DFR1G
DFR1G
    ANBON(安邦)
    SOD-123
    1.0A表面贴装快恢复整流二极管
DFR1G 数据手册
DFR1A THRU DFR1M 1.0A Surface Mount Fast Recovery Rectifiers-50-1000V Package outline Features Glass passivated device Ideal for surface mouted applications Low reverse leakage Metallurgically bonded construction High temperature soldering guaranteed: 250 C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension Compliant to RoHS Directive 2011/65/EU Compliant to Halogen-free SOD-123 1.1± 0.25 0.10-0.30 1.8± 0.2 1.0±0.2 Cathode Band Top View 0.6±0.25 Mechanical data Case : JEDEC SOD-123 molded plastic body over passivated chip Terminals: Plated axial leads, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight :0.0007 ounce, 0.02 grams 3.7±0.2 Dimensions in millimeters Maximum ratings and Electrical Characteristics (AT PARAMETER T A=25 oC unless otherwise noted) CONDITIONS Symbol MIN. TYP. MAX. UNIT Forward rectified current See Fig.2 IO 1.0 A Forward surge current 8.3ms single half sine-wave (JEDEC methode) I FSM 25 A V R = V RRM T A = 25 OC Reverse current V R = V RRM T A = 100 C Thermal resistance Junction to ambient NOTE 1 Diode junction capacitance f=1MHz and applied 4V DC reverse voltage Storage temperature V RMS*2 (V) *3 VR (V) DFR1A 50 35 50 DFR1B 100 70 100 DFR1D 200 140 200 DFR1G 400 280 400 DFR1J 600 420 600 DFR1K 800 560 800 DFR1M 1000 700 1000 *4 VF (V) *5 t rr (ns) Operating temperature T J, ( OC) μA 50 R θJA 50 CJ 15 T STG *1 V RRM (V) SYMBOLS 5.0 IR O O pF +150 -65 C/W O C *1 Repetitive peak reverse voltage *2 RMS voltage 150 *3 Continuous reverse voltage 1.30 -55 to +150 250 *4 Maximum forward voltage@I F=1.0A *5 Maximum Reverse recovery time, note 2 500 Note: 1.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas 2. Reverse recovery time test condition, I F =0.5A, I R =1.0A, I RR =0.25A http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 1 Document ID Issued Date Revised Date Revision Page. AS-3020002 2003/03/08 2012/05/16 D 3 DFR1A THRU DFR1M 1.0A Surface Mount Fast Recovery Rectifiers-50-1000V Rating and characteristic curves (DFR1A THRU DFR1M ) FIG.1-TYPICAL FORWARD FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 10 3.0 1.0 1.2 1.0 0.8 0.6 P.C.B. Mounted on 0.2" x 0.2" (5 mm x 5 mm) Copper Pad Areas 0.4 0.2 0 0 20 40 TJ=25 C 60 80 100 120 140 160 180 200 LEAD TEMPERATURE (°C) Pulse Width 300us 1% Duty Cycle 0.1 .01 .6 .8 1.0 1.2 1.4 1.6 1.8 2.0 FORWARD VOLTAGE,(V) FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTICS 50W NONINDUCTIVE 10W NONINDUCTIVE ( ) (+) D.U.T. 25Vdc (approx.) PEAK FORWAARD SURGE CURRENT,(A) FIG.4-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PULSE GENERATOR (NOTE 2) ( ) 50 40 30 8.3ms Single Half TJ=25 C 1W NONINDUCTIVE Sine Wave 20 JEDEC method 10 0 1 5 50 10 100 NUMBER OF CYCLES AT 60Hz (+) OSCILLISCOPE (NOTE 1) FIG.5-TYPICAL JUNCTION CAPACITANCE NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF. 2. Rise Time= 10ns max., Source Impedance= 50 ohms. trr | | | | | | | | +0.5A 0 35 JUNCTION CAPACITANCE,(pF) INSTANTANEOUS FORWARD CURRENT,(A) 50 -0.25A 30 25 20 15 10 5 0 -1.0A 1cm .01 SET TIME BASE FOR .05 .1 .5 1 5 10 50 100 REVERSE VOLTAGE,(V) 50 / 10ns / cm http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 2 Document ID Issued Date Revised Date Revision Page. AS-3020002 2003/03/08 2012/05/16 D 3 DFR1A THRU DFR1M 1.0A Surface Mount Fast Recovery Rectifiers-50-1000V Pinning information Pin Pin1 Pin2 Simplified outline cathode anode 1 Symbol 2 1 2 Marking Type number Marking code DFR1A DFR1B DFR1D DFR1G DFR1J DFR1K DFR1M F1 F2 F3 F4 F5 F6 F7 Suggested solder pad layout C A B Dimensions in inches and (millimeters) PACKAGE A B C SOD-123 0.075 (1.90) 0.055 (1.40) 0.075 (1.90) http://www.anbonsemi.com TEL:886-755-23776891 FAX:886-755-81482182 Page 3 Document ID Issued Date Revised Date Revision Page. AS-3020002 2003/03/08 2012/05/16 D 3
DFR1G 价格&库存
很抱歉,暂时无法提供与“DFR1G”相匹配的价格&库存,您可以联系我们找货
DFR1G
    • 1+0.12400
    库存:50
