BRD50N06
BRD50N06
    BLUEROCKET(蓝箭电子)
    TO-252(DPAK)
    停产 1个N沟道 耐压:60V 电流:50A
BRD50N06 数据手册
BRD50N06 Rev.D May.-2016 描述 / DATA SHEET Descriptions TO-252 塑封封装 N 沟道 MOS 场效应管。N-CHANNEL MOSFET in a TO-252 Plastic Package. 特征 / Features RDS(on)小,门电荷低,Crss 小,开关速度快。 Low RDS(on),low gate charge, low Crss, fast switching. 用途 / Applications 用于低压电路如:汽车电路、DC/DC 转换、便携式产品的电源高效转换。 Suited for low voltage applications such as automotive, DC/DC Converters, and high efficiency switching for power management in portable and battery operated products. 内部等效电路 引脚排列 / Equivalent Circuit / Pinning 4 1 2 3 PIN1:G 放大及印章代码 PIN 2:D PIN 3:S PIN 4:D / hFE Classifications & Marking 见印章说明。See Marking Instructions. http://www.fsbrec.com 1/6 BRD50N06 Rev.D May.-2016 极限参数 / DATA SHEET Absolute Maximum Ratings(Ta=25℃) 参数 Parameter 符号 Symbol 数值 Rating 单位 Unit VDSS 60 V Drain Current ID(Tc=25℃) 50 A Drain Current ID(Tc=100℃) 35.4 A Drain Current - Pulsed IDM 200 A Gate-Source Voltage VGS ±20 V Single Pulsed Avalanche Energy EAS 490 mJ Repetitive Avalanche Energy EAR 12 mJ PD(Tc=25℃) 85 W Junction Temperature Range Tj 150 ℃ Storage Temperature Range Tstg -55~150 ℃ Drain-Source Voltage Power Dissipation 电性能参数 / Electrical Characteristics(Ta=25℃) 参数 Parameter 符号 Symbol Drain-Source Breakdown Voltage BVDSS Zero Gate Voltage Drain Current IDSS Gate-Body Leakage Current Forward Gate Threshold Voltage Total Gate Charge Static Drain-Source On-Resistance Drain-Source Diode Forward Voltage Input Capacitance 测试条件 Test Conditions 最小值 典型值 Min Typ 最大值 Max VGS=0V ID=250μA VDS=60V VGS=0V 1.0 VDS=48V TC=150℃ 10 VGS=±20V VDS=0V VGS(th) VDS=VGS ID=250μA Qg VDS=48V VGS=10V ID=50A RDS(on) VGS=10V ID=25A VSD VGS=0V IS=50A VDS=25V f=1.0MHz VGS=0V IGSS Ciss 60 V μA 4 V 32 42 nC 0.018 0.022 Ω 1.5 V 2 1050 1365 460 600 Coss Reverse Transfer Capacitance Crss 70 90 Turn-On Delay Time td(on) 20 50 Turn-On Rise Time tr 100 210 Turn-Off Delay Time td(off) 80 170 85 180 Turn-Off Fall Time http://www.fsbrec.com tf ID=25A μA ±0.1 Output Capacitance VDD=30V RG=25Ω 单位 Unit pF ns 2/6 BRD50N06 Rev.D May.-2016 电参数曲线图 DATA SHEET / Electrical Characteristic Curve http://www.fsbrec.com 3/6 BRD50N06 Rev.D May.-2016 外形尺寸图 DATA SHEET / Package Dimensions http://www.fsbrec.com 4/6 BRD50N06 Rev.D May.-2016 印章说明 / DATA SHEET Marking Instructions BR 50N06 **** 说明: BR: 为公司代码 50N06:  为型号代码 ****:  为生产批号代码,随生产批号变化。  Company Code Note: BR:   50N06: ****: http://www.fsbrec.com Product Type Code.  Lot No. Code, code change with Lot No. 5/6 BRD50N06 Rev.D May.-2016 DATA SHEET 回流焊温度曲线图(无铅) / Temperature Profile for IR Reflow Soldering(Pb-Free) 说明: Note: 1、预热温度 25~150℃,时间 60~90sec; 1.Preheating:25~150℃, Time:60~90sec. 2、峰值温度 245±5℃,时间持续为 5±0.5sec; 2.Peak Temp.:245±5℃, Duration:5±0.5sec. 3、焊接制程冷却速度为 2~10℃/sec. 3. Cooling Speed: 2~10℃/sec. 耐焊接热试验条件 / Resistance to Soldering Heat Test Conditions 温度:260±5℃ 包装规格 Package Type 封装形式 TO-252 套管包装 Package Type 封装形式 使用说明 Temp.:260±5℃ Time:10±1 sec / Packaging SPEC. 卷盘包装 TO-251/252 时间:10±1 sec. / REEL Units 包装数量 Dimension Units/Reel 只/卷盘 Reels/Inner Box 卷盘/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 2,500 2 5,000 5 25,000 包装尺寸 3 (unit:mm ) Reel Inner Box 盒 Outer Box 箱 13〞×16 360×360×50 385×257×392 / TUBE Units 包装数量 Dimension 包装尺寸 3 (unit:mm ) Units/Tube 只/套管 Tubes/Inner Box 套管/盒 Units/Inner Box 只/盒 Inner Boxes/Outer Box 盒/箱 Units/Outer Box 只/箱 Tube 套管 Inner Box 盒 Outer Box 箱 75 48 3,600 5 18,000 526×20.5×5.25 555×164×50 575×290×180 / Notices http://www.fsbrec.com 6/6
BRD50N06 价格&库存
很抱歉,暂时无法提供与“BRD50N06”相匹配的价格&库存,您可以联系我们找货
