AOD2606-MS
AOD2606-MS
    MSKSEMI(美森科)
    TO-252(DPAK)
    AOD2606-MS 1个N沟道 耐压:60V 电流:80A
AOD2606-MS 数据手册
www.msksemi.com AOD2606-MS Semiconductor Compiance General Description The AOD2606-MS use advanced VD MOST technology to provide low RDS(ON), low gate charge, fast switching This device is specially designed to get better ruggedness and suitable to use in Low RDS(on) & FOM Extremely low switching loss Excellent stability and uniformity or Invertors Applications PIN2 D ! Consumer electronic power supply Motor control " PIN1 G ! Synchronous-rectification Isolated DC ! " " " Synchronous-rectification applications ! General Features PIN3 S VDS = 60V ID =80 A N-Channel MOSFET RDS(ON) < 8mΩ @ VGS=10V TO-252 RDS(ON) < 12m Ω @ VGS=4.5V Absolute Maximum Ratings@Tj=25oC(unless otherwise specified) Symbol Parameter Rating Units VDS Drain-Source Voltage 60 V VGS Gate-Source Voltage +20 V ID@TC=25℃ Drain Current, VGS @ 10V 80 A ID@TC=100℃ Drain Current, VGS @ 10V 43 A IDM Pulsed Drain Current1 272 A PD@TC=25℃ Total Power Dissipation 104 W Storage Temperature Range -55 to 150 ℃ TJ Operating Junction Temperature Range -55 to 150 ℃ Rthj-c Maixmum Thermal Resistance, Junction-case 1.2 ℃/W Rthj-a Maximum Thermal Resistance, Junction-ambient (PCB mount)3 62.5 ℃/W TSTG www.msksemi.com AOD2606-MS Semiconductor Compiance Electrical Characteristics@Tj=25oC(unless otherwise specified) Symbol Parameter Test Conditions BVDSS Drain-Source Breakdown Voltage RDS(ON) Static Drain-Source OnResistance2 VGS=0V, ID=250uA Typ. 60 - Gate Threshold Voltage VDS=VGS, ID=250uA Max. Units - V - 6 10 mΩ - 8.3 15 mΩ 1 1.4 3 V VGS=10V, ID=45A VGS=4.5V, ID=30A VGS(th) Min. gfs Forward Transconductance VDS=10V, ID=30A - 71 - S IDSS Drain-Source Leakage Current VDS=60V, VGS=0V - - 10 uA Current VDS=48V ,VGS=0V - - 250 uA Drain-Source (Tj=125oC) Leakage IGSS Gate-Source Leakage VGS=+20V, VDS=0V - - +100 nA Qg Total Gate Charge ID=30A - 33 45 nC Qgs Gate-Source Charge VDS=48V - 5 - nC Qgd Gate-Drain ("Miller") Charge - 21 - nC td(on) Turn-on Delay Time VDS=30V - 10 - ns tr Rise Time ID=30A - 43 - ns td(off) Turn-off Delay Time - 47 - ns tf Fall Time - 80 - ns Ciss VGS=4.5V RG=3.3Ω VGS=10V Input Capacitance Coss Output Capacitance Crss VGS=0V - 2680 3300 pF - 260 - pF Reverse Transfer Capacitance VDS=25V f=1.0MHz - 180 - pF VSD Forward On Voltage2 IS=45A, VGS=0V - - 1.3 V trr Reverse Recovery Time IS=10A, VGS=0V, dI/dt=100A/µs - 30 - ns Qrr Reverse Recovery Charge - 18 - nC www.msksemi.com AOD2606-MS Semiconductor Compiance Typical Performance Characteristics 200 100 10V 7.0V o T C =25 C 160 80 ID , Drain Current (A) ID , Drain Current (A) 10V 7.0V 5.0V 4.5V T C = 150 o C 5.0V 120 4.5V 80 40 60 40 V G =3.0V 20 V G =3.0V 0 0 0 2 4 6 8 10 0 12 1 Fig 1. Typical Output Characteristics 3 4 5 6 Fig 2. Typical Output Characteristics 16 2.0 I D = 30 A I D =45A V G =10V T C =25 o C Normalized RDS(ON) 14 RDS(ON) (mΩ ) 2 V DS , Drain-to-Source Voltage (V) V DS , Drain-to-Source Voltage (V) 12 1.6 1.2 0.8 10 0.4 8 2 4 6 8 -50 10 V GS , Gate-to-Source Voltage (V) 0 50 100 150 o T j , Junction Temperature ( C) Fig 3. On-Resistance v.s. Gate Voltage Fig 4. Normalized On-Resistance v.s. Junction Temperature 1.5 40 T j =150 o C Normalized VGS(th) IS(A) 30 T j =25 o C 20 1.1 0.7 10 0 0.3 0 0.2 0.4 0.6 0.8 1 V SD , Source-to-Drain Voltage (V) Fig 5. Forward Characteristic of Reverse Diode 1.2 -50 0 50 100 150 T j , Junction Temperature ( o C) Fig 6. Gate Threshold Voltage v.s. Junction Temperature www.msksemi.com AOD2606-MS Semiconductor I D = 30 A V DS =48V 5 3000 4 C iss C (pF) VGS , Gate to Source Voltage (V) f=1.0MHz 4000 6 3 2000 2 1000 1 C oss C rss 0 0 0 10 20 30 40 50 1 60 21 Q G , Total Gate Charge (nC) 41 61 81 V DS , Drain-to-Source Voltage (V) Fig 7. Gate Charge Characteristics Fig 8. Typical Capacitance Characteristics 1 Normalized Thermal Response (R thjc) 1000 Operation in this area limited by RDS(ON) 100 100us ID (A) Compiance 10 1ms 10ms 100ms DC 1 T C =25 o C Single Pulse 0.1 Duty factor=0.5 0.2 0.1 0.1 0.05 PDM t 0.02 T 0.01 Duty factor = t/T Peak Tj = PDM x Rthjc + TC Single Pulse 0.01 0.1 1 10 100 1000 0.00001 0.0001 V DS , Drain-to-Source Voltage (V) 0.001 0.01 0.1 1 t , Pulse Width (s) Fig 9. Maximum Safe Operating Area Fig 10. Effective Transient Thermal Impedance 100 T j =25 o C V DS =5V VG T j =150 o C ID , Drain Current (A) 80 QG 4.5V 60 QGS QGD 40 20 Charge Q 0 0 2 4 6 8 V GS , Gate-to-Source Voltage (V) Fig 11. Transfer Characteristics Fig 12. Gate Charge Waveform www.msksemi.com AOD2606-MS Semiconductor Compiance PACKAGE MECHANICAL DATA D A D1 c E V L3 h L4 L A1 L2 L1 D2 b e θ Symbol A A1 b c D D1 D2 E e L L1 L2 L3 L4 θ h V Dimensions In Millimeters Min. Max. 2.200 2.400 0.000 0.127 0.635 0.770 0.460 0.580 6.500 6.700 5.100 5.460 4.830 REF. 6.000 6.200 2.186 2.386 9.712 10.312 2.900 REF. 1.400 1.700 1.600 REF. 0.600 1.000 0° 0.000 5.250 REF. 8° 0.300 Dimensions In Inches Min. Max. 0.087 0.094 0.000 0.005 0.025 0.030 0.018 0.023 0.256 0.264 0.201 0.215 0.190 REF. 0.236 0.244 0.086 0.094 0.382 0.406 0.114 REF. 0.055 0.067 0.063 REF. 0.024 0.039 0° 0.000 0.207 REF. 8° 0.012 REEL SPECIFICATION P/N PKG QTY AOD2606-MS TO-252 2500 www.msksemi.com AOD2606-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
AOD2606-MS 价格&库存
很抱歉,暂时无法提供与“AOD2606-MS”相匹配的价格&库存,您可以联系我们找货
