Rev 1.3
DIO8242F2
Adaptive 100/120Hz Current Ripple Remover
Max Input Current ≤ 120mA
Features
Descriptions
Regulator for adaptive 100/120Hz current
DIO8242F2 is a regulator for driving internal
ripple remove
NMOSFET to remove the 100/120Hz LED string
Built-in
zener
diode
for
input
voltage
current ripple on AC/DC power.
clamping
Built-in 100V power MOSFET
Patented control strategies are optimized for
Programmable amplitude LED current ripple
remover current ripple. Nover circuit design
Programmable maximum cathode voltage of
makes a lower BOM and high cost-effective for
LED
flickerless filament.
Programmable maximum LED current
Optimized for TRIAC dimming, 1% brightness
without flicker
The current ripple is less than ±1%
SOT23-3,SOT89-3 and SOT223 packages
Applications
LED lighting
Ordering Information
Order Part Number
Top Marking
TA
Package
DIO8242F2ST3
2013
Green
-40 to 125°C
SOT23-3
Tape & Reel,3000
DIO8242F2TC3
2013
Green
-40 to 125°C
SOT89-3
Tape & Reel,2500
DIO8242F2TD3
2013
Green
-40 to 125°C
SOT223
Tape & Reel,2500
www.dioo.com
© 2019 DIOO MICROCIRCUITS CO., LTD
DIO8242F2• Rev. 1.3
DIO8242F2
SOT23-3
VC
SOT89-3/SOT223
1
3
GND
LEDN
2
1
2
3
VC
LE D N
GND
Figure 1 Top View
Pin Descriptions
Name
GND
VC
LEDN
www.dioo.com
Description
Power Ground
LED Current Ripple Programming
Connect to the Cathode of LED string
DIO8242F2• Rev.1.3
Adaptive 100/120Hz Current Ripple Remover Max Input Current ≤ 120mA
Pin Assignment
DIO8242F2
Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress
ratings only and functional operation of the device at these or any other condition beyond those indicated in the operational
sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect
device reliability.
Parameter
Rating
Unit
100
V
-0.3 to 6
V
Junction Temperature
150
°C
Lead Temperature
260
°C
-65 to 150
°C
LEDN
VC
Storage Temperature
Thermal Resistance / θJA
Thermal Resistance / θJC
SOT23-3
220
SOT89-3
80
SOT223
50
SOT23-3
130
SOT89-3
25
SOT223
°C/W
°C/W
Recommend Operating Conditions
The Recommended Operating Conditions table defines the conditions for actual device operation. Recommended Operating
conditions are specified to ensure optimal performance to the datasheet specifications. DIOO does not Recommend exceeding
them or designing to Absolute Maximum Ratings.
Parameter
LEDN
Junction Temperature (TJ)
Under point VLEDN
Power consumption
www.dioo.com
Rating
Unit
< 100
V
125
°C
0.8~1.2
V
SOT23-3
< 250
SOT89-3
< 650
SOT223
< 800
mW
DIO8242F2• Rev.1.3
DIO8242F2
Typical value: Vcc=3.6V, TA=25°C, unless otherwise specified.
Symbol
Parameter
IST
Conditions
Min.
Typ.
Max.
Unit
1
uA
Start-up Current
VREF
LEDN Compare Voltage
ICLMT
LED Current Limit
RDSON
MOS Rdson
BV
Breakdown Voltage
6
V
120
8
100
mA
Ω
V
Specifications subject to change without notice.
Typical Performance Characteristics
CVC=1μF, CEC=8.2μF, unless otherwise specified.
LED Current Ripple without DIO8242F2
(VAC=220V,VLED=250V,ILED=15mA)
AC Source Power ON
(VAC=120V,VLED=125V,ILED=15mA)
www.dioo.com
LED Current Ripple with DIO8242F2
AC Source Power OFF
DIO8242F2• Rev.1.3
Electrical Characteristics
DIO8242F2
Function Description
DIO8242F2 is designed for driving one LED string and removing the 100/120Hz LED current ripple.
Theory of Operation
The LED string and DIO8242F2 are both supplied by an AC/DC current source. The drain of internal
NMOSFET is connected to the cathode of LED string. A sensing resistor Rcs is connected between the source
of NMOSFET and GND. DIO8242F2 drives NMOSFET to transfer the LED current ripple to voltage ripple on
NMOSFET, and ensures the constant voltage across LED string and the constant current flow through LED
string. The scalable adaptive function of DIO8242F2 can regulate the cathode voltage of LED string to
minimum to improve the efficiency of the system.
Current Ripple Removing
The capacitor CC between VC and GND is an integral capacitor.
DIO8242F2 transform the voltage on Cc to a
reference voltage. The current regulator regulates LED current via negative feedback control.
CC should be large enough in order to remove the current ripple of the LED string. However, too large capacitor
may slow down the dynamic response.
www.dioo.com
DIO8242F2• Rev.1.3
Block Diagram
DIO8242F2
DIO8242F2 controls
the voltage on CC by monitoring
the operation state of built-in N-MOSFET. The
efficiency of system is relatively low when N-MOSFET always works in the saturation region. DIO8242F2
detects
it and charges CC to raise the VVC and ILED, then the output voltage of power supply is reduced, and
the voltage drop on N-MOSFET decreases.
Conversely, when N-MOSFET is working in the linear region, LED current regulation loop is open. DIO8242F2
detects it and discharges CC to reduce the VVC and ILED, then the output voltage of power supply is raised, and
the LED current regulation loop is closed.
PCB Design Guideline
1.
DIO8242F2 should be placed far away from the power devices for better thermal performance.
2.
The area of LED current loop should be as small as possible.
Application Information
DIO8242F2 design guide:
IN+
LEDN
DIO8242F2
VC
GND
IN-
1.
The value of the capacitor between VC and GND can determine the final amplitude of the current ripple. It
capacitor may low down the dynamic response.
www.dioo.com
DIO8242F2• Rev.1.3
Adaptive Regulation
DIO8242F2
COMMON DIMENSIONS
(UNITS OF MEASURE=MILLIMETER)
Symbol
MIN
NOM
MAX
A
1.25
A1
A2
1.00
1.10
1.20
A3
0.60
0.65
0.70
b
0.36
0.50
b1
0.36
0.38
0.45
c
0.14
0.20
c1
0.14
0.15
0.16
D
2.826
2.926
3.026
E
2.60
2.80
3.00
E1
1.526
1.626
1.726
e
0.90
0.95
1.00
e1
1.80
1.90
2.00
L
0.35
0.45
0.60
L1
0.59REF
L2
0.25BSC
R
0.05
R1
0.05
0.20
Θ
0°
8°
Θ1
3°
5°
7°
Θ2
6°
14°
www.dioo.com
DIO8242F2• Rev.1.3
Physical Dimensions: SOT23-3
DIO8242F2
www.dioo.com
Symbol
Min.
NOM.
Max.
A
1.40
1.50
1.60
b
1.68
1.77
b1
1.67
1.70
1.73
b2
0.38
0.47
b3
0.37
0.40
0.43
b4
0.46
0.55
b5
0.45
0.48
0.51
c
0.40
0.44
c1
0.39
0.40
0.41
D
4.40
4.50
4.60
D1
4.35
4.45
4.55
D2
1.60
1.75
1.90
D3
0.75
0.90
1.05
D4
1.60
1.70
1.80
E
2.40
2.50
2.60
E1
2.13
2.19
e
1.50BSC
e1
3.00BSC
H
4.05
4.25
H1
2.70
3.00
H2
L
0.89
1.20
θ1
6°
8°
10°
θ2
3°
5°
7°
θ3
85°
90°
95°
DIO8242F2• Rev.1.3
Physical Dimensions: SOT89-3
DIO8242F2
COMMON DIMENSIONS
Symbol
MIN
NOM
MAX
A
1.80
A1
0.02
0.10
A2
1.50
1.60
1.70
A3
0.80
0.90
1.00
b
0.67
0.80
b1
0.66
0.71
0.76
b2
2.96
3.09
b3
2.95
3.00
3.05
c
0.24
0.35
c1
0.23
0.25
0.30
D
6.43
6.48
6.58
E
6.80
7.00
7.20
E1
3.30
3.38
3.53
e
2.25
2.30
2.35
e1
4.50
4.60
4.70
L
0.80
1.00
1.20
L1
1.81REF
R
0.10
R1
0.10
Θ
0°
8°
Θ1
10°
12°
14°
www.dioo.com
DIO8242F2• Rev.1.3
Physical Dimensions: SOT223
DIO8242F2
Dioo is a professional design and sales corporation for high-quality and performance analog semiconductors. The company focuses
on industry markets, such as, cell phone, handheld products, laptop, and medical equipment and so on. Dioo’s product families include
analog signal processing and amplifying, LED drivers and charger IC. Go to http://www.dioo.com for a complete list of Dioo product
families.
For additional product information, or full datasheet, please contact with our Sales Department or Representatives.
www.dioo.com
DIO8242F2• Rev.1.3
CONTACT US
很抱歉,暂时无法提供与“DIO8242F2TC3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.06445
- 50+0.83582
- 150+0.73786
- 500+0.61560
- 2500+0.56117
