SAS14-M
SAS14-M
    ANBON(安邦)
    SOD-123
    耐压:200V 电流:1A 反向恢复时间:35NS
SAS14-M 数据手册
SAS11-M THRU SAS18-M 1.0A Surface Mount Super Fast Rectifiers-50-600V Package outline Features • Batch process design, excellent power dissipation offers • • • • • • • SOD-123 better reverse leakage current and thermal resistance Tiny plastic SMD package High current capability Superfast recovery time for switching mode application High surge current capability Glass passivated chip junction Lead-free parts meet RoHS requirements Suffix "-H" indicates Halogen free parts, ex. SAS11-M-H 0.154(3.9) 0.138(3.5) 0.012(0.3) Typ. 0.075(1.9) 0.060(1.5) Mechanical data • Epoxy : UL94-V0 rated flame retardant • Case : Molded plastic, SOD-123 / MINI SMA • Terminals :Plated terminals, solderable per MIL-STD-750, 0.067(1.7) 0.051(1.3) Method 2026 • Polarity : Indicated by cathode band • Mounting Position : Any • Weight : Approximated 0.018 gram 0.028(0.7) Typ. 0.028(0.7) Typ. Dimensions in inches and (millimeters) Maximum ratings (AT T A =25 o C unless otherwise noted) SYMBOLS SAS11-M SAS12-M SAS13-M SAS14-M Maximum repetitive peak reverse voltage VRRM 50 100 150 200 300 Maximum RMS voltage VRMS 35 70 105 140 Maximum continuous reverse voltage VR 50 100 150 200 Maximum average forward rectified current IO 1.0 A Non-repetitive peak forward surge current 8.3ms single half sine-wave IFSM 25 A Typical junction capacitance (Note 1) CJ 10 pF Operating junction temperature range TJ -55 to +150 °C Storage temperature range TSTG -65 to +175 °C PARAMETER Electrical characteristics (AT PARAMETER SYMBOLS SAS15-M SAS16-M SAS17-M SAS18-M 400 500 600 V 210 280 350 420 V 300 400 500 600 V UNIT o T A =25 C unless otherwise noted) SAS11-M SAS12-M SAS13-M SAS14-M SAS15-M SAS16-M SAS17-M SAS18-M UNIT Maximum instantaneous forward voltage at I F=1.0A VF Maximum reverse leakage current T J =25 ° C at rated V R T J =125 ° C IR 5.0 100 μA μA Maximum reverse recovery time (Note 2) trr 35 ns 1.25 0.95 V 1.70 Thermal characteristics PARAMETER Typical thermal resistance junction to ambient (3) Typical thermal resistance junction to case(3) SYMBOLS SAS11-M SAS12-M SAS13-M RθJA RθJC SAS14-M SAS15-M SAS16-M SAS17-M SAS18-M UNIT °C/W ° C/W 56 41 Notes 1: Measured at 1 MHz and applied reverse voltage of 4.0 VDC 2: Measured with IF = 0.5 A, IR = 1 A, Irr = 0.25 A 3: Mounted on FR-4 PCB Copper, minimum recommended pad layout Page 1 Document ID Issued Date Revised Date AS-121401 2008/02/10 2012/10/29 Revision E Page. 3 Rating and characteristic curves (SAS11-M THRU SAS18-M) FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE FIG.1-TYPICAL FORWARD CHARACTERISTICS AVERAGE FORWARD CURRENT,(A) 16 AS ~S M 5- 18 -M S1 SA S1 7- M ~S AS SA 1.0 -M ~S AS 14 -M SA S1 1-M .1 1.2 1.0 0.8 0.6 P.C.B. Mounted on 0.2"x0.2" (5.0 mm x 5.0 mm) Copper Pad Areas 0.4 0.2 0 0 25 50 75 100 125 150 175 LEAD TEMPERATURE (°C) TJ=25 C Pulse Width 300us 1% Duty Cycle .01 .6 .8 1.0 1.2 1.4 1.6 1.8 FORWARD VOLTAGE,(V) FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTICS 50W NONINDUCTIVE 10W NONINDUCTIVE ( ) (+) D.U.T. 25Vdc (approx.) PULSE GENERATOR (NOTE 2) ( ) PEAK FORWAARD SURGE CURRENT,(A) .001 .4 FIG.4-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 50 40 30 8.3ms Single Half TJ=25 C Sine Wave 20 JEDEC method 10 0 1 5 (+) 1W NONINDUCTIVE 50 10 100 NUMBER OF CYCLES AT 60Hz OSCILLISCOPE (NOTE 1) NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF. 2. Rise Time= 10ns max., Source Impedance= 50 ohms. FIG.5-TYPICAL JUNCTION CAPACITANCE 70 trr JUNCTION CAPACITANCE,(pF) INSTANTANEOUS FORWARD CURRENT,(A) 10 | | | | | | | | +0.5A 0 -0.25A -1.0A 60 50 40 30 20 10 1cm SET TIME BASE FOR 50 / 10ns / cm 0 .01 .05 .1 .5 1 5 10 50 100 REVERSE VOLTAGE,(V) Page 2 Document ID Issued Date Revised Date AS-121401 2008/02/10 2012/10/29 Revision E Page. 3 SAS11-M THRU SAS18-M 1.0A Surface Mount Super Fast Rectifiers-50-600V Pinning information Pin Pin1 Pin2 Simplified outline cathode anode 1 Symbol 2 1 2 Marking Type number Marking code SAS11-M SAS12-M SAS13-M SAS14-M SAS15-M SAS16-M SAS17-M SAS18-M S1 S2 S3 S4 S5 S6 S7 S8 Suggested solder pad layout C A B Dimensions in inches and (millimeters) PACKAGE A B C SOD-123 0.075 (1.90) 0.055 (1.40) 0.075 (1.90) Page 3 Document ID Issued Date Revised Date AS-121401 2008/02/10 2012/10/29 Revision E Page. 3
SAS14-M 价格&库存
很抱歉,暂时无法提供与“SAS14-M”相匹配的价格&库存,您可以联系我们找货
