BZT52CXXX
Rev.G Apr.-2018
DATA SHEET
Descriptions
SOD-123 塑封封装 稳压二极管。
Zener Diode in a SOD-123 Plastic Package.
特征
/ Features
500mW 功耗,中等电流,自动贴片组装。无卤产品。
500mW power dissipation, medium current, automated assembly processes. HF Product.
用途
Applications
适用于 2.4V-39V 的宽范围稳压电路。
2.4V to 39V wide zener voltage range applications.
内部等效电路
引脚排列
/ Equivalent Circuit
/ Pinning
1
2
PIN1:Cathode
放大及印章代码
PIN2:Anode
/ hFE Classifications & Marking
见电性能参数。See Electrical Characteristics.
http://www.fsbrec.com
1/7
BZT52CXXX
Rev.G Apr.-2018
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
符号
Symbol
数值
Rating
单位
Unit
Forward Voltage (Note 2) ( IF=10mA)
VF
0.9
V
Power Dissipation(Note 1)
PD
500
mW
RθJA
305
℃/W
Tj,Tstg
-65~150
Typical Thermal Resistance Junction to
Ambient
Junction and Storage Temperature
Range
电性能参数
Type Number
/ Electrical Characteristics(Ta=25℃)
Mark
-ing
Code
Zener Voltage Range
(Note 2)
Vz @IZT
IZT
Nom
(V)
Min
(V)
Max
(V)
mA
Maximum Zener
mpedance (Note 3)
Maximum
Reverse
Current
(Note 2)
ZZT
@IZT
IZK
IR
@VR
mA
uA
V
Min
Max
mA
ZZK
@IZK
Ω
Typical
Temperature
Coefficient
@IZTC
mV/ºC
Test
Curre
nt IZTC
BZT52C2V4
HWX
2.4
2.2
2.6
5
100
600
1
50
1
-3.5
BZT52C2V7
HW1
2.7
2.5
2.9
5
100
600
1
-3.5
BZT52C3V0
HW2
3.0
2.8
3.2
5
95
600
1
10
1
-3.5
BZT52C3V3
HW3
3.3
3.1
3.5
5
95
600
1
5
1
-3.5
BZT52C3V6
HW4
3.6
3.4
3.8
5
90
600
1
5
1
-3.5
BZT52C3V9
HW5
3.9
3.7
4.1
5
90
600
1
3
1
-3.5
BZT52C4V3
HW6
4.3
4
4.6
5
90
600
1
3
1
-3.5
BZT52C4V7
HW7
4.7
4.4
5
5
80
500
1
3
2
-3.5
0.2
5
BZT52C5V1
HW8
5.1
4.8
5.4
5
60
480
1
2
2
-2.7
1.2
5
BZT52C5V6
HW9
5.6
5.2
6
5
40
400
1
1
2
-2
2.5
5
BZT52C6V2
HWA
6.2
5.8
6.6
5
10
150
1
3
4
0.4
3.7
5
BZT52C6V8
HWB
6.8
6.4
7.2
5
15
80
1
2
4
1.2
4.5
5
BZT52C7V5
HWC
7.5
7
7.9
5
15
80
1
1
5
2.5
5.3
5
BZT52C8V2
HWD
8.2
7.7
8.7
5
15
80
1
0.7
5
3.2
6.2
5
BZT52C9V1
HWE
9.1
8.5
9.6
5
15
100
1
0.5
6
3.8
7
5
BZT52C10
HWF
10
9.4
10.6
5
1
0.2
7
4.5
8
5
2/7
BZT52CXXX
Rev.G Apr.-2018
电性能参数
Type
Number
DATA SHEET
Zener Voltage Range
(Note 2)
Marki
ng
Code
Vz @IZT
IZT
Nom
(V)
Min
(V)
Max
(V)
mA
Maximum Zener
mpedance (Note 3)
Maximum
Reverse
Current
(Note 2)
ZZT
@IZT
IZK
IR
@VR
mA
uA
V
Min
Max
mA
ZZK
@IZK
Ω
Typical
Temperature
Coefficient
@IZTC
mV/ºC
Test
Curre
nt IZTC
BZT52C11
HWG
11
10.4
11.6
5
1
0.1
8
5.4
9
5
BZT52C12
HWH
12
11.4
12.7
5
25
150
1
0.1
8
6
10
5
BZT52C13
HWI
13
12.4
14.1
5
30
170
1
0.1
8
7
11
5
BZT52C15
HWJ
15
13.8
15.6
5
30
200
1
0.1
10.5
9.2
13
5
BZT52C16
HWK
16
15.3
17.1
5
40
200
1
0.1
11.2
10.4
14
5
BZT52C18
HWL
18
16.8
19.1
5
45
225
1
0.1
12.6
12.4
16
5
BZT52C20
HWM
21.2
5
55
225
1
0.1
14
14.4
18
5
BZT52C22
HWN
22
20.8
23.3
5
55
250
1
0.1
15.4
16.4
BZT52C24
HWO
24
22.8
25.6
5
70
250
1
0.1
16.8
18.4
22
5
BZT52C27
HWP
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
2
BZT52C30
HWQ
30
28
32
2
80
300
0.5
0.1
21
24.4
29.4
2
BZT52C33
HWR
33
31
35
2
80
325
0.5
0.1
23.1
27.4
33.4
2
BZT52C36
HWS
36
34
38
2
90
350
0.5
0.1
25.2
30.4
37.4
2
BZT52C39
HWT
39
37
41
2
130
350
0.5
0.1
27.3
33.4
41.2
2
Notes:
1. Device mounted on ceramic PCB; 7.6mm x 9.4mm x 0.87mm with pad areas 25mm2.
2. Short duration test pulse used to minimize self-heating effect.
3. f = 1kHz.
3/7
BZT52CXXX
Rev.G Apr.-2018
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
4/7
BZT52CXXX
Rev.G Apr.-2018
外形尺寸图
DATA SHEET
/ Package Dimensions
5/7
BZT52CXXX
Rev.G Apr.-2018
印章说明
DATA SHEET
Marking Instructions
HWX
说明:
H:
为公司代码
WX:
为型号代码
Note:
H:
Company Code.
WX:
Product Type.
6/7
BZT52CXXX
Rev.G Apr.-2018
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 150~180℃,时间 60~90sec;
1.Preheating:150~180℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SOD-123
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3,000
10
30,000
6
180,000
7〞×8
180×120×180
390×385×205
/ Notices
7/7
很抱歉,暂时无法提供与“BZT52C15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10703
- 500+0.08403
- 3000+0.07118
- 6000+0.06351
- 24000+0.05681
- 51000+0.05325
