LV10T100D
Rev.F Mar.-2016
DATA SHEET
Descriptions
TO-252 塑封封装 肖特基二极管。
Schottky Diode in a TO-252 Plastic Package.
特征
/ Features
高正向浪涌能力,超低正向压降,优异的高温稳定性。
High Forward Surge Capability, Ultra Low Forward Voltage Drop, Excellent High Temperature
Stability.
用途
Applications
用于高频、低压、大电流整流二极管,续流二极管,保护二极管。
For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications.
内部等效电路
引脚排列
/ Equivalent Circuit
/ Pinning
4
1
2
3
PIN1:Anode
放大及印章代码
PIN 2,4:Cathode
PIN 3:Anode
/ hFE Classifications & Marking
见印章说明。See Marking Instructions.
http://www.fsbrec.com
1/6
LV10T100D
Rev.F Mar.-2016
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
参数
Parameter
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
符号
Symbol
VRM
VRSM
VDC
数值
Rating
单位
Unit
100
V
RMS Reverse Voltage
VRMS
70
V
Average forward rectified current
IF(AV)
1×10
A
Non Repetitive Peak Surge Current
IFSM
200
A
Thermal Resistance Junction to Case
RθJc
2.0
℃/W
-55~+150
Tj
Junction and Storage Temperature Range
电性能参数
Tstg
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
Reverse Voltage
Forward Voltage
Instantaneous Reverse Current
符号
Symbol
V(BR)R
VF
IR
(Note 1)
测试条件
Test Conditions
IR=1mA(Ta=25℃)
最小值 典型值 最大值
Min
Typ
Max
100
单位
Unit
V
IF =2A(Ta=25℃)
0.41
0.45
V
IF =10A(Ta=25℃)
0.58
0.65
V
IF =2A(Ta=125℃)
0.31
0.40
V
IF =10A(Ta=125℃)
0.55
0.65
V
VR=100V(Ta=25℃)
150
μA
VR=100V(Ta=125℃)
25
mA
注/Notes:
1. 使用极短的测试时间,以尽量减少自热效应。
Short duration pulse test used to minimize self-heating effect.
2. 除非特别注明,数值为一个芯片的参数。
Unless otherwise noted, values for the parameters of a single chip
2/6
LV10T100D
Rev.F Mar.-2016
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
3/6
LV10T100D
Rev.F Mar.-2016
外形尺寸图
DATA SHEET
/ Package Dimensions
4/6
LV10T100D
Rev.F Mar.-2016
印章说明
DATA SHEET
BR
10T100
说明:
BR:
为公司代码
10T100:
为型号代码
为生产批号代码,随生产批号变化。
Note:
BR:
Company Code
10T100:
Product Type Code.
Lot No. Code, code change with Lot No.
5/6
LV10T100D
Rev.F Mar.-2016
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 25~150℃,时间 60~90sec;
1.Preheating:25~150℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Package Type
封装形式
TO-252
套管包装
Package Type
封装形式
使用说明
Temp.:260±5℃
Time:10±1 sec
/ Packaging SPEC.
卷盘包装
TO-251/252
时间:10±1 sec.
/ REEL
Units 包装数量
Dimension
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
2,500
2
5,000
5
25,000
包装尺寸
3
(unit:mm )
Reel
Inner Box 盒
Outer Box 箱
13〞 ×16
360×360×50
385×257×392
/ TUBE
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Tube
只/套管
Tubes/Inner Box
套管/盒
Units/Inner Box
只/盒
盒/箱
Units/Outer Box
只/箱
Tube 套管
Inner Box 盒
Outer Box 箱
75
48
3,600
5
18,000
526×20.5×5.25
555×164×50
575×290×180
/ Notices
6/6
很抱歉,暂时无法提供与“LV10T100D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.06226
- 50+1.59959
- 150+1.40130
- 500+1.15398
