JW1851
JW1851
    JOULWATT(杰华特)
    SOT-89-3
    双色LED稳压器
JW1851 数据手册
JW1851 Dual Color LED Regulator Parameters Subject to Change Without Notice DESCRIPTION FEATURES JW ®1851 is a dual color LED regulator, which is very simple to use in light-color dimming system. The warm color or cold color LED current is determined by external resistors. It supports applications with high input voltage up to 500VDC. Specially designed current sensing techniques help to realize the color dimming function, and the dimming curve is easy to be defined according to customer requirements. JW1851 provides over temperature protection function to prevent device damaging. IC reduces OUT1 current When temperature inside chip exceeds 150 , which helps the chip cooling.  Supports dual color LED strings  Ultra-low quiescent current  500V MOS built-in  Low BOM cost with only 2 SMD resistors  Over temperature protection.  No EMI issues.  SOT89-3 package APPLICATIONS  Dual-Color Bulb lamp, Light-Color Dimming ℃ Company’s Logo is Protected, “JW” and “JOULWATT” are Registered Trademarks of JoulWatt technology Inc. TYPICAL APPLICATION LED2 Cold LED1 Warm JW1851 Rev.0.81 ® JoulWatt Proprietary Information. Patent Protected. Unauthorized Photocopy and Duplication Prohibited. 1
