TPD65R600M
TPD65R600M
    UNIGROUP(紫光)
    TO-252(DPAK)
    650V超结功率MOSFET
TPD65R600M 数据手册
TPD65R600M Wuxi Unigroup Microelectronics Co.,Ltd 650V Super-Junction Power MOSFET DESCRIPTION 650V super-junction Power MOSFET Super-junction power MOSFET is a revolutionary technology for high voltage power MOSFETs, designed according to the SJ principle. The SJ MOSFET is a price-performance optimized product enabling to target cost sensitive applications in Consumer and Lighting markets , designed by Wuxi Unigroup Microelectronics Company. FEATURES APPLICATIONS  Very low FOM RDS(on)×Qg  Switch Mode Power Supply (SMPS)  100% avalanche tested  Uninterruptible Power Supply (UPS)   Power Factor Correction (PFC) RoHS compliant Device Marking and Package Information Device Package Marking TPD65R600M TO-252 65R600M Parameter Value Unit VDS @ Tj,max 650 V RDS(on),max 0.6 Ω ID 7 A Qg,typ 13 nC IDM 21 A Key Performance Parameters V4.0 1 www.tsinghuaicwx.com TPD65R600M Wuxi Unigroup Microelectronics Co.,Ltd Absolute Maximum Ratings TC = 25ºC, unless otherwise noted Parameter Drain-Source Voltage (VGS = 0V) Continuous Drain Current TC = 25ºC Symbol Value Unit VDSS 650 V 7 TC = 100ºC Pulsed Drain Current A ID 4.2 (note1) Gate-Source Voltage IDM 21 A VGSS ±30 V Single Pulse Avalanche Energy (note2) EAS 142 mJ Repetitive Avalanche Energy (note2) EAR 0.21 mJ IAR 1.3 A dv/dt 50 V/ns Power Dissipation PD 63 W Continuous Body Diode Current IS 6 Avalanche Current MOSFET dv/dt ruggedness, VDS = 0...480V A Pulsed Diode Forward Current (note1) ISM 21 Reverse diode dv/dt (note3) dv/dt 15 V/ns Maximum diode commutation speed (note3) dif/dt 500 A/us TJ, Tstg -55~+150 ºC Symbol Value Unit Thermal Resistance, Junction-to-Case RthJC 2.0 Thermal Resistance, Junction-to-Ambient RthJA 62 Operating Junction and Storage Temperature Range Thermal Resistance Parameter ºC/W V4.0 2 www.tsinghuaicwx.com TPD65R600M Wuxi Unigroup Microelectronics Co.,Ltd Specifications TJ = 25ºC, unless otherwise noted Value Parameter Symbol Test Conditions Unit Min. Typ. Max. VGS = 0V, ID = 250µA 650 -- -- VDS = 650V, VGS = 0V, TJ = 25ºC -- -- 1 VDS = 650V, VGS = 0V, TJ = 150ºC -- -- 100 IGSS VGS = ±30V -- -- ±100 nA Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = 250µA 2.5 -- 4.0 V Drain-Source On-Resistance RDS(on) VGS = 10V, ID = 3.5A -- 0.53 0.6 Ω RG f = 1.0MHz open drain -- 19 -- Ω -- 509 -- -- 23 -- Static Drain-Source Breakdown Voltage V(BR)DSS Zero Gate Voltage Drain Current IDSS Gate-Source Leakage Gate resistance V μA Dynamic Input Capacitance Ciss VGS = 0V, VDS = 100V, f = 1.0MHz Output Capacitance Coss Reverse Transfer Capacitance Crss -- 1.5 -- Total Gate Charge Qg -- 13 -- Gate-Source Charge Qgs -- 2.8 -- Gate-Drain Charge Qgd -- 5.6 -- Turn-on Delay Time td(on) -- 55 -- Turn-on Rise Time tr -- 61 -- Turn-off Delay Time td(off) -- 117 -- -- 42 -- -- 0.9 1.2 V -- 321 -- ns -- 3.4 -- μC -- 21.2 -- A Turn-off Fall Time VDD = 520V, ID = 7A, VGS = 10V VDD = 400V, ID = 7A, RG = 25Ω tf pF nC ns Drain-Source Body Diode Characteristics Body Diode Voltage Reverse Recovery Time VSD TJ = 25ºC, ISD = 3.5A, VGS = 0V trr Reverse Recovery Charge Qrr Peak Reverse Recovery Current Irrm VR = 400V, IF = 7A, diF/dt = 100A/μs Notes 1. Repetitive Rating: Pulse width limited by maximum junction temperature 2. IAS = 2.4A, VDD = 50V, RG = 25Ω, Starting TJ = 25°C 3. Identical low side and high side switch with identical RG V4.0 3 www.tsinghuaicwx.com TPD65R600M Wuxi Unigroup Microelectronics Co.,Ltd Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 1. Output Characteristics Figure 2. Transfer Characteristics 20 20V 10V 8V 7V 6V 5.5V 5V 4.5V 15 10 VDS = 20V ID, Drain Current (A) ID, Drain Current (A) 20 5 15 10 TJ = 25ºC TJ = 150ºC 5 0 0 0 5 10 15 VDS, Drain-to-Source Voltage (V) 0 20 2 4 6 8 10 VGS, Gate-to-Source Voltage (V) Figure 3. On-Resistance vs. Drain Current Figure 4. Capacitance VGS = 10V TJ = 25ºC 1.4 VGS = 0 f = 1MHz Capacitance (pF) RDS(on), On-Resistance (Ω) 104 1.2 1 0.8 Ciss 103 102 Coss 101 0.6 Crss 100 0.4 0 2 4 6 8 10 12 14 16 18 0 ID, Drain Current (A) 300 400 500 600 Figure 6. Body Diode Forward Voltage 12 102 Is, Source Current (A) VGS, Gate-to-Source Voltage (V) 200 VDS, Drain-to-Source Voltage (V) Figure 5. Gate Charge 10 VDD = 120V 8 6 VDD = 520V 4 TJ = 125ºC 101 TJ = 25ºC 100 2 0 10-1 0 5 10 15 0 Qg, Total Gate Charge (nC) V4.0 100 4 0.5 1 VSD, Source-to-Drain Voltage (V) 1.5 www.tsinghuaicwx.com TPD65R600M Wuxi Unigroup Microelectronics Co.,Ltd Typical Characteristics TJ = 25ºC, unless otherwise noted Figure 8.Breakdown voltage vs. Junction Temperature Figure 7. On-Resistance vs. Junction Temperature 1.3 VGS = 10V ID = 3.5A 2.5 ID = 250µA VBR(DSS), (Normalized) RDS(on), (Normalized) 3 2 1.5 1 0.5 0 1.2 1.1 1 0.9 0.8 -50 0 50 100 150 -30 0 TJ, Junction Temperature (ºC) ID, Drain Current(A) ZthJC, Thermal Impedance (ºC/W) 120 150 TO-252 102 100 D = 0.5 D = 0.2 D = 0.1 D = 0.05 D = 0.02 D = 0.01 Single Pulse 10-2 101 100 tp = 1us tp = 10us tp = 100us tp = 1ms tp = 10ms DC 10-1 10-2 10-4 10-3 10-2 10-1 100 101 100 101 102 103 VDS, Drain-Source Voltage(V) Tp, Pulse Width (s) V4.0 90 Figure 10. Safe operation area for 101 10-1 60 TJ, Junction Temperature (ºC) Figure 9. Transient Thermal Impedance TO-252 10-5 30 5 www.tsinghuaicwx.com TPD65R600M Wuxi Unigroup Microelectronics Co.,Ltd Figure A:Gate Charge Test Circuit and Waveform Figure B:Resistive Switching Test Circuit and Waveform Figure C:Unclamped Inductive Switching Test Circuit and Waveform V4.0 6 www.tsinghuaicwx.com TPD65R600M Wuxi Unigroup Microelectronics Co.,Ltd TO-252 Unit:mm Symbol Min. Nom Max. Symbol A 2.20 2.30 2.40 e A1 0.00 - 0.20 H 9.40 10.10 10.50 A2 0.97 1.07 1.17 L 1.38 1.50 1.75 b 0.68 0.78 0.90 L1 2.90 REF b3 5.20 5.33 5.50 L2 0.51 BSC c 0.43 0.53 0.63 L3 0.88 - 1.28 D 5.98 6.10 6.22 L4 - - 1.00 L5 1.65 1.80 1.95 θ 0° - 8° D1 V4.0 Unit:mm 5.30 REF E 6.40 6.60 6.80 E1 4.63 - - 7 Min. Nom Max. 2.286 BSC www.tsinghuaicwx.com TPD65R600M Wuxi Unigroup Microelectronics Co.,Ltd Disclaimer All product specifications and data are subject to change without notice. For documents and material available from this datasheet, Wuxi Unigroup does not warrant or assume any legal liability or responsibility for the accuracy, completeness of any product or technology disclosed hereunder. No license, express or implied, by estoppels or otherwise, to any intellectual property rights is granted by this document or by any conduct of Wuxi Unigroup. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling Wuxi Unigroup products not expressly indicated for use in such applications do so entirely at their own risk and agree to fully indemnify Wuxi Unigroup for any damages arising or resulting from such use or sale. Wuxi Unigroup disclaims any and all liability arising out of the use or application of any product described herein or of any information provided herein to the maximum extent permitted by law. The product specifications do not expand or otherwise modify Wuxi Unigroup’s terms and conditions of purchase, including but not limited to the warranty expressed therein, which apply to these products. Wuxi Unigroup Microelectronics CO., LTD. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design, and structural design. In the event that any or all Wuxi Unigroup products (including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. Information (including circuit diagrams and circuit parameters) herein is for example only. It is not guaranteed for volume production. Wuxi Unigroup believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. V4.0 8 www.tsinghuaicwx.com
TPD65R600M 价格&库存
很抱歉,暂时无法提供与“TPD65R600M”相匹配的价格&库存,您可以联系我们找货
