ASP8120ZC-R
ASP8120ZC-R
    ASCEND(安森德)
    SOT23-6
ASP8120ZC-R 数据手册
ASP8120 18V 2A Synchronous Step-Down Regulator Features General Description • • • • • • • • Wide 4V to 18V Operating Input Range 2A Continuous Output Current 500KHz Switching Frequency Short Protection with Hiccup-Mode Built-in Over Current Limit Built-in Over Voltage Protection Internal Power-Save Mode (PFM/PWM) Internal Soft-Start • 110mΩ/70mΩ Low RDS(ON) Internal Power MOSFETs Output Adjustable from 0.6V No Schottky Diode Required Integrated internal compensation Thermal Shutdown Available in SOT23-6 Package -40°C to +85°C Temperature Range • • • • • • The ASP8120 is a high frequency, synchronous, rectified, step-down, switch-mode converter with internal power MOSFETs. It offers a very compact solution to achieve a 3A peak output current over a wide input supply range, with excellent load and line regulation. The ASP8120 requires a minimal number of readily available, external components and is available in a space saving SOT23-6 package. Applications • • • • Digital Set-top Box (STB) Tablet Personal Computer (Pad) Flat-Panel Television and Monitor Wi-Fi Router / AP • • • • Digital Video Recorder (DVR) Portable Media Player (PMP) Cable Modem / XDSL General Purposes Typical Application Circuit C1 BS VIN IN L1 VOUT SW R1 CFF COUT Opt. CIN ON/ OFF EN FB GND R2 NOV 2018 Version1.0 1/11 Ascend Semicondutor Co.,Ltd ASP8120 18V 2A Synchronous Step-Down Regulator Pin Configuration TOP VIEW BS 1 6 SW GND 2 5 IN FB 3 4 EN SOT23-6 Pin Description Pin Name Function 1 BS Bootstrap. A capacitor connected between SW and BST pins is required to form a floating supply across the high-side switch driver. 2 GND 3 FB Adjustable Version Feedback input. Connect FB to the center point of the external resistor divider 4 EN Drive this pin to a logic-high to enable the IC. Drive to a logic-low to disable the IC and enter micro-power shutdown mode. 5 IN Power Supply Pin 6 SW Switching Pin NOV 2018 Version1.0 GROUND Pin 2/11 Ascend Semicondutor Co.,Ltd ASP8120 18V 2A Synchronous Step-Down Regulator Absolute Maximum Ratings (1) (2) VIN, EN, Voltage …………………... -0.3V to 21V VSW Voltage ...………………...…...…. -0.3V to (VIN+0.5V) VFB Voltages ...………………………… -0.3 to 6V VBS Voltage …...………………...... (Vsw-0.3) to (Vsw+5V) Operating Temperature Range …...-40°C to +85°C Storage Temperature Range ………………. -65°C to 150°C Lead Temperature (Soldering, 10s) ……... +300°C Junction Temperature……….………………...….…+150°C θJA ……….……...……….…………........170°C/W ESD (Human Body Made) HMB……………...……….2KV θJC ……….……...……………...……......110°C/W ESD (Machine Made) MM…………………………... 200V Note1: Exceeding these ratings may damage the device. Note2: The device is not guaranteed to function outside of its operating conditions. Electrical Characteristics (3) (4) VIN =12V, TA = +25ºC, unless otherwise noted. Parameter Test Conditions Input Voltage Range Min Typ. 4 Supply Current in Operation VEN=3.0V, VFB=1.1V Supply Current in Shutdown VEN =0 or EN = GND Regulated Feedback Voltage TJ=-40°C to +125°C 0.4 0.591 0.6 Max Unit 18 V 0.8 mA 10 uA 0.609 V High-Side Switch On-Resistance 110 mΩ Low-Side Switch On-Resistance 70 mΩ High-Side Switch Leakage Current VEN=0V, VSW=0V Upper Switch Current Limit Minimum Duty Cycle 10 uA 3 A 500 kHz 92 % Minimum On-Time 60 nS Minimum Off-Time 90 nS VEN=2V 1 uA VEN=0V 0 uA Oscillation Frequency Maximum Duty Cycle EN Input Current VFB=0.6V VIN Under-Voltage Lockout Threshold INUVTH VIN Under-Voltage Lockout Threshold-Hysteresis INUVHYS EN up Threshold VEN-Rising 3.5 3.8 200 1.05 1.15 V mV 1.25 V EN Threshold Hysteresis 140 mV Soft Start 1.03 mS Hiccup Frequency VOUT = 3.3V, VIN = 12V Hiccup Duty cycle VOUT = 3.3V, VIN = 12V 80 120 Hz 40 % Thermal Shutdown 160 ℃ Thermal Hysteresis 20 ℃ Note3: MOSFET on-resistance specifications are guaranteed by correlation to wafer level measurements. Note4: Thermal shutdown specifications are guaranteed by correlation to the design and characteristics analysis. NOV 2018 Version1.0 3/11 Ascend Semicondutor Co.,Ltd ASP8120 18V 2A Synchronous Step-Down Regulator Typical Performance Characteristics (5) (6) Note 5: Performance waveforms are tested on the evaluation board. Note 6: VIN =12V, VOUT=3.3V, TA = +25ºC, unless otherwise noted. Efficiency vs Load Current Load Regulation Line Regulation VOUT = 3.3V VOUT = 3.3V VOUT = 3.3V Output Ripple Voltage Output Ripple Voltage Output Ripple Voltage VIN = 12V, VOUT = 3.3V, IOUT = 0A VIN = 12V, VOUT = 3.3V, IOUT = 1.0A VIN = 12V, VOUT = 3.3V, IOUT = 2.0A Loop Response Hiccup with Output Short Short Circuit Entry VIN = 12V, VOUT = 3.3V, IOUT = 1.0A-2.0A VIN = 12V, VOUT = 3.3V VIN = 12V, VOUT = 3.3V NOV 2018 Version1.0 4/11 Ascend Semicondutor Co.,Ltd ASP8120 18V 2A Synchronous Step-Down Regulator Short Circuit Recovery Enable Startup at No Load Enable Shutdown at No Load VIN = 12V, VOUT = 3.3V VIN = 12V, VOUT = 3.3V, IOUT = 0A VIN = 12V, VOUT = 3.3V, IOUT = 0A Enable Startup at Full Load Enable Shutdown at Full Load Power Up at No Load VIN = 12V, VOUT = 3.3V, IOUT = 2.0A VIN = 12V, VOUT = 3.3V, IOUT = 2.0A VIN = 12V, VOUT = 3.3V, IOUT = 0A Power Up at Full Load VIN = 12V, VOUT = 3.3V, IOUT = 2.0A NOV 2018 Version1.0 5/11 Ascend Semicondutor Co.,Ltd ASP8120 18V 2A Synchronous Step-Down Regulator Functional Block Diagram IN + RSEN VCC REGULATOR - VCC CURRENT S ENSE AMP LIFIER B OOS T REGULATOR BS OS CI LLA TOR HS DRIVER + COM PARATOR - SW VCC REFERENCE EN ON TIM E CO NTROL CURRENT LIM IT COM PARATOR 1pF 1M 56 pF LOGI C CO NTROL 40 0k LS DRIVER + + FB GND ERROR AM PLIFIER Figure 2. ASP8120 Block Diagram Functions Description Internal Regulator The ASP8120 is a current mode step down DC/DC converter that provides excellent transient response with no extra external compensation components. This device contains an internal, low resistance, high voltage power MOSFET, and operates at a high 500KHz operating frequency to ensure a compact, high efficiency design with excellent AC and DC performance. Error Amplifier The error amplifier compares the FB pin voltage with the internal FB reference (VFB) and outputs a current proportional to the difference between the two. This output current is then used to charge or discharge the internal compensation network, which is used to control the power MOSFET current. The optimized internal compensation network minimizes the external component counts and simplifies the control loop design. Internal Soft-Start The soft-start is implemented to prevent the converter output voltage from overshooting during startup. When the chip starts, the internal circuitry generates a soft-start voltage (SS) ramping up from 0V to 0.6V. When it is lower than the internal reference (REF), SS overrides REF so the error amplifier uses SS as the reference. When SS is higher than REF, REF regains control. The SS time is internally max to 1.2ms. Over Current Protection & Hiccup The ASP8120 has cycle-by-cycle over current limit when the inductor current peak value exceeds the set current limit threshold. Meanwhile, output voltage starts to drop until FB is below the Under-Voltage (UV) threshold, typically 25% below the reference. Once a UV is triggered, the ASP8120 enters hiccup mode to periodically restart the part. This protection mode is especially useful when the output is dead-short to ground. The average short circuit NOV 2018 Version1.0 6/11 Ascend Semicondutor Co.,Ltd ASP8120 18V 2A Synchronous Step-Down Regulator current is greatly reduced to alleviate the thermal issue and to protect the regulator. The ASP8120 exits the hiccup mode once the over current condition is removed. Startup and Shutdown If both VIN and EN are higher than their appropriate thresholds, the chip starts. The reference block starts first, generating stable reference voltage and currents, and then the internal regulator is enabled. The regulator provides stable supply for the remaining circuitries. Three events can shut down the chip: EN low, VIN low and thermal shutdown. In the shutdown procedure, the signaling path is first blocked to avoid any fault triggering. The comp voltage and the internal supply rail are then pulled down. The floating driver is not subject to this shutdown command. Applications Information Setting the Output Voltage ASP8120 require an input capacitor, an output capacitor and an inductor. These components are critical to the performance of the device. ASP8120 are internally compensated and do not require external components to achieve stable operation. The output voltage can be programmed by resistor divider. 𝑉𝑂𝑈𝑇 = 𝑉𝐹𝐵 × 𝑅1 + 𝑅2 𝑅2 VOUT(V) R1(KΩ) R2(KΩ) L1(μH) C1(nF) CIN(μF) COUT(μF) CFF(pF) Opt. 1.0 6.67 10 1.5 22-100 22 22×2 100-220 1.05 7.50 10 1.5 22-100 22 22×2 100-220 1.2 10.00 10 1.5 22-100 22 22×2 100-220 1.5 15.00 10 1.5 22-100 22 22×2 100-220 1.8 20.00 10 2.2 22-100 22 22×2 100-220 2.5 31.67 10 2.2 22-100 22 22×2 100-220 3.3 45.00 10 3.3 22-100 22 22×2 100-220 5.0 73.33 10 4.7 22-100 22 22×2 100-220 Selecting the Inductor The recommended inductor values are shown in the Application Diagram. It is important to guarantee the inductor core does not saturate during any foreseeable operational situation. The inductor should be rated to handle the peak load current plus the ripple current: Care should be taken when reviewing the different saturation current ratings that are specified by different manufacturers. Saturation current ratings are typically specified at 25°C, so ratings at maximum ambient temperature of the application should be requested from the manufacturer. 𝐿= 𝑉𝑂𝑈𝑇 × (𝑉𝐼𝑁 − 𝑉𝑂𝑈𝑇 ) 𝑉𝐼𝑁 × ∆𝐼𝐿 × 𝐹𝑂𝑆𝐶 Where ΔIL is the inductor ripple current. Choose inductor ripple current to be approximately 30% if the maximum load current. The maximum inductor peak current is: NOV 2018 Version1.0 7/11 Ascend Semicondutor Co.,Ltd ASP8120 18V 2A Synchronous Step-Down Regulator 𝐼𝐿(𝑀𝐴𝑋) = 𝐼𝐿𝑂𝐴𝐷 + ∆𝐼𝐿 2 Under light load conditions below 100mA, larger inductance is recommended for improved efficiency. Selecting the Output Capacitor Special attention should be paid when selecting these components. The DC bias of these capacitors can result in a capacitance value that falls below the minimum value given in the recommended capacitor specifications table. The ceramic capacitor’s actual capacitance can vary with temperature. The capacitor type X7R, which operates over a temperature range of −55°C to +125°C, will only vary the capacitance to within ±15%. The capacitor type X5R has a similar tolerance over a reduced temperature range of −55°C to +85°C. Many large value ceramic capacitors, larger than 1uF are manufactured with Z5U or Y5V temperature characteristics. Their capacitance can drop by more than 50% as the temperature varies from 25°C to 85°C. Therefore X5R or X7R is recommended over Z5U and Y5V in applications where the ambient temperature will change significantly above or below 25°C. Tantalum capacitors are less desirable than ceramic for use as output capacitors because they are more expensive when comparing equivalent capacitance and voltage ratings in the 0.47uF to 44uF range. Another important consideration is that tantalum capacitors have higher ESR values than equivalent size ceramics. This means that while it may be possible to find a tantalum capacitor with an ESR value within the stable range, it would have to be larger in capacitance (which means bigger and more costly) than a ceramic capacitor with the same ESR value. It should also be noted that the ESR of a typical tantalum will increase about 2:1 as the temperature goes from 25°C down to −40°C, so some guard band must be allowed. PC Board Layout Consideration PCB layout is very important to achieve stable operation. It is highly recommended to duplicate EVB layout for optimum performance. If change is necessary, please follow these guidelines for reference. 1. Keep the path of switching current short and minimize the loop area formed by Input capacitor, high-side MOSFET and low-side MOSFET. 2. Bypass ceramic capacitors are suggested to be put close to the Vin Pin. 3. Ensure all feedback connections are short and direct. Place the feedback resistors and compensation components as close to the chip as possible. 4. VOUT, SW away from sensitive analog areas such as FB. 5. Connect IN, SW, and especially GND respectively to a large copper area to cool the chip to improve thermal performance and long-term reliability. NOV 2018 Version1.0 8/11 Ascend Semicondutor Co.,Ltd ASP8120 18V 2A Synchronous Step-Down Regulator Ordering and Marking Information Device Package Packing SOT23-6 Tape Reel AS38120 Quantity 00 MARKING PACKAGE SOT23-6 BCYLL Top Marking: BCYLL (device code: BC, Y=year code, LL= lot number code) Ordering Information Halogen Free Lead Free ASP8120-ZC-R ASP8120G-ZC-R Package SOT23-6 1 R:Tape Reel ASP8120G-ZC-R 2 ZC: SOT23-6 3 blank : Lead Free 1 Packing Type G:Halogen Free 2 Package Type 3 Halogen Free NOV 2018 Version1.0 9/11 Ascend Semicondutor Co.,Ltd ASP8120 18V 2A Synchronous Step-Down Regulator Symbol A A1 A2 b C D E e e1 H L θ Dimensions in Millimeters Min Max 1.00 1.25 0.00 0.10 1.00 1.15 0.30 0.55 0.08 0.20 2.70 3.10 1.40 1.80 0.95 TYP 1.90 TYP 2.80 3.00 0.30 0.60 0∘ 8∘ NOV 2018 Version1.0 Dimensions in Inches Min Max 0.039 0.049 0.000 0.004 0.039 0.045 0.012 0.022 0.003 0.008 0.106 0.122 0.055 0.071 0.037 TYP 0.075 TYP 0.110 0.118 0.012 0.024 0∘ 8∘ 10/11 Q'ty / Reel 3000pcs Reel Size 7" Ascend Semicondutor Co.,Ltd ASP8120 18V 2A Synchronous Step-Down Regulator IMPORTANT NOTICE Xi‘an Ascend Semiconductor incorporated MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARDS TO THIS DOCUMENT, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION). Xi‘an Ascend Semiconductor Incorporated and its subsidiaries reserve the right to make modifications, enhancements, improvements, corrections or other changes without further notice to this document and any product described herein. Xi‘an Ascend Semiconductor Incorporated does not assume any liability arising out of the application or use of this document or any product described herein; neither does Xi‘an Ascend Semiconductor Incorporated convey any license under its patent or trademark rights, nor the rights of others. Any Customer or user of this document or products described herein in such applications shall assume all risks of such use and will agree to hold Ascendsemi Incorporated and all the companies whose products are represented on Xi‘an Ascend Semiconductor Incorporated website, harmless against all damages. Xi‘an Ascend Semiconductor Incorporated does not warrant or accept any liability whatsoever in respect of any products purchased through unauthorized sales channel. Should Customers purchase or use Xi‘an Ascend Semiconductor Incorporated products for any unintended or unauthorized application, Customers shall indemnify and hold Xi‘an Ascend Semiconductor Incorporated and its representatives harmless against all claims, damages, expenses, and attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized application. www.ascendsemi.com NOV 2018 Version1.0 11/11 Ascend Semicondutor Co.,Ltd
ASP8120ZC-R
物料型号:ASP8120
器件简介:ASP8120是一款18V 2A同步降压调节器,具有4V至18V的宽输入电压范围,可提供高达3A的峰值输出电流,具有出色的负载和线路调节性能。
引脚分配:ASP8120采用SOT23-6封装,具有6个引脚,包括开关(SW)、自举(BS)、地(GND)、反馈(FB)、使能(EN)和电源输入(IN)。
参数特性: - 工作频率:500kHz - 输入电压范围:4V至18V - 输出可调:0.6V起 - 内部软启动 - 热关断保护 - 过压保护 - 过流限制和hiccup模式 - 内部功率MOSFET的低RDS(ON):110mΩ/70mΩ - 工作温度范围:-40°C至+85°C
功能详解: - 内部补偿 - 无需外部肖特基二极管 - 集成的电源节省模式(PFM/PWM) - 集成的内部补偿 - 短路保护
应用信息:适用于数字机顶盒、平板电脑、液晶电视/监视器、Wi-Fi路由器/AP、数字视频录像机、便携式媒体播放器、电缆调制解调器/XDSL等。
封装信息:ASP8120采用SOT23-6封装,具有紧凑的尺寸,适用于空间受限的应用。
ASP8120ZC-R 价格&库存
很抱歉,暂时无法提供与“ASP8120ZC-R”相匹配的价格&库存,您可以联系我们找货
