IRLR3636TRPBF-VB
IRLR3636TRPBF-VB
    VBSEMI(微碧)
    TO-252(DPAK)
    1个N沟道 耐压:60V 电流:97A
IRLR3636TRPBF-VB 数据手册
IRLR3636TRPBF www.VBsemi.com N-Channel 60 V (D-S) 175 °C MOSFET FEATURES PRODUCT SUMMARY VDS (V) • TrenchFET® Power MOSFET 60 RDS(on) () at VGS = 10 V 0.0050 RDS(on) () at VGS = 4.5 V 0.0120 ID (A) • Package with Low Thermal Resistance • 100 % Rg and UIS Tested 97 Configuration Single D TO-252 G G D S S Top View N-Channel MOSFET ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted) PARAMETER SYMBOL LIMIT Drain-Source Voltage VDS 60 Gate-Source Voltage VGS ± 20 TC = 25 °C Continuous Drain Current Continuous Source Current (Diode TC = 125 °C Conduction)a Pulsed Drain Currentb Single Pulse Avalanche Current Single Pulse Avalanche Energy Maximum Power Dissipationb L = 0.1 mH TC = 25 °C TC = 125 °C Operating Junction and Storage Temperature Range ID V 97 56 IS 100 IDM 290 IAS 45 EAS 101 PD UNIT 136 45 A mJ W TJ, Tstg - 55 to + 175 °C SYMBOL LIMIT UNIT RthJA 50 RthJC 1.1 THERMAL RESISTANCE RATINGS PARAMETER Junction-to-Ambient Junction-to-Case (Drain) PCB Mountc °C/W Notes a. Package limited. b. Pulse test; pulse width  300 μs, duty cycle  2 %. c. When mounted on 1" square PCB (FR-4 material). d. Parametric verification ongoing. 服务热线:400-655-8788 1 IRLR3636TRPBF www.VBsemi.com SPECIFICATIONS (TC = 25 °C, unless otherwise noted) PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. - MAX. UNIT Static Drain-Source Breakdown Voltage Gate-Source Threshold Voltage Gate-Source Leakage VDS VGS = 0 V, ID = 250 μA 60 VGS(th) VDS = VGS, ID = 250 μA 2.0 VDS = 0 V, VGS = ± 20 V IGSS 4.0 - - ± 100 VGS = 0 V VDS = 60 V - - 1 - - 50 Zero Gate Voltage Drain Current IDSS VGS = 0 V VDS = 60 V, TJ = 125 °C VGS = 0 V VDS = 60 V, TJ = 175 °C - - 150 On-State Drain Currenta ID(on) VGS = 10 V VDS5 V 50 - - VGS = 10 V ID = 25 A - 0.0050 - VGS = 10 V ID = 25 A, TJ = 125 °C - 0.0117 - VGS = 10 V ID = 25 A, TJ = 175 °C - 0.0149 - VGS = 4.5 V ID = 20 A - 0.0120 - - 177 - Drain-Source On-State Resistancea Forward Transconductanceb RDS(on) gfs VDS = 15 V, ID = 25 A V nA μA A  S Dynamicb - 4844 6060 - 441 555 Crss - 200 250 Qg - 82 125 Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Total Gate Chargec Gate-Source Chargec Qgs Gate-Drain Chargec Qgd Gate Resistance Rg Turn-On Delay Timec Rise Timec Turn-Off Delay Fall Timec VGS = 10 V VDS = 25 V, f = 1 MHz VDS = 30 V, ID = 50 A f = 1 MHz td(on) tr Timec VGS = 0 V td(off) VDD = 30 V, RL = 0.6  ID  50 A, VGEN = 10 V, Rg = 1  tf pF - 14.5 - - 13.5 - nC 1 2 3 - 14 21 - 5 8 - 41 62 - 7 11 - - 290 A - 0.9 1.5 V  ns Source-Drain Diode Ratings and Characteristicsb Pulsed Currenta ISM Forward Voltage VSD IF = 50 A, VGS = 0 V Notes a. Pulse test; pulse width  300 μs, duty cycle  2 %. b. Guaranteed by design, not subject to production testing. c. Independent of operating temperature. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 服务热线:400-655-8788 2 IRLR3636TRPBF www.VBsemi.com TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted) 120 160 VGS = 10 V thru 5 V 96 ID - Drain Current (A) ID - Drain Current (A) 128 96 64 VGS = 4 V 72 TC = 25 °C 48 32 24 0 0 TC = 125 °C TC = - 55 °C 0 2 4 6 8 0 10 2 4 6 8 VDS - Drain-to-Source Voltage (V) VGS - Gate-to-Source Voltage (V) Output Characteristics Transfer Characteristics 350 10 0.015 TC = - 55 °C VGS = 4.5 V 0.0012 RDS(on) - On-Resistance (Ω) gfs - Transconductance (S) 280 TC = 25 °C 210 TC = 125 °C 140 70 0.009 0.006 VGS = 10 V 0.003 0.000 0 0 10 20 30 40 0 50 20 40 ID - Drain Current (A) 100 ID - Drain Current (A) 8000 10 6400 8 VGS - Gate-to-Source Voltage (V) C - Capacitance (pF) 80 On-Resistance vs. Drain Current Transconductance Ciss 4800 60 3200 Crss 1600 ID = 50 A VDS = 30 V 6 4 2 Coss 0 0 0 12 24 36 48 60 0 20 40 60 VDS - Drain-to-Source Voltage (V) Qg - Total Gate Charge (nC) Capacitance Gate Charge 80 100 服务热线:400-655-8788 3 IRLR3636TRPBF www.VBsemi.com TYPICAL CHARACTERISTICS (TA = 25 °C, unless otherwise noted) 80 VGS = 10 V ID = 25 A VDS - Drain-to-Source Voltage (V) RDS(on) - On-Resistance (Normalized) 2.5 2.1 1.7 VGS = 4.5 V 1.3 0.9 ID = 1 mA 76 72 68 64 60 0.5 - 50 - 25 0 25 50 75 100 125 150 - 50 - 25 175 0 TJ - Junction Temperature (°C) 50 75 100 125 150 175 TJ - Junction Temperature (°C) On-Resistance vs. Junction Temperature Drain Source Breakdown vs. Junction Temperature 100 0.05 10 0.04 TJ = 150 °C RDS(on) - On-Resistance (Ω) IS - Source Current (A) 25 1 TJ = 25 °C 0.1 0.01 0.001 0.03 0.02 TJ = 150 °C 0.01 TJ = 25 °C 0.00 0.0 0.2 0.4 0.6 0.8 1.0 1.2 0 2 VSD - Source-to-Drain Voltage (V) 4 6 8 10 VGS - Gate-to-Source Voltage (V) Source Drain Diode Forward Voltage On-Resistance vs. Gate-to-Source Voltage 0.5 VGS(th) Variance (V) 0.1 - 0.3 ID = 5 mA - 0.7 ID = 250 μA - 1.1 - 1.5 - 50 - 25 0 25 50 75 100 125 150 175 TJ - Temperature (°C) Threshold Voltage 服务热线:400-655-8788 4 IRLR3636TRPBF www.VBsemi.com THERMAL RATINGS (TA = 25 °C, unless otherwise noted) 1000 ID - Drain Current (A) 100 100 μs IDM Limited 1 ms 10 10 ms 1 0.1 0.01 0.01 100 ms 1 s, 10 s, DC Limited by RDS(on)* TC = 25 °C Single Pulse BVDSS Limited 0.1 1 10 100 VDS - Drain-to-Source Voltage (V) * VGS > minimum VGS at which RDS(on) is specified Safe Operating Area 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.05 0.02 Single Pulse 0.01 10-4 10-3 10-2 10-1 1 Square Wave Pulse Duration (s) 10 100 1000 Normalized Thermal Transient Impedance, Junction-to-Ambient 服务热线:400-655-8788 5 IRLR3636TRPBF www.VBsemi.com THERMAL RATINGS (TA = 25 °C, unless otherwise noted) 2 Normalized Effective Transient Thermal Impedance 1 Duty Cycle = 0.5 0.2 0.1 0.1 0.01 10 -4 0.05 0.02 Single Pulse 10 -3 10 -2 10 -1 1 10 100 Square Wave Pulse Duration (s) Normalized Thermal Transient Impedance, Junction-to-Case Note • The characteristics shown in the two graphs - Normalized Transient Thermal Impedance Junction-to-Ambient (25 °C) - Normalized Transient Thermal Impedance Junction-to-Case (25 °C) are given for general guidelines only to enable the user to get a “ball park” indication of part capabilities. The data are extracted from single pulse transient thermal impedance characteristics which are developed from empirical measurements. The latter is valid for the part mounted on printed circuit board - FR4, size 1" x 1" x 0.062", double sided with 2 oz. copper, 100 % on both sides. The part capabilities can widely vary depending on actual application parameters and operating conditions. 服务热线:400-655-8788 6 IRLR3636TRPBF www.VBsemi.com TO-252AA CASE OUTLINE E MILLIMETERS A C2 e b2 D1 e1 E1 L gage plane height (0.5 mm) L4 b L5 H D L3 b3 C A1 INCHES DIM. MIN. MAX. MIN. MAX. A 2.18 2.38 0.086 0.094 A1 - 0.127 - 0.005 b 0.64 0.88 0.025 0.035 b2 0.76 1.14 0.030 0.045 b3 4.95 5.46 0.195 0.215 C 0.46 0.61 0.018 0.024 C2 0.46 0.89 0.018 0.035 D 5.97 6.22 0.235 0.245 D1 5.21 - 0.205 - E 6.35 6.73 0.250 0.265 E1 4.32 - 0.170 - H 9.40 10.41 0.370 0.410 e 2.28 BSC 0.090 BSC e1 4.56 BSC 0.180 BSC L 1.40 1.78 0.055 0.070 L3 0.89 1.27 0.035 0.050 L4 - 1.02 - 0.040 L5 1.14 1.52 0.045 0.060 ECN: X12-0247-Rev. M, 24-Dec-12 DWG: 5347 Note • Dimension L3 is for reference only. 服务热线:400-655-8788 7 IRLR3636TRPBF www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
