DFR1A THRU DFR1M
1.0A Surface Mount Fast
Recovery Rectifiers-50-1000V
Package outline
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
260 C/10 seconds at terminals
Glass passivated chip junction
1.8± 0.2
1.0±0.2
SOD-123
1.1± 0.25
0.10-0.30
2.7±0.2
0.6±0.25
Mechanical data
Case: JEDEC SOD-123 molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
3.7±0.2
Dimensions in inches and (millimeters)
Maximum ratings and Electrical Characteristics (AT
PARAMETER
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
0.375”(9.5mm) lead length at TA=75 C
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Maximum reverse recovery time
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
Operating junction and storage temperature range
T A=25 oC unless otherwise noted)
SYMBOLS DFR1A DFR1B DFR1D DFR1G DFR1J DFR1K DFR1M
VRRM
VRMS
VDC
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
I(AV)
1.0
A
IFSM
25.0
A
VF
1.3
V
IR
5.0
50.0
µA
trr
150
250
15.0
85.0
-55 to +150
CJ
RθJA
TJ,TSTG
500
ns
pF
C/W
C
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
www.fuxinsemi.com
Page 1
Ver2.1
DFR1A THRU DFR1M
Rating and characteristic curves
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
10
3.0
1.0
1.2
1.0
0.8
0.6
0.4
0.2
TJ=25 C
60
80
100
120
140
160
180
200
LEAD TEMPERATURE (°C)
Pulse Width 300us
1% Duty Cycle
0.1
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
.01
.6
.8
1.0
1.2
1.4
1.6
1.8
2.0
FORWARD VOLTAGE,(V)
FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERISTICS
50W
NONINDUCTIVE
10W
NONINDUCTIVE
D.U.T.
25Vdc
(approx.)
PEAK FORWAARD SURGE CURRENT,(A)
INSTANTANEOUS FORWARD CURRENT,(A)
50
PULSE
GENERATOR
(NOTE 2)
50
40
30
8.3ms Single Half
TJ=25 C
JEDEC method
10
5
50
10
100
NUMBER OF CYCLES AT 60Hz
1W
NONINDUCTIVE
Sine Wave
OSCILLISCOPE
(NOTE 1)
FIG.5-TYPICAL JUNCTION CAPACITANCE
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
JUNCTION CAPACITANCE,(pF)
trr
+0.5A
-0.25A
30
25
10
5
-1.0A
1cm
.01
SET TIME BASE FOR
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
50 / 10ns / cm
www.fuxinsemi.com
Page 2
Ver2.1
DFR1A THRU DFR1M
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
1
Symbol
2
1
2
Marking
Type number
Marking code
DFR1A
DFR1B
DFR1D
DFR1G
DFR1J
DFR1K
DFR1M
F1
F2
F3
F4
F5
F6
F7
Suggested solder pad layout
C
A
B
www.fuxinsemi.com
PACKAGE
A
B
C
SOD-123
0.075 (1.90)
0.055 (1.40)
0.075 (1.90)
Page 3
Ver2.1
DFR1A THRU DFR1M
Suggested thermal profiles for soldering processes
1.Storage environment: Temperature=5 oC ~40 oC Humidity=55%±25%
2.Reflow soldering of surface-mount devices
Critical Zone
TL to TP
Tp
TP
Ramp-up
TL
TL
Tsmax
Temperature
Tsmin
tS
Preheat
Ramp-down
25
o
t25 C to Peak
Time
3.Reflow soldering
Profile Feature
Soldering Condition
Average ramp-up rate(T L to T P )
o
很抱歉,暂时无法提供与“DFR1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.20240
- 200+0.06754
- 1500+0.04213
- 3000+0.03344
- 国内价格
- 20+0.08338
- 200+0.06707
- 600+0.05800
- 3000+0.05098
- 9000+0.04623
- 21000+0.04364
