PTD3006
30V/80A N-Channel Advanced Power MOSFET
Features
Low On-Resistance
Fast Switching
100% Avalanche Tested
Repetitive Avalanche Allowed up to Tjmax
Lead-Free, RoHS Compliant
Description
D
PTD3006 designed by the trench process
techniques to achieve extremely low on-resistance.
Additional features of this design can operate at
high junction temperature, fast switching speed and
improved repetitive avalanche rating . These
features combine to make this design an extremely
efficient and reliable device for use in Motor
applications and a wide variety of other
applications.
S
G
TO-252
Absolute Maximum Ratings
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only;and
functional operation of the device at these or any other condition beyond those indicated in the specifications is not implied. Exposure to
absolute-maximum-rated conditions for extended periods may affect device reliability. The thermal resistance and power dissipation ratings are
measured under board mounted and still air conditions. Ambient temperature (Ta) is 25°C, unless otherwise specified.
Symbol
Parameter
Rating
Unit
Common Ratings (TC=25°C Unless Otherwise Noted)
VGS
Gate-Source Voltage
±20
V
V(BR)DSS
Drain-Source Breakdown Voltage
30
V
TJ
Maximum Junction Temperature
150
°C
TSTG
Storage Temperature Range
-55 to 150
°C
IS
Diode Continuous Forward Current
TC =25°C
80
A
Mounted on Large Heat Sink
IDM
Pulse Drain Current Tested (Sillicon Limit)
TC =25°C
320
A
ID
Continuous Drain current@VGS=10V (See Fig2)
TC =25°C
80
A
PD
Maximum Power Dissipation
TC =25°C
58
W
R JC
Thermal Resistance-Junction to Case
1.98
°C/W
225
mJ
Drain-Source Avalanche Ratings
EAS
Avalanche Energy, Single Pulsed ②
- 1-
2015-3-26
PTD3006
Symbol
Parameter
Condition
Min.
Typ.
Max.
Unit
Static Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
VGS=0V ID=250μA
30
V
Zero Gate Voltage Drain Current(Tc=25℃)
VDS=24V,VGS=0V
1
μA
Zero Gate Voltage Drain Current(Tc=125℃)
VDS=24V,VGS=0V
100
μA
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(TH)
Gate Threshold Voltage
VDS=VGS,ID=250μA
1.0
1.6
2.5
V
RDS(ON)
Drain-Source On-State Resistance①
VGS=10V, ID=40A
4.5
6.0
mΩ
RDS(ON)
VGS=4.5V, ID=20A
5.5
7.5
mΩ
1350
pF
190
pF
115
pF
38
nC
V(BR)DSS
IDSS
Dynamic Electrical Characteristics @ TJ = 25°C (unless otherwise stated)
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Qg
Total Gate Charge
VDS=15V,VGS=0V,
f=1MHz
VGS=10V
VGS=4.5V
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
15
VDS=15V,ID=18A,
VGS=10V
nC
8
nC
7
nC
13
nS
Switching Characteristics
t d(on)
Turn-on Delay Time
tr
Turn-on Rise Time
ID=10A,
12
nS
t d(off)
Turn-Off Delay Time
RG=4.7Ω,
19
nS
tf
Turn-Off Fall Time
12
nS
VDD=15V,
VGS=10V
Source- Drain Diode Characteristics@ TJ = 25°C (unless otherwise stated)
ISD
Source-drain current(Body Diode)
Tc=25℃
80
A
VSD
Forward on voltage
IS=40A,VGS=0V
1.2
V
trr
Reverse Recovery Time
Tj=25℃,Isd=40A,
22
nS
Qrr
Reverse Recovery Charge
11
nC
VGS=0V
di/dt=100A/μs
Note:
① Pulse width ≤ 300μs; duty cycle≤ 2%.
② Limited by Tjmax, starting TJ = 25°C, L = 0.5mH,RG = 25Ω, IAS = 30A, VGS =10V. Part not recommended for use above this value
③ Repetitive rating; pulse width limited by max. junction temperature.
- 2-
2015-3-26
PTD3006
ID, Drain-Source Current (A)
Typical Characteristics
VDS, Drain -Source Voltage (V)
Tc - Case Temperature (°C)
Fig2. Maximum Drain Current Vs.Case Temperature
Normalized On Resistance
Fig1. Typical Output Characteristics
VGS, Gate -Source Voltage (V)
Tj - Junction Temperature (°C)
Fig4. Normalized On-Resistance Vs. Temperature
On Resistance (mΩ)
ID - Drain Current (A)
Fig3. Typical Transfer Characteristics
Fig5. On Resistance Vs. Gate -Source Voltage
Fig6. Maximum Safe Operating Area
- 3-
2015-3-26
PTD3006
VGS, Gate-Source Voltage (V)
ISD, Reverse Drain Current (A)
VSD, Source-Drain Voltage (V)
Qg -Total Gate Charge (nC)
Fig8. Typical Gate Charge Vs.Gate-Source Voltage
C, Capacitance (pF)
VGS(TH), Gate -Source Voltage (V)
Fig7. Typical Source-Drain Diode Forward Voltage
VDS , Drain-Source Voltage (V)
Fig9. Threshold Voltage Vs. Temperature
Fig10. Typical Capacitance Vs.Drain-Source Voltage
Fig11. Unclamped Inductive Test Circuit and
Fig12. Switching Time Test Circuit and waveforms
waveforms
- 4-
2015-3-26
很抱歉,暂时无法提供与“PTD3006”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.11510
- 50+0.86973
- 150+0.76464
- 500+0.63342
- 2500+0.57500
- 5000+0.54000
