AP100N03AD
AP100N03AD
    APM-MICROELECTRONICS(永源微)
    TO-252(DPAK)
    30V N沟道增强型MOSFET,电流:100A,耐压:30V
AP100N03AD 数据手册
AP100N03AD 30V N-Channel Enhancement Mode MOSFET Description The AP100N03AD uses advanced trench technology to provide excellent RDS(ON), low gate charge and operation with gate voltages as low as 4.5V. This device is suitable for use as a Battery protection or in other Switching application. General Features VDS=30V ID =100A RDS(ON) < 6.0mΩ @ VGS=10V (Type:4.8mΩ) Application Battery protection Load switch Uninterruptible power supply Package Marking and Ordering Information Product ID Pack Marking Qty(PCS) AP100N03AD TO-252-3L AP100N03AD XXXX YYYY 2500 Absolute Maximum Ratings (TC=25℃unless otherwise noted) Symbol Parameter Rating Units VDS Drain-Source Voltage 30 V VGS Gate-Source Voltage ±20 V ID@TC=25℃ Continuous Drain Current, VGS @ 10V1 100 A ID@TC=75℃ Continuous Drain Current, VGS @ 10V1 59 A IDM Pulsed Drain Current2 240 A EAS Single Pulse Avalanche Energy3 56 mJ IAS Avalanche Current 15 A 46 W Dissipation4 Total Power PD@TA=25℃ Total Power Dissipation4 2.72 W TSTG Storage Temperature Range -55 to 175 ℃ TJ Operating Junction Temperature Range -55 to 175 ℃ 62 ℃/W 2.72 ℃/W RθJA Thermal Resistance Junction-Ambient RθJC Junction-Case1 AP100N03AD RVE1.0 Thermal Resistance 1 永源微電子科技有限公司 1 PD@TC=25℃ AP100N03AD 30V N-Channel Enhancement Mode MOSFET Electrical Characteristics (TJ=25 ℃, unless otherwise noted) Symbol Parameter Test Condition Min. Typ. Max. Units V(BR)DSS Drain-Source Breakdown Voltage VGS=0V,ID=250μA 30 32 - V IDSS Zero Gate Voltage Drain Current VDS =30V, VGS = 0V, - - 1.0 μA IGSS Gate to Body Leakage Current VDS =0V,VGS = ±20V - - ±100 nA VGS(th) Gate Threshold Voltage VDS= VGS, ID=250μA 1.0 1.5 2.5 V RDS(on) Static Drain-Source on-Resistance VGS =10V, ID =30A - 4.8 6.0 VGS =4.5V, ID =20A - 7.5 12 Ciss Input Capacitance - 1614 - pF Coss Output Capacitance - 245 - pF Crss Reverse Transfer Capacitance - 215 - pF Qg Total Gate Charge - 33.7 - nC Qgs Gate-Source Charge - 8.5 - nC Qgd Gate-Drain(“Miller”) Charge - 7.5 - nC td(on) Turn-on Delay Time - 7.5 - ns - 14.5 - ns - 35.2 - ns - 9.6 - ns tr Turn-on Rise Time td(off) Turn-off Delay Time tf Turn-off Fall Time VDS =15V, VGS =0V, f = 1.0MHz VDS =15V, ID =30A, VGS =10V VDS=15V, ID=30A, RGEN=3Ω, VGS =10V mΩ IS Maximum Continuous Drain to Source Diode Forward Current - - 70 A ISM Maximum Pulsed Drain to Source Diode Forward Current - - 280 A - - 1.2 V VSD Drain to Source Diode Forward Voltage VGS = 0V, IS=30A Note : 1、The data tested by surface mounted on a 1 inch2 FR-4 board with 2OZ copper. 2、The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2% 3、The EAS data shows Max. rating . The test condition is VDD=25V,VGS=10V,L=0.1mH,IAS=15A 4、The power dissipation is limited by 175℃ junction temperature 5、The data is theoretically the same as ID and IDM , in real applications , should be limited by total power dissipation. 2 AP100N03AD RVE1.0 永源微電子科技有限公司 AP100N03AD 30V N-Channel Enhancement Mode MOSFET Typical Characteristics Figure1: Output Characteristics Figure 3:On-resistance vs. Drain Current Figure 5: Gate Charge Characteristics Figure 2: Typical Transfer Characteristics Figure 4: Body Diode Characteristics Figure 6: Capacitance Characteristics 3 AP100N03AD RVE1.0 永源微電子科技有限公司 AP100N03AD 30V N-Channel Enhancement Mode MOSFET Figure 7: Normalized Breakdown Voltage vs. Junction Temperature Figure 9: Maximum Safe Operating Area vs. Case Temperature Figure 8: Normalized on Resistance vs Junction Temperature Figure 10: Maximum Continuous Drain Current Figure.11: Maximum Effective Transient Thermal Impedance, Junction-to-Ca 4 AP100N03AD RVE1.0 永源微電子科技有限公司 AP100N03AD 30V N-Channel Enhancement Mode MOSFET Package Mechanical Data:TO-252-3L E Dimensions A B2 C2 Ref. L V1 Min. 0.083 0.098 A2 0 0.10 0 0.004 B 0.66 0.86 0.026 0.034 B2 5.18 5.48 0.202 0.216 C 0.40 0.60 0.016 0.024 C2 0.44 0.58 0.017 0.023 D 5.90 6.30 0.232 0.248 6.80 0.252 D H DETAIL A V2 D1 V1 A2 V1 E1 5.30REF D1 G Max. 0.209REF E 6.40 E1 4.63 G 4.47 4.67 H 9.50 10.70 0.374 0.421 L 1.09 1.21 0.043 0.048 L2 1.35 1.65 0.053 V2 0.268 0.182 0.176 7° V1 L2 Typ. Max. 2.50 Min. C Typ. Inches 2.10 A B Millimeters 0.184 0.065 7° 0° 6° 0° 6° DETAIL A TO-252 Reel Spectification-TO-252 B D 0 P0 P2 Dimensions T E Ref. A B0 A D1 W F t1 K0 P1 A0 B B B 5° Φ3 29 A A 20 Φ13 Millimeters Inches Min. Typ. Max. Min. Typ. Max. W 15.90 16.00 16.10 0.626 0.630 0.634 E 1.65 1.75 1.85 0.065 0.069 0.073 F 7.40 7.50 7.60 0.291 0.295 0.299 D0 1.40 1.50 1.60 0.055 0.059 0.063 D1 1.40 1.50 1.60 0.055 0.059 0.063 P0 3.90 4.00 4.10 0.154 0.157 0.161 P1 7.90 8.00 8.10 0.311 0.315 0.319 P2 1.90 2.00 2.10 0.075 0.079 0.083 A0 6.85 6.90 7.00 0.270 0.271 0.276 B0 10.45 10.50 10.60 0.411 0.413 0.417 K0 2.68 2.78 2.88 0.105 0.109 0.113 T 0.24 t1 0.10 10P0 39.80 0.27 0.009 0.011 0.004 40.00 40.20 1.567 1.575 1.583 5 AP100N03AD RVE1.0 永源微電子科技有限公司 AP100N03AD 30V N-Channel Enhancement Mode MOSFET Attention 1,Any and all APM Microelectronics products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your APM Microelectronics representative nearest you before using any APM Microelectronics products described or contained herein in such applications. 2,APM Microelectronics assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specifications of any and all APM Microelectronics products described or contained herein. 3, Specifications of any and all APM Microelectronics products described or contained here instipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’s products or equipment. 4, APM Microelectronics Semiconductor CO., LTD. strives to supply high quality high reliability products. However, any and all semiconductor products fail with some probability. It is possible that these probabilistic failures could give rise to accidents or events that could endanger human lives that could give rise to smoke or fire, or that could cause damage to other property. Whendesigning equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits and error prevention circuits for safe design, redundant design,and structural design. 5,In the event that any or all APM Microelectronics products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from the authorities concerned in accordance with the above law. 6, No part of this publication may be reproduced or transmitted in any form or by any means,electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of APM Microelectronics Semiconductor CO., LTD. 7, Information (including circuit diagrams and circuit parameters) herein is for example only; it is not guaranteed for volume production. APM Microelectronics believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringements of intellectual property rights or other rights of third parties. 8, Any and all information described or contained herein are subject to change without notice due to product/technology improvement,etc. When designing equipment, refer to the "Delivery Specification" for the APM Microelectronics product that you Intend to use. 6 AP100N03AD RVE1.0 永源微電子科技有限公司 AP100N03AD 30V N-Channel Enhancement Mode MOSFET Edition Date Change Rve1.0 2021/5/1 Initial release Copyright Attribution“APM-Microelectronice” 7 AP100N03AD RVE1.0 永源微電子科技有限公司
AP100N03AD
物料型号:AP100N03AD
器件简介: - 使用先进的沟槽技术,提供优秀的RDS(ON)、低栅极电荷,并且可以在低至4.5V的栅极电压下工作。 - 适用于电池保护或作为开关应用。
引脚分配: - D(漏极) - S(源极) - G(栅极)
参数特性: - 漏源电压(VDS)= 30V - 漏极电流(ID)= 100A - RDS(ON) < 6.0 mΩ @ VDS=10V(典型值:4.8 mΩ)
功能详解: - 电池保护 - 负载开关 - 不间断电源
应用信息: - 电池保护 - 负载开关 - 不间断电源
封装信息: - 产品ID:AP100N03AD - 封装类型:TO-252-3L - 包装标记:AP100N03AD XXXX YYYY - 每包装数量:2500
绝对最大额定值(除非另有说明,TC=25℃): - 漏源电压(Vps):30V - 栅源电压(VGs):±20V - 连续漏极电流(ID@Tc=25°C):100A - 存储温度范围(TSTG):-55至175℃ - 工作结温范围(TJ):-55至175℃
电气特性(TJ=25℃,除非另有说明): - 漏源击穿电压(V(BR)DSS):30V至32V - 栅阈值电压(VGS(th)):1.0V至2.5V - 静态漏源导通电阻(RDS(on)):4.8mΩ至6.0mΩ
典型特性曲线: - 输出特性 - 转移特性 - 导通电阻与漏极电流的关系 - 体二极管特性 - 栅极电荷特性 - 电容特性
机械数据: - 封装类型:TO-252-3L - 提供了详细的机械尺寸和公差
注意事项: - 产品不适用于需要极高可靠性的应用,如生命支持系统、飞机控制系统等。 - 不对超出额定值的设备故障负责。 - 规格是独立状态下产品的性能、特性和功能的说明,不保证在客户产品或设备中的性能。 - 设计设备时,应采取安全措施以防止事故或事件的发生。
版权声明: - 版权所有归永源微電子科技有限公司所有。
版本信息: - 版本:RVE1.0 - 日期:2021/5/1 - 变更:初始发布
AP100N03AD 价格&库存
很抱歉,暂时无法提供与“AP100N03AD”相匹配的价格&库存,您可以联系我们找货
