IRLR3110ZPBF-VB
IRLR3110ZPBF-VB
    VBSEMI(微碧)
    TO-252(DPAK)
    1个N沟道 耐压:100V 电流:85A
IRLR3110ZPBF-VB 数据手册
IRLR3110ZPBF www.VBsemi.com N-Channel 100-V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) 100 RDS(on) (Ω) ID (A) 0.0075 at VGS = 10 V 85 0.0095 at VGS = 4.5 V 75 • TrenchFET® Power MOSFET • 100 % Rg Tested • 100 % UIS Tested APPLICATIONS • Primary Side Switch • Isolated DC/DC Converter TO-252 D G G D S S N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted Symbol Parameter Limit Drain-Source Voltage VDS 100 Gate-Source Voltage VGS ± 20 TC = 25 °C Continuous Drain Current (TJ = 150 °C) 75 a IDM Pulsed Drain Current Avalanche Current L = 0.1 mH Single Pulse Avalanche Energyb TC = 25 °C (TO-252 and TO-251) Maximum Power Dissipationb IAS 75 EAS 280 mJ 210 W 3.25 TJ, Tstg Operating Junction and Storage Temperature Range A 300 PD TA = 25 °C (TO-252) V 85 ID TC = 125 °C Unit - 55 to 175 °C THERMAL RESISTANCE RATINGS Parameter Maximum Junction-to-Ambient b Maximum Junction-to-Case Steady State Symbol Typical Maximum RthJA 40 50 RthJC 0.85 1.1 Unit °C/W Notes: a. Package limited. b. Surface mounted on 1" x 1" FR4 board. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 服务热线:400-655-8788 1 IRLR3110ZPBF www.VBsemi.com SPECIFICATIONS TJ = 25 °C, unless otherwise noted Parameter Symbol Test Conditions Min. Typ. Max. Unit Static VDS VGS = 0 V, ID = 250 µA 100 VGS(th) VDS = VGS, ID = 250 µA 1 Gate-Body Leakage IGSS VDS = 0 V, VGS = ± 20 V VDS = 100 V, VGS = 0 V 1 Zero Gate Voltage Drain Current IDSS VDS = 100 V, VGS = 0 V, TJ = 125 °C 50 Drain-Source Breakdown Voltage Gate-Threshold Voltage 3 ± 100 VDS = 100 V, VGS = 0 V, TJ = 175 °C On-State Drain Currenta Drain-Source On-State Resistancea VDS = ≥ 5 V, VGS = 10 V ID(on) RDS(on) VGS = 10 V, ID = 30 A 0.0075 0.0095 VGS = 10 V, ID = 30 A, TJ = 125 °C 0.017 VDS = 15 V, ID = 30 A µA A VGS = 4.5 V, ID = 20 A gfs nA 250 120 VGS = 10 V, ID = 30 A, TJ = 175 °C Forward Transconductancea V Ω 0.022 25 S b Dynamic Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Total Gate Chargec Gate-Source Charge c Gate-Drain Charge Turn-On Delay Time c Timec Turn-Off DelayTime VGS = 0 V, VDS = 25 V, f = 1 MHz Qgs Fall Timec pF 105 VDS = 50 V, VGS = 10 V, ID = 85 A 160 nC 17 Qgd 23 td(on) 12 25 90 135 55 85 130 195 tr c 565 205 Qg c Rise 4550 td(off) VDD = 50 V, RL = 0.6 Ω ID ≅ 85 A, VGEN = 10 V, Rg = 2.5 Ω tf Source-Drain Diode Ratings and Characteristics TC = 25 °C b IS 85 Pulsed Current ISM 240 Forward Voltagea VSD Continuous Current Reverse Recovery Time Peak Reverse Recovery Current Reverse Recovery Charge Qrr A IF = 85 A, VGS = 0 V 1.0 1.5 V 85 140 ns IF = 50 A, dI/dt = 100 A/µs 4.5 7 A 0.35 µC trr IRM(REC) ns 0.17 Notes: a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %. b. Guaranteed by design, not subject to production testing. c. Independent of operating temperature. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 服务热线:400-655-8788 2 IRLR3110ZPBF www.VBsemi.com TYPICAL CHARACTERISTICS TA = 25 °C, unless otherwise noted 200 250 VGS = 10 V thru 6 V 5V 200 I D - Drain Current (A) I D - Drain Current (A) 150 150 100 4V 100 TC = 125 °C 50 50 - 55 °C 25 °C 3V 0 0 0 2 4 6 8 0 10 1 2 3 4 5 VDS - Drain-to-Source Voltage (V) VGS - Gate-to-Source Voltage (V) Output Characteristics Transfer Characteristics 250 6 0.020 R DS(on) - On-Resistance (Ω) g fs - Transconductance (S) TC = - 55 °C 200 25 °C 150 125 °C 100 50 0 0 20 40 60 80 0.015 VGS = 4.5 V VGS = 10 V 0.010 0.005 0.000 100 0 20 40 80 100 120 ID - Drain Current (A) ID - Drain Current (A) On-Resistance vs. Drain Current Transconductance 20 VGS - Gate-to-Source Voltage (V) 7500 6000 C - Capacitance (pF) 60 Ciss 4500 3000 1500 Crss VDS = 50 V ID = 85 A 16 12 8 4 Coss 0 0 0 15 30 45 60 VDS - Drain-to-Source Voltage (V) Capacitance 75 0 50 100 150 200 Qg - Total Gate Charge (nC) Gate Charge 服务热线:400-655-8788 3 IRLR3110ZPBF www.VBsemi.com TYPICAL CHARACTERISTICS TA = 25 °C, unless otherwise noted 2.5 100 VGS = 10 V ID = 30 A I S - Source Current (A) (Normalized) R DS(on) - On-Resistance 2.0 1.5 1.0 TJ = 150 °C TJ = 25 °C 10 0.5 0.0 - 50 1 - 25 0 25 50 75 100 125 150 175 0 0.6 0.9 1.2 VSD - Source-to-Drain Voltage (V) On-Resistance vs. Junction Temperature Source-Drain Diode Forward Voltage 1000 140 130 100 IAV (A) at T A = 25 °C VDS (V) I Dav (a) 0.3 TJ - Junction Temperature (°C) 10 IAV (A) at T A = 150 °C ID = 250 µA 120 110 1 100 0.1 0.00001 0.0001 0.001 0.01 0.1 1 90 - 50 - 25 0 25 50 75 100 125 tin (s) TJ - Junction Temperature (°C) Avalanche Current vs. Time TJ - Drain-Source Breakdown vs. Junction-Temperature 150 175 服务热线:400-655-8788 4 IRLR3110ZPBF www.VBsemi.com THERMAL RATINGS 100 1000 10 µs 100 I D - Drain Current (A) I D - Drain Current (A) 80 60 40 100 µs 10 Limited by R DS(on)* 1 ms 10 ms 100 ms, DC 1 20 0 25 0 50 75 100 125 150 175 0.1 0.1 TC = 25 °C Single Pulse 1 10 100 1000 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is specified TC - Case Temperature (°C) Maximum Avalanche and Drain Current vs. Case Temperature Safe Operating Area 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10-4 10-3 10-2 10-1 1 10 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Case 服务热线:400-655-8788 5 IRLR3110ZPBF www.VBsemi.com TO-252AA CASE OUTLINE E MILLIMETERS A C2 e b2 D1 e1 E1 L gage plane height (0.5 mm) L4 b L5 H D L3 b3 C A1 INCHES DIM. MIN. MAX. MIN. MAX. A 2.18 2.38 0.086 0.094 A1 - 0.127 - 0.005 b 0.64 0.88 0.025 0.035 b2 0.76 1.14 0.030 0.045 b3 4.95 5.46 0.195 0.215 0.024 C 0.46 0.61 0.018 C2 0.46 0.89 0.018 0.035 D 5.97 6.22 0.235 0.245 D1 5.21 - 0.205 - E 6.35 6.73 0.250 0.265 E1 4.32 - 0.170 - H 9.40 10.41 0.370 0.410 e 2.28 BSC e1 0.090 BSC 4.56 BSC 0.180 BSC L 1.40 1.78 0.055 0.070 L3 0.89 1.27 0.035 0.050 L4 - 1.02 - 0.040 L5 1.14 1.52 0.045 0.060 ECN: X12-0247-Rev. M, 24-Dec-12 DWG: 5347 Note • Dimension L3 is for reference only. 服务热线:400-655-8788 6 IRLR3110ZPBF www.VBsemi.com RECOMMENDED MINIMUM PADS FOR DPAK (TO-252) 0.224 0.243 0.087 (2.202) 0.090 (2.286) (10.668) 0.420 (6.180) (5.690) 0.180 0.055 (4.572) (1.397) Recommended Minimum Pads Dimensions in Inches/(mm) 服务热线:400-655-8788 7 IRLR3110ZPBF www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
IRLR3110ZPBF-VB
物料型号:IRLR3110ZPBF
器件简介:N-Channel 100-V (D-S) MOSFET,采用TrenchFET® Power MOSFET技术。
引脚分配:G D S,代表栅极、漏极和源极。
参数特性: - 漏源电压(VDs):100V - 栅源电压(VGS):±20V - 连续漏电流(Tc=25°C):85A - 脉冲漏电流(IDM):300A - 雪崩电流(IAs):75A - 单脉冲雪崩能量(EAS):280mJ - 最大功耗(PD):210W
功能详解: - 静态和动态特性,包括阈值电压(VGS(th))、栅漏电流(IGss)、零栅电压漏电流(Ioss)、导通状态下的漏电流(ID(on))和漏源导通电阻(RDS(on))等。 - 电容特性,如输入电容(Ciss)、输出电容(Coss)和反向传输电容(Crss)。 - 门极电荷(Qg)、栅源电荷(Qgs)和栅漏电荷(Qgd)。 - 延迟时间和上升/下降时间。
应用信息:适用于主侧开关和隔离式DC/DC转换器。
封装信息:TO-252AA,提供了详细的封装尺寸和推荐最小焊盘尺寸。
