MBRD10100CT
MBRD10100CT
    BLUEROCKET(蓝箭电子)
    TO-252(DPAK)
    电压:100V 电流:10A
MBRD10100CT 数据手册
MBRD10100CT Rev.F May.-2016 描述 / DATA SHEET Descriptions TO-252 塑封封装 肖特基二极管。 Schottky Diode in a TO-252 Plastic Package. 特征 / Features 损耗低,效率高。 Low power loss, high efficiency. 用途 / Applications 用于高频、低压、大电流整流二极管,续流二极管,保护二极管。 For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications. 内部等效电路 引脚排列 / Equivalent Circuit / Pinning 4 1 2 3 PIN1:Anode 放大及印章代码 PIN 2,4:Cathode PIN 3:Anode / hFE Classifications & Marking 见印章说明。See Marking Instructions. http://www.fsbrec.com 1/6 MBRD10100CT Rev.F May.-2016 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage 符号 Symbol VRRM VRWM VRM 数值 Rating 单位 Unit 100 V RMS Reverse Voltage VR(RMS) 70 V Average Rectified Forward Current IF(AV) 2×5 A Non Repetitive Peak Surge Current IFSM 125 A Thermal resistance, junction to case RθJc 6.5 ℃/W Junction Temperature Range Tj MAX 150 ℃ Storage Temperature Range Tstg -55~150 ℃ 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter Reverse Voltage Forward Voltage Instantaneous Reverse Current 符号 Symbol VBR VF IR (Note 1) 测试条件 Test Conditions IR=0.3mA 最小值 典型值 最大值 Min Typ Max 100 单位 Unit V IF=5A TJ=25℃ 0.85 V IF=5A TJ=125℃ 0.75 V IF=10A TJ=25℃ 0.95 V IF=10A TJ=125℃ 0.85 V VR=100V TJ=25℃ 10 uA VR=70V TJ=125℃ 1.0 mA VR=100V TJ=125℃ 5.0 mA 注/Notes: 1. 使用极短的测试时间,以尽量减少自热效应。/Short duration pulse test used to minimize self-heating effect. 2. 除非特别注明,数值为一个芯片的参数。/ Unless otherwise noted, values for the parameters of a single chip http://www.fsbrec.com 2/6 MBRD10100CT Rev.F May.-2016 电参数曲线图 DATA SHEET / Electrical Characteristic Curve IF - TC 12 PEAK FORWARD SURGE CURRENT-(A) 10 8 6 IF(A) IFSM 125 4 2 8.3ms Single Half Sine Wave Jedec Method 100 75 50 25 0 0 25 50 75 100 125 150 0 175 10 20 30 40 50 60 70 NO.OF CYCLES AT 60HZ 80 90 100 TC(℃) IF - VF IR - VR 10000 100 TA=150℃ IR(uA) 1000 TA=150℃ IF(A) 10 TA=125℃ 100 10 TA=125℃ TA=25℃ 1 1 TA=25℃ 0.1 0.01 0.1 0 0.2 0.4 0.6 VF(V) http://www.fsbrec.com 0.8 1 1.2 0 20 40 60 80 100 VR(V) 3/6 MBRD10100CT Rev.F May.-2016 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 MBRD10100CT Rev.F May.-2016 印章说明 / DATA SHEET Marking Instructions BR MBRD10100 CT **** 说明: BR:    为公司代码 MBRD10100: 为产品型号 CT:    为内部结构 ****:   为生产批号代码,随生产批号变化。 Note: BR: Company Code MBRD10100: Product Type. CT: Internal Structure ****: Lot No. Code, code change with Lot No. http://www.fsbrec.com 5/6 MBRD10100CT Rev.F May.-2016 DATA SHEET 回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 245±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:245±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:260±5℃ 包装规格 Package Type 封装形式 TO-252 套管包装 Package Type 封装形式 使用说明 Temp.:260±5℃ Time:10±1 sec / Packaging SPEC. 卷盘包装 TO-251/252 时间:10±1 sec. / REEL Units 包装数量 Dimension Units/Reel 只/卷盘 Reels/Inner Box 卷盘/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 2,500 2 5,000 5 25,000 包装尺寸 3 (unit:mm ) Reel Inner Box 盒 Outer Box 箱 13〞×16 360×360×50 385×257×392 / TUBE Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) Units/Tube 只/套管 Tubes/Inner Box 套管/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Tube 套管 Inner Box 盒 Outer Box 箱 75 48 3,600 5 18,000 526×20.5×5.25 555×164×50 575×290×180 / Notices http://www.fsbrec.com 6/6
MBRD10100CT 价格&库存
很抱歉,暂时无法提供与“MBRD10100CT”相匹配的价格&库存,您可以联系我们找货
MBRD10100CT
  • 5+1.67282
  • 50+1.34622
  • 150+1.20626
  • 500+1.03162
库存:1860
