PDTC114TM
Digital Transistor(built-in resistors)
Feature
Built-in bias resistors enable the configuration of an inverter circuit
without connecting external input resistors (see equivalent circuit).
The bias resistors consist of thin-film resistors with complete isolation
C
R1
B
to allow negative biasing of the input. They also have the advantage
of almost completely eliminating parasitic effects.
Only the on/off conditions need to be set for operation, making the
device design easy.
E
B:Base
C: Collector
E: Emitter
R1=10KΩ
Applications
Inverter
Interface
Driver
Mechanical Characteristics
Lead finish:100% matte Sn(Tin)
Mounting position: Any
Qualified max reflow temperature:260℃
Device meets MSL 1 requirements
Pure tin plating: 7 ~ 17 um
Pin flatness:≤3mil
Structure
NPN epitaxial planar silicon transistor (Resistor built-in type)
Electrical characteristics per line@25℃( unless otherwise specified)
Parameter
Symbol
Conditions
Min.
Collector-base breakdown voltage
BVCBO
IC =50µA
50
V
Collector-emitter breakdown
BVCEO
IC=1mA
50
V
Emitter-base breakdown voltage
BVEBO
IE=50µA
5
V
Collector cutoff current
ICBO
VCB=50V
0.5
μA
Emitter cutoff current
IEBO
VEB=4V
0.5
μA
Collector-emitter saturation
VCE(sat)
IC/IB=5mA/0.25mA
0.3
V
DC current transfer ratio
hFE
IC=1mA, VCE=5V
100
250
600
Input resistance
R1
7
10
13
kΩ
Transition frequency
fT
VCE=10V, IE= −5mA,
Rev.06
1
Typ.
250
Max.
Units
MHz
www.prisemi.com
PDTC114TM
Absolute maximum rating@25℃
Rating
Symbol
Value
Units
Collector-base voltage
VCBO
50
V
Collector-emitter voltage
VCEO
50
V
Emitter-base voltage
VEBO
5
V
Collector current
IC
100
mA
Collector power dissipation
PC
150
mW
Junction temperature
Tj
150
Storage temperature
Tstg
-55 to +150
1K
1K
500
500
100
50
Collector Saturation Voltage : VCE(SAT)(mV)
DC Current Gain : hFE
Typical Characteristics
Ta=100°C
25°C
-40°C
10
5
1
100μ
500μ 1m
5m 10m
100
50
10
5
1
100μ
50m 100m
Ta=100°C
25°C
-40°C
500μ 1m
500μ 10m
50m 100m
Collector Current:: IC(A)
Collector Current: IC(A)
Fig 1.DC current gain vs. collector current @ VCE=5V
Fig 2.Collector-emitter saturation voltage vs. collector current
@IC/IB=10
Rev.06
2
www.prisemi.com
PDTC114TM
Solder Reflow Recommendation
Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec
280
240
200
160
120
80
40
30
90
120
150
180
240
210
270
300
330
360
390
420
450
480
Time (sec)
Product dimension (SOT-723)
(0.11)
Side View
0.387±0.013
R0.1-R0.15
9°(4x)
1.2±0.03
(0.4)
(2)
(3)
(1)
(0.2)
Bottom View
1.2±0.025
0.8±0.025
Rev.06
Unit:mm
3
www.prisemi.com
PDTC114TM
0.6
0.6
0.6
0.65
0.4
0.8
1
Unit:mm
Device
Package
Shipping
PDTC114TM
SOT-723 (Pb-Free)
8000 / Tape & Reel
Ordering information
Rev.06
4
www.prisemi.com
PDTC114TM
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06
5
www.prisemi.com
很抱歉,暂时无法提供与“PDTC114TM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23793
- 200+0.18663
- 600+0.15812
