MMSZ27VBW
MMSZ27VBW
    TC(德昌)
    SOD-123
    27V 500mW
MMSZ27VBW 数据手册
SEMICONDUCTOR 500mW SOD-123 SURFACE MOUNT Green Product Flat Lead Surface Mount Plastic Package Zener Voltage Regulators Absolute Maximum Ratings Symbol PD TA = 25°C unless otherwise noted Parameter Power Dissipation Value Units 500 mW TSTG Storage Temperature Range -65 to +150 °C TOPR Operating Temperature Range -65 to +150 °C These ratings are limiting values above which the serviceability of the diode may be impaired. SOD-123 Flat Lead Specification Features: ƒ ƒ ƒ ƒ ƒ ƒ ƒ ƒ Wide Zener Voltage Range Selection, 2.0V to 75V VZ Tolerance Selection of ±2% (B Series) Flat Lead SOD-123 Plastic Package Cathode Surface Device Type Mounting Anode ELECTRICAL SYMBOL RoHS Compliant Green EMC Matte Tin(Sn) Lead Finish Band Indicates Cathode Electrical Characteristics Device Type Device Marking MMSZ2V0BW MMSZ2V2BW MMSZ2V4BW MMSZ2V7BW MMSZ3V0BW MMSZ3V3BW MMSZ3V6BW MMSZ3V9BW MMSZ4V3BW MMSZ4V7BW MMSZ5V1BW MMSZ5V6BW MMSZ6V2BW MMSZ6V8BW MMSZ7V5BW MMSZ8V2BW MMSZ9V1BW MMSZ10VBW MMSZ11VBW MMSZ12VBW MMSZ13VBW MMSZ15VBW 2V0B 2V2B 2V4B 2V7B 3V0B 3V3B 3V6B 3V9B 4V3B 4V7B 5V1B 5V6B 6V2B 6V8B 7V5B 8V2B 9V1B 10VB 11VB 12VB 13VB 15VB TA = 25°C unless otherwise noted VZ @ IZT (Volts) Min Nom Max 1.95 2.14 2.35 2.65 2.94 3.23 3.53 3.82 4.21 4.61 5.00 5.49 6.08 6.66 7.35 8.04 8.92 9.80 10.78 11.76 12.74 14.70 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 13 15 2.05 2.26 2.45 2.75 3.06 3.37 3.67 3.98 4.39 4.79 5.20 5.71 6.32 6.94 7.65 8.36 9.28 10.20 11.22 12.24 13.26 15.30 IZT (mA) ZZT @ IZT (Ω) Max IZK (mA) ZZK @ IZK (Ω) Max IR @ VR (μA) Max VR (Volts) 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 100 100 100 100 100 95 90 90 90 80 60 40 10 15 15 15 15 20 20 25 30 30 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 564 564 564 564 564 564 564 564 564 470 451 376 141 75 75 75 94 141 141 141 160 188 120 120 45 18 9 4.5 4.5 2.7 2.7 2.7 1.8 0.9 2.7 1.8 0.9 0.63 0.45 0.18 0.09 0.09 0.09 0.045 0.5 0.7 1 1 1 1 1 1 1 2 2 2 4 4 5 5 6 7 8 8 8 10.5 Number: DB-086 January 2013, Revision E Page 1 MMSZ2V0BW through MMSZ75VBW ® TAK CHEONG ® TAK CHEONG SEMICONDUCTOR Electrical Characteristics TA = 25°C unless otherwise noted VZ @ IZT (Volts) IZT (mA) ZZT @ IZT (Ω) Max IZK (mA) ZZK @ IZK (Ω) Max IR @ VR (μA) Max VR (Volts) 16.32 18.36 20.40 5 5 5 40 45 55 1 1 1 188 212 212 0.045 0.045 0.045 11.2 12.6 14.0 22 22.44 5 55 1 235 0.045 15.4 24 24.48 5 70 1 235 0.045 16.8 26.46 27 27.54 2 80 0.5 282 0.045 18.9 30VB 29.40 30 30.60 2 80 0.5 282 0.045 21.0 33VB 32.34 33 33.66 2 80 0.5 306 0.045 23.0 MMSZ36VBW 36VB 35.28 36 36.72 2 90 0.5 329 0.045 25.2 MMSZ39VBW 39VB 38.22 39 39.78 2 130 0.5 329 0.045 27.3 MMSZ43VBW 43VB 42.14 43 43.86 2 150 0.5 353 0.045 30.1 MMSZ47VBW 47VB 46.06 47 47.94 2 170 0.5 353 0.045 33.0 MMSZ51VBW 51VB 49.98 51 52.02 2 180 0.5 376 0.045 35.7 MMSZ56VBW 56VB 54.88 56 57.12 2 200 0.5 400 0.045 39.2 MMSZ62VBW 62VB 60.76 62 63.24 2 215 0.5 423 0.045 43.4 MMSZ68VBW 68VB 66.64 68 69.36 2 240 0.5 447 0.045 47.6 MMSZ75VBW 75VB 73.50 75 76.50 2 255 0.5 470 0.045 52.5 Device Type Device Marking Min Nom Max MMSZ16VBW MMSZ18VBW MMSZ20VBW 16VB 18VB 20VB 15.68 17.64 19.60 16 18 20 MMSZ22VBW 22VB 21.56 MMSZ24VBW 24VB 23.52 MMSZ27VBW 27VB MMSZ30VBW MMSZ33VBW VF Forward Voltage = 900mV Maximum @ IF = 10 mA for all types Notes: 1. 2. 3. 4. The Zener Voltage (VZ) is tested under pulse condition of 10mS. The device numbers listed have a standard tolerance on the nominal zener voltage of ±2%. For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Tak Cheong Electronics representative. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an rms value equal to 10% of the dc zener current (IZT or IZK) is superimposed to IZT or IZK. Number: DB-086 January 2013, Revision E Page 2 ® TAK CHEONG SEMICONDUCTOR RATING AND CHARACTERISTIC CURVES Fig.2 EFFECT OF ZENER VOLTAGE ON ZENER IMPEDANCE Fig.1 TYPICAL FORWARD VOLTAGE POWER PASSIPATION,mW 600 500 400 300 200 100 0 0 25 50 75 100 125 150 175 200 TEMPERATURE [℃ ] Fig.3 POWER DISSIPATION VS. AMBIENT TEMP. Fig.5 ZENER BREAKDOWN CHARACTERISTICS Fig.4 TYPICAL CAPACITANCE Fig.6 ZENER BREAKDOWN CHARACTERISTICS Number: DB-086 January 2013, Revision E Page 3 ® TAK CHEONG SEMICONDUCTOR Fig.7 TYPICAL LEAKGE CURRENT Flat Lead SOD-123 Package Outline Note: Dimensions are exclusive of Burrs, Mold Flash & Tie Bar extrusions. Number: DB-086 January 2013, Revision E Page 4 TAK CHEONG ® DISC LA I MER NOTIC E NOTICE The information presented in this document is for reference only. Tak Cheong reserves the right to make changes without notice for the specification of the products displayed herein. The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Tak Cheong Semiconductor Co., Ltd., or anyone on its behalf, assumes no responsibility or liability for any damagers resulting from such improper use of sale. This publication supersedes & replaces all information reviously supplied. For additional information, please visit our website http://www.takcheong.com, or consult your nearest Tak Cheong’s sales office for further assistance. Number: DB-100 April 14, 2008 / A
MMSZ27VBW 价格&库存
很抱歉,暂时无法提供与“MMSZ27VBW”相匹配的价格&库存,您可以联系我们找货
MMSZ27VBW
    • 10+0.08060
    • 100+0.07626
    • 1000+0.07316
    库存:8395
