Enable and Disable When the input voltage is above maximal UVLO rising threshold and the EN pin is pulled high, the SK6152 is enabled. When the EN pin is pulled low, the SK6152 goes into shutdown mode. In shutdown mode, less than 1μA input current is consumed. Soft-Start The SK6152 begins soft start when the EN pin is pulled high. at the beginning of the soft start period, the isolation FET is turned on slowly to charge the output capacitor. After the pre-charge phase, the SK6152 starts switching. This is called switching soft start phase. An internal soft start circuit limits the peak inductor current according to the output voltage. The switching soft start phase is about 1.5ms typically. The soft start function reduces the inrush current during startup. Over-Voltage Protection The SK6152 has internal output over-voltage protection (OVP) function. When the output voltage exceeds the OVP threshold, the device stops switching. Once the output voltage falls 800mV below the OVP threshold, the device resumes operation again. 上海洺太电子科技有限公司 -6- SUNTEK MICRO LTD Output Short Circuit Protection When the VOUT pin is shorted to ground, the SK6152 stop switching. This function protects the device from being damaged when the output is shorted to ground. Thermal Shutdown Thermal shutdown prevents the chip from operating at exceedingly high temperatures. When the silicon die temperature exceeds 160°C, it shuts down the whole chip. When the temperature falls below its lower threshold (Typ. 130°C) the chip is enabled again. PWM Mode The SK6152 uses a quasi-constant 1.2MHz frequency pulse width modulation (PWM) at moderate to heavy load current. Based on the input voltage to output voltage ratio, a circuit predicts the required off-time. At the beginning of the switching cycle, the NMOS switching FET, shown in the functional block diagram, is turned on. The input voltage is applied across the inductor and the inductor current ramps up. In this phase, the output capacitor is discharged by the load current. When the inductor current hits the current threshold that is set by the output of the error amplifier, the PWM switch is turned off, and the power diode is forward-biased. The inductor transfers its stored energy to replenish the output capacitor and supplythe load. When the off-time is expired, the next switching cycle starts again.The error amplifier compares the FB pin voltage with an internal reference voltage, and its output determines the inductor peak current. The SK6152 hasabuilt-incompensationcircuitthatcanaccommodateawide rangeof input voltage,output voltage, inductor value and output capacitor value for stable operation. Power Save Mode The SK6152 integrates a power save mode with pulse frequency modulation (PFM) to improve efficiency at light load. When the load current decreases, the inductor peak current set by the output of the error amplifier declines to regulate the output voltage. When the FB voltage hits the PFM reference voltage, the SK6152 goes into the power save mode. In the power save mode, when the FB voltage rises and hits the PFM reference voltage, the device continuous switching for several cycles because of the delay time of the internal comparator. Then it stops switching. The load is supplied by the output capacitor and the output voltage declines. When the FB voltage falls below the PFM reference voltage, after the delay time of the comparator, the device starts switching again to ramp up the output voltage. 上海洺太电子科技有限公司 -7- SUNTEK MICRO LTD Applications Information Setting the Output Voltage SK6152 are internally compensated and do not require external components to achieve stable operation. The output voltage can be programmed by resistor divider, as shown in Equation 𝑉𝑂𝑈𝑇 = 𝑉𝐹𝐵 × 𝑅1+𝑅2 . 𝑅2 VOUT R1 VF COUT E E DBACK R2 Inductor Selection Because the selection of the inductor affects steady state operation, transient behavior, and loop stability, the inductor is the most important component in power regulator design. There are three important inductor specifications, inductor value, saturation current, and dc resistance (DCR). The SK6152 is designed to work with inductor values between 2.2μH and 22μH. Follow the Equation below to calculate the inductor’s peak current for the application. To calculate the current in the worst case, use the minimum input voltage, maximum output voltage, and maximum load current of the application. To have enough design margin, choose the inductor value with -30% tolerance, and a low power-conversion efficiency for the calculation. In a boost regulator, the inductor dc current can be calculated with Equation: 𝐼𝐿(𝐷𝐶) = 𝑉𝑂𝑈𝑇 × 𝐼𝑂𝑈𝑇 𝑉𝐼𝑁 × 𝜂 Where ⚫ ⚫ ⚫ ⚫ VOUT = output voltage IOUT = output current VIN = input voltage η = power conversion efficiency, use 80% for most applications The inductor ripple current is calculated with the Equation 3 for an asynchronous boost converter in continuous conduction mode (CCM). 𝛥𝐼𝐿(𝑃−𝑃) = 𝑉𝐼𝑁 × (𝑉𝑂𝑈𝑇 + 𝑉𝐷𝐼𝑂𝐷𝐸 − 𝑉𝐼𝑁 ) 𝐿 × 𝐹𝑆 × (𝑉𝑂𝑈𝑇 + 𝑉𝐷𝐼𝑂𝐷𝐸 ) Where ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ΔIL(P-P) = inductor ripple current L = inductor value VIN = input voltage VOUT = output voltage VDIODE = output diode forward voltage FS = switching frequency, Hertz 上海洺太电子科技有限公司 -8- SUNTEK MICRO LTD Therefore, the inductor peak current is calculated with Equation: 𝐼𝐿(𝑃) = 𝐼𝐿(𝐷𝐶) + 𝛥𝐼𝐿(𝑃−𝑃) 2 Normally, it is advisable to work with an inductor peak-to-peak current of less than 40% of the average inductor current for maximum output current. A smaller ripple from a larger valued inductor reduces the magnetic hysteresis losses in the inductor and EMI. Bit in the same way, load transient response time is increased. Because the SK6152 is for relatively small output current application, the inductor peak-to-peak current could be as high as 200% of the average current with a small inductor value, which means the SK6152 always works in DCM mode. Input and Output Capacitor Selection The output capacitor is mainly selected to meet the requirements for output ripple and loop stability. This ripple voltage is related to the capacitor’s capacitance and its equivalent series resistance (ESR). Assuming a ceramic capacitor with zero ESR, the minimum capacitance needed for a given ripple can be calculated by: 𝐼𝑂𝑈𝑇 × 𝐷𝑀𝐴𝑋 𝐶𝑂𝑈𝑇 = 𝐹𝑆 × 𝑉𝑅𝐼𝑃𝑃𝐿𝐸 Where ⚫ ⚫ DMAX = maximum switching duty cycle IRIPPLE = peak to peak output voltage ripple The ESR impact on the output ripple must be considered if tantalum or aluminum electrolytic capacitors are used. Care must be taken when evaluating a ceramic capacitor’s derating under dc bias, aging, and ac signal. For example, the dc bias can significantly reduce capacitance. A ceramic capacitor can lose more than 50% of its capacitance at its rated voltage. Therefore, always leave margin on the voltage rating to ensure adequate capacitance at the required output voltage. It is recommended to use the output capacitor with effective capacitance in the range of 10μF to 22μF. The output capacitor affects the small signal control loop stability of the boost regulator. If the output capacitor is below the range, the boost regulator can potentially become unstable. Increasing the output capacitor makes the output voltage ripple smaller in PWM mode. For input capacitor, a ceramic capacitor with more than 1.0μF is enough for most applications. Diode Selection A Schottky diode should be used for the output diode. The forward current rating of the diode should be higher than the load current, and the reverse voltage rating must be higher than the output voltage. Do not use ordinary rectifier diodes, since slow switching speeds and long recovery times cause the efficiency and the load regulation to suffer. 上海洺太电子科技有限公司 -9- SUNTEK MICRO LTD Layout Guidelines PC board layout is an important part of DC-DC converter design. Poor board layout can disrupt the performance of a DC-DC converter and surrounding circuitry by contributing to EMI, ground bounce, and resistive voltage loss in the traces. These can send erroneous signals to the DC-DC converter resulting in poor regulation or instability. Good layout can be implemented by following a few simple design rules. 1. Minimize area of switched current loops. In a buck regulator there are two loops where currents are switched rapidly. The first loop starts from the CIN input capacitor, to the regulator VIN terminal, to the regulator SW terminal, to the inductor then out to the output capacitor COUT and load. The second loop starts from the output capacitor ground, to the regulator GND terminals, to the inductor and then out to COUT and the load. To minimize both loop areas the input capacitor should be placed as close as possible to the VIN terminal. Grounding for both the input and output capacitors should consist of a small localized topside plane that connects to GND. The inductor should be placed as close as possible to the SW pin and output capacitor. 2. Minimize the copper area of the switch node. The SW terminals should be directly connected with a trace that runs on top side directly to the inductor. To minimize IR losses this trace should be as short as possible and with an enough width. However, a trace that is wider than 100 mils will increase the copper area and cause too much capacitive loading on the SW terminal. The inductors should be placed as close as possible to the SW terminals to further minimize the copper area of the switch node. 3. Have a single point ground for all device analog grounds. The ground connections for the feedback components should be connected then routed to the GND pin of the device. This prevents any switched or load currents from flowing in the analog ground plane. If not properly handled, poor grounding can result in degraded load regulation or erratic switching behavior. 4. Minimize trace length to the FB terminal. The feedback trace should be routed away from the SW pin and inductor to avoid contaminating the feedback signal with switch noise. 5. Make input and output bus connections as wide as possible. This reduces any voltage drops on the input or output of the converter and can improve efficiency. If voltage accuracy at the load is important make sure feedback voltage sense is made at the load. Doing so will correct for voltage drops at the load and provide the best output accuracy. Top Layer Bottom Layer Sample Board Layout 上海洺太电子科技有限公司 - 10 - SUNTEK MICRO LTD Package Description:SOT23-6 Unit: mm Symbol Dimensions In Millimeters Min Typ Max A 2.80 2.90 3.00 B 2.60 2.80 B1 1.50 C Symbol Dimensions In Millimeters Min Typ Max L3 1.800 1.900 2.000 3.00 L4 0.077 0.127 0.177 1.60 1.70 L5 - 0.250 - - - 1.05 L6 - 0.600 - C1 0.60 0.80 1.00 θ 0° C2 0.35 0.40 0.45 Θ1 10° 12° 14° C4 0.223 0.273 0.323 Θ2 10° 12° 14° K 0.000 0.075 0.150 R - 0.100 - L 0.325 0.400 0.475 R1 - 0.100 - L1 0.325 0.450 0.550 R2 - 0.100 - L2 0.850 0.950 1.050 0° Note: 1) All dimensions are in millimeters. 2) Package length does not include mold flash, protrusion or gate burr. 3) Package width does not include inter lead flash or protrusion. 4) Lead popularity (bottom of leads after forming) shall be 0.10 millimeters max. 上海洺太电子科技有限公司 - 11 - SUNTEK MICRO LTD
