30V /36A Single N Power MOSFET
SMIRF4N65
N-Channel Enhancement Mode Power MOSFET
Description
SMIRF4N65 is an N-channel enhancement mode
power MOS field effect transistor. The improved
planar stripe cell and the improved guard ring
terminal have been especially tailored to minimize
on-state resistance, provide superior switching
performance, and withstand high energy pulse in
ID
4A
VDSS
650V
Rdson(max)
2.8Ω(VGS=10V, ID=2A)
Qg
13.7nC
the avalanche and commutation mode.
These devices are widely used in AC-DC power
suppliers, DC/DC converters and H-bridge PWM
motor drivers.
General Features
● 4A,650V,RDS(on)(typ.)= 2.3ohm@VGS=10V
● Low Gate charge
● Low Crss
● Fast Switching
● Improved dv/dt Capability
Application
● Power switching application
● Hard switched and high frequency circuits
● Uninterruptible power supply
TO-220
TO-252
V01
1
www.sourcechips.com
TO-220F
TO-251
SMIRF4N65
Order Information
Order Information
Marking ID
Package
Packing Type Supplied As
SMIRF4N65TBRL
IRF4N65
TO251-3L
2400 Units on Box
SMIRF4N65T9RL
IRF4N65
TO252-2L
3000 Units on Reel
SMIRF4N65T2TL
IRF4N65
TO220F-3L
1000 units on Box 5000 units on Carton
SMIRF4N65T1TL
IRF4N65
TO220-3L
1000 units on Box、5000 units on Carton
Absolute Maximum Ratings Ta=25 ºC unless otherwise noted
Parameter
Symbol
Value
Unit
Drain-source Voltage
VDS
650
V
Gate-source Voltage
VGS
±30
V
Continuous Drain Current(Ta=25 )
ID
4
A
Drain Current-Pulsed
IDM
16
A
TO251
Total Dissipation
(Ta=25 )
55
TO252
50
PD
W
TO220
30
TO220F
30
Junction Temperature
TJ
150
ºC
Storage Temperature
TSTG
-65 to 150
ºC
Single Pulse Avalanche Energy
EAS
130
mJ
ESD HBM(Human Body Mode)
≥2000
V
ESD MM(Machine Mode)
≥200
V
Electrical Characteristics Ta = 25ºC
PARAMETER
Drain-source Breakdown Voltage
Gate Threshold Voltage
Symbol
BVDSS
Test Condition
VGS=0V, ID=250μA
TYP
MAX
650
UNIT
V
4.0
V
25
uA
VGS=0V IS=4A
1.4
V
IGSS
VGS=±30V
±100
nA
RDS(ON)
VGS=10V,ID=2A
2.8
Ω
VGS(TH)
VGS=VDS ,ID=250μA
Drain-source Leakage Current
IDSS
VDS=650V,VGS=0V
Drain-Source Diode Forward Voltage
VSD
Gate-body Leakage Current (VDS = 0)
Static Drain-source On Resistance
V01
MIN
2.0
2
www.sourcechips.com
2.3
SMIRF4N65
Thermal Characteristics Ta=25℃
PARAMETER
Symbol
TYP
MAX
2.5
TO251,TO252
Maximum Junction-to-case (note1)
ºC/W
RQJC
3
TO220F,TO220
TO251,TO252
Maximum Junction-to-Ambient
UNIT
63
RQJA
TO220F,TO220
ºC/W
80
Note1: Surface Mounted on FR4 Board, t ≤ 10 sec
Dynamic Characteristics Ta = 25 ºC
PARAMETER
Symbol
Input Capacitance
Ciss
output Capacitance
Coss
Test Condition
MIN
TYP
MAX
610
UNIT
pF
62
85
pF
7
10
pF
TYP
MAX
UNIT
nS
30
70
nS
Td(off)
25
100
nS
Turn-Off Rise Time
Tf
35
85
nS
Total Gate Charge
Qg
13.7
nC
Gate-Source Charge
Qgs
2.9
nC
Gate-Drain Charge
Qgd
4.6
nC
Reverse Transfer Capacitance
VDS=25V,VGS=0V, f=1.0MHZ
Crss
Switching Characteristics Ta=25 ºC
PARAMETER
Symbol
Turn-On Delay Time
Td(on)
Turn-On Rise Time
Turn-Off Delay Time
Test Condition
MIN
Tr
VDS=300V,ID=4A,RG=25Ω
VDS=160V
,I =4A,V
D
=10V
GS
Drain-Source Diode Maximum Ratings and Characteristics Ta=25 ºC
PARAMETER
Symbol
Max. Diode Forward Current
Is
Pulsed Source Current
Ism
Integral Reverse P-N
Junction Diode in the
MOSFET
VSD
VGS=0V,IS=4A
Reverse Recovery Time
Reverse Recovery Charge
V01
Test Condition
Trr
Qrr
VGS=0V,IS=4A,
dIF/dt=100A/μs
3
www.sourcechips.com
MIN
TYP
MAX
UNIT
4
A
16
1.4
V
390
nS
1.5
μC
Test Circuit
Gate Charge Test Circuit & Waveform
Resistive Switching Test Circuit & Waveform
Unclamped Inductive Switching Test Circuit & Waveform
V01
4
www.sourcechips.com
SMIRF4N65
Typical Electrical
SMIRF4N65
And Thermal Characteristics
Figure 1: Output Characteristics
Figure 2: Transfer Characteristics
Figure 3: On Resistance Vs Drain Current
Figure 4: On Resistance Vs Gate
Source Voltage
Figure5: On Resistance Vs Junction Temperature
Characteristics
5
V01
www.sourcechips.com
Figure6: Capacitance
SMIRF4N65
Characteristics Curve
Figure7: Gate Charge Waveform
Forward Voltage
Figure8: Source-Drain Diode
Figure9: Breakdown Voltage Vs Junction Temperature
6
V01
www.sourcechips.com
Outline Information (TO251-3L)
Outline Information (TO252-2L)
7
V01
www.sourcechips.com
SMIRF4N65
Outline Information (TO220F-3L)
Outline Information (TO220-3L)
8
V01
www.sourcechips.com
SMIRF4N65
9
V01
www.sourcechips.com
SMIRF4N65
很抱歉,暂时无法提供与“SMIRF4N65T9RL”相匹配的价格&库存,您可以联系我们找货
