PTD3004
30V/50A N-Channel Advanced Power MOSFET
Features
• Low RDS(on) @ 5V Logic.
• 5V Logic Level Control
• TO-252 SMD Package
• Pb−Free, RoHS Compliant
BVDSS
30
V
ID
50
A
RDSON@VGS=10V
10
mΩ
RDSON@VGS=5V
13
mΩ
Applications
• High Side Load Switch
• Battery Switch
• Optimized for Power Management Applications for
Portable Products, such as Aeromodelling, Power bank,
S
G
TO-252
Brushless motor, Main board , and Others
Absolute Maximum Ratings
Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the
Recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may
affect device reliability.
Symbol
Parameter
Rating
Unit
±20
V
30
V
175
°C
-55 to 175
°C
TC =25°C
50
A
Common Ratings (T C=25°C Unless Otherwise Noted)
VGS
Gate-Source Voltage
V(BR)DSS Drain-Source Breakdown Voltage
TJ
Maximum Junction Temperature
TSTG
Storage Temperature Range
IS
Diode Continuous Forward Current
Mounted on Large Heat Sink
IDM
Pulse Drain Current Tested (Sillicon Limit)
TC =25°C
140
A
ID
Continuous Drain current @VGS=10V
TC =25°C
50
A
PD
Maximum Power Dissipation
TC =25°C
32
W
EAS
Avalanche Energy, Single Pulsed (Note 3)
220
mJ
Thermal Resistance Junction−to−Ambient – Steady State (Note 1)
62
°C/W
Thermal Resistance Junction−to−Ambient –t ≤ 5 s (Note 1)
3.3
°C/W
(Note 2)
R JA
Note :
1. Surface−mounted on FR4 board using 1 in sq. pad size (Cu area = 1.127 in sq. [2 oz] including traces).
2. Pulse Test: pulse width ≤ 300 us, duty cycle ≤ 2%
3. Limited by Tjmax, starting TJ = 25°C, L = 0.1mH,RG = 25Ω, IAS = 35A, VGS =10V. Part not recommended for use above this value
- 1-
2015-3-26
PTD3004
Symbol
Parameter
Condition
Min.
Typ.
Max.
Unit
Static Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
VGS=0V ID=250μA
30
V
Zero Gate Voltage Drain current(Tc=25℃)
VDS=24V,VGS=0V
1
μA
Zero Gate Voltage Drain Current(Tc=125℃)
VDS=24V,VGS=0V
100
μA
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(TH)
Gate Threshold Voltage
VDS=VGS,ID=-250μ
1.2
1.8
2.5
V
RDS(ON)
Drain-Source On-State Resistance note A
A
VGS=10V, ID=30A
7.5
10
mΩ
RDS(ON)
VGS=5V, ID=20A
9
13
mΩ
1500
pF
300
pF
135
pF
11
nC
V(BR)DSS
IDSS
Dynamic Electrical Characteristics @ TJ = 25°C (unless otherwise stated) note B
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
VDS=15V,VGS=0V,
f=1MHz
VGS=10V
VGS=4.5V
Qgs
Gate-Source Charge
Q gd
Gate-Drain Charge
9
VDS=15V,ID=10A,
VGS=10V
nC
25
nC
5
nC
22
nS
Switching Characteristics note B
t d(on)
Turn-on Delay Time
tr
Turn-on Rise Time
ID=10A,
8
nS
t d(off)
Turn-Off Delay Time
RG=4.7Ω,
9
nS
tf
Turn-Off Fall Time
6
nS
VDD=15V,
VGS=10V
Source- Drain Diode Characteristics@ TJ = 25°C (unless otherwise stated)
ISD
Source-drain current(Body Diode)
Tc=25℃
50
A
VSD
Forward on voltage
IS=20A,VGS=0V
0.82
1.2
V
trr
Reverse Recovery Time
Tj=25℃,ISD=20A,
22
nS
Qrr
Reverse Recovery Charge
15
nC
VGS=0V
di/dt=100A/μs
Note:
A: Pulse Test: pulse width ≤ 300 us, duty cycle ≤ 2%
B:Guranteed by design, not subject to production testing.
- 2-
2015-3-26
PTD3004
ID, Drain-Source Current (A)
Typical Characteristics
VDS, Drain -Source Voltage (V)
VGS - Gate-to-Source Voltage (V)
Fig2. Transfer Characteristics
RDSON, Normalized
Is- Reverse Drain Current (A)
Fig1. Typical Output Characteristics
Tj - Junction Temperature (°C)
Vsd Source-Drain Voltage (V)
Figure4. Source- Drain Diode Forward
ID - Drain Current (A)
VGS, Gate-Source Voltage (V)
Fig3. Normalized On-Resistance Vs. Temperature
Qg Gate Charge (nC)
Figure 5 .Gate Charge Vs. Gate-Source Voltage
Fig6. Maximum Safe Operating Area
- 3-
2015-3-26
PTD3004
C, Capacitance (pF)
VGS(TH), Gate -Source Voltage (V)
VDS , Drain-Source Voltage (V)
Fig7. Threshold Voltage Vs. Temperature
Fig8. Typical Capacitance Vs.Drain-Source Voltage
Fig9. Normalized Maximum Transient Thermal Impedance
Fig10. Switching Time Test Circuit and waveforms
- 4-
2015-3-26
很抱歉,暂时无法提供与“PTD3004”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.23520
- 50+1.01747
- 150+0.92416
- 500+0.80774
