BU406DT9TL
Silicon NPN Power Transistor
DESCRIPTION
·High Voltage: VCEV= 400V(Min)
·Low Saturation Voltage-
: VCE(sat)= 1.0V(Max.)@ IC= 5A
APPLICATIONS
·Designed for use in horizontal deflection output stages
of TV’s and CRT’s
ABSOLUTE MAXIMUM RATINGS(Ta=25℃)
SYMBOL
PARAMETER
VALUE
UNIT
VCBO
Collector-Base Voltage
400
V
VCEO
Collector-Emitter Voltage
200
V
Package Type
VEBO
Emitter-Base Voltage
6
V
IC
Collector Current-Continuous
7
A
ICP
Collector Current-Peak Repetitive
10
A
ICP
Collector Current- Peak (10ms)
15
A
IB
Base Current
4
A
PC
Collector Power Dissipation
@ TC=25℃
65
W
TJ
Junction Temperature
150
-55~150
Tstg
Storage Temperature Range
THERMAL CHARACTERISTICS
SYMBOL
PARAMETER
Rth j-c
Thermal Resistance, Junction to Case
Rth j-a
Thermal Resistance, Junction to Ambient
MAX
UNIT
2.08
℃/W
70
℃/W
Ordering Information
Product
BU406DT9TL
V01
Package
TO-252
Packaging
Tube
1
www.sourcechips.com
TO-252
BU406DT9TL
ELECTRICAL CHARACTERISTICS
TC=25℃ unless otherwise specified
SYMBOL
PARAMETER
VCEO(SUS)
Collector-Emitter Sustaining Voltage
IC= 50mA ;IB= 0
VCE(sat)
Collector-Emitter Saturation Voltage
IC= 5A; IB= 0.8A
1.0
V
VBE(sat)
Base-Emitter Saturation Voltage
IC= 5A; IB= 0.5A
1.2
V
ICES
Collector Cutoff Current
VCE= 400V; VBE= 0
VCE=250V; VBE= 0
5.0
0.1
mA
IEBO
Emitter Cutoff Current
VEB= 6V; IC= 0
1.0
mA
hFE
DC Current Gain
IC= 2A; VCE= 5V
60
70
fT
Current-Gain—Bandwidth Product
IC= 0.5A; VCE= 10V
10
30
tf
Fall Time
IC= 5A; IB1= -IB2= 0.8A
V01
CONDITIONS
2
www.sourcechips.com
MIN
TYP.
MAX
150
UNIT
V
80
MHz
0.4
μs
很抱歉,暂时无法提供与“BU406DT9TL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.68300
- 100+1.29800
- 1250+1.12200
- 2500+1.05710
