78M06-MS
78M06-MS
    MSKSEMI(美森科)
    TO-252(DPAK)
    6V 500MA 25V
78M06-MS 数据手册
www.msksemi.com 78M06-MS Semiconductor FEATURES Maximum output current IOM: 0.5 A Output voltage VO: 6V Continuous total dissipation 1.25 W PD: 1.IN 2.GND 1 3.OUT Compiance 2 3 TO-252 ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified) Parameter Symbol Input Voltage Value 25 Vi Operating Junction Temperature Range Storage Temperature Range Unit V TOPR 0-+125 ℃ TSTG -65-+150 ℃ ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JINCTION TEMPERATURE (Vi=11V, IO=350mA,Ci=0.33μF,Co=0.1μF, unless otherwise specified) Parameter Symbol Test conditions Min 25℃ Output Voltage Vo 8V≤V i≤21V, Io=5mA-350mA 0-125℃ Po≤ 15W Load Regulation ΔVo Line Regulation ΔVo Quiescent Current Iq Typ Max Unit 5.75 6 6.25 V 5.7 6 6.3 V Io=5mA-0.5A 25℃ 18 120 mV Io=5mA-200mA 25℃ 10 60 mV 8V≤V i≤25V, Io=200mA 25℃ 5 100 mV 9V≤V i≤25V, Io=200mA 25℃ 1.5 50 mV 25℃ 4.3 6 mA ΔIq 9V≤V i≤25V, Io=200mA 0-125℃ 0.8 mA ΔIq 5mA≤I O≤350mA 0-125℃ 0.5 mA Output Noise Voltage VN 10Hz≤ f ≤100KHz 25℃ Ripple Rejection RR 9V≤Vi≤19V,f=120Hz,Io=300mA Dropout Voltage Vd Io=350mA Short Circuit Current Isc Vi=11V Peak Current Ipk Quiescent Current Change 45 uV 80 dB 25℃ 2 V 25℃ 270 mA 25℃ 0.5 A 0-125℃ 59 TYPICAL APPLICATION Vi 1 Ci 0.33μF 78M06-MS 2 3 Vo 0.5A Co 0.1μF www.msksemi.com 78M06-MS Semiconductor Output Dropout Characteristics Characteristics 8 7.2 IO=0mA (V) 6.4 VO 6.0 5 4 3 2 0A I O= 5.6 OUTPUT VOLTAGE (V) 6 TJ=25℃ 6.8 TJ=25℃ 7 OUTPUT VOLTAGE VO Compiance IO=0.2A、0.35A、0.5A 5.2 4.8 4.4 4.0 1 3.6 0 0 5 10 15 20 25 VIN INPUT VOLTAGE 30 3.2 6.8 35 7.0 7.2 (V) 7.4 7.6 7.8 8.0 INPUT VOLTAGE 8.2 VIN 8.4 8.6 8 VIN=11V IO=0mA TJ=25℃ TJ=25℃ 7 Pulsed (V) 5 OUTPUT VOLTAGE 3 6 VO 4 IQ (mA) 9.0 Current Cut-off Grid Voltage Quiescent Current 5 QUIESCENT CURRENT 8.8 (V) 2 1 4 3 2 1 0 0 5 10 15 20 INPUT VOLTAGE 8 25 VIN 30 0 0.0 35 0.5 1.0 1.5 OUTPUT CURRENT (V) IO 2.0 2.5 (A) Power Derating Curve Output Voltage vs Junction Temperature 1.50 VIN=11V IO=5mA (W) 1.25 PD 6 5 POWER DISSIPATION OUTPUT VOLTAGE VO (V) 7 4 3 2 1.00 0.75 0.50 0.25 1 0 -25 0 25 50 JUNCTION TEMPERATURE 75 TJ 100 (℃ ) 125 0.00 -25 0 25 50 JUNCTION TEMPERATURE 75 TJ 100 125 (℃ ) www.msksemi.com 78M06-MS Semiconductor Compiance PACKAGE MECHANICAL DATA D A D1 c V L3 h E φ L4 L A1 L2 L1 D2 b e θ Symbol A A1 b c D D1 D2 E e L L1 L2 L3 L4 Φ θ h V Dimensions In Millimeters Min. Max. 2.200 2.400 0.000 0.127 0.635 0.770 0.460 0.580 6.500 6.700 5.100 5.460 4.830 REF. 6.000 6.200 2.186 2.386 9.712 10.312 2.900 REF. 1.400 1.700 1.600 REF. 0.600 1.000 1.100 1.300 0° 8° 0.000 0.300 5.250 REF. Dimensions In Inches Min. Max. 0.087 0.094 0.000 0.005 0.025 0.030 0.018 0.023 0.256 0.264 0.201 0.215 0.190 REF. 0.236 0.244 0.086 0.094 0.382 0.406 0.114 REF. 0.055 0.067 0.063 REF. 0.024 0.039 0.043 0.051 0° 8° 0.000 0.012 0.207 REF. REEL SPECIFICATION P/N PKG QTY 78M06-MS TO-252 2500 www.msksemi.com 78M06-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
78M06-MS 价格&库存
很抱歉,暂时无法提供与“78M06-MS”相匹配的价格&库存,您可以联系我们找货
