HT317LRHZ
HT317LRHZ
    HTCSEMI(海天芯)
    SOT-89-3
    1.2V~37V 100MA
HT317LRHZ 数据手册
HT317L 100 mA Adjustable Output, Positive Voltage Regulator The HT317L is an adjustable 3−terminal positive voltage regulator capable of supplying in excess of 100 mA over an output voltage range of 1.2 V to 37 V. This voltage regulator is exceptionally easy to use and requires only two external resistors to set the output voltage. Further, it employs internal current limiting, thermal shutdown and safe area compensation, making them essentially blow−out proof. The HT317L serves a wide variety of applications including local, on card regulation. This device can also be used to make a programmable output regulator, or by connecting a fixed resistor between the adjustment and output, the HT317L can be used as a precision current regulator. Features          Output Current in Excess of 100 mA Output Adjustable Between 1.2 V and 37 V Internal Thermal Overload Protection Internal Short Circuit Current Limiting Output Transistor Safe−Area Compensation Floating Operation for High Voltage Applications Standard 3−Lead Transistor Package Eliminates Stocking Many Fixed Voltages NCV Prefix for Automotive and Other Applications Requiring Unique Site and Control Change Requirements; AEC−Q100 Qualified and PPAP Capable  These are Pb−Free Devices PIN CONNECTIONS 8 1 SOP8 R SUFFIX HT317LRZ BENT LEAD TAPE & REEL AMMO PACK 1 Simplified Application Vin Pin 1. V in 2. V out 3. Vout 4. Adjust 5. N.C. 6. Vout 7. Vout 8. N.C. 2 3 TO92 P SUFFIX HT317LRPZ Pin 1. Adjust 2. Vout 3. Vin Vout HT317L Vin R1 240 IAdj Cin* 0.1µF + C ** O 1.0µF Adjust Vout 1 XDFN4 Q SUFFIX HT317LRQZ Pin A1. Adjust A2. Vout B1. Vin B2. N.C. R2 A1 A2 B1 B2 ADJ (Top Nc. View) TAB * Cin is required if regulator is located an appreciable distance from power supply filter. ** CO is not needed for stability, however, it does improve transient response. ( ) R Vout = 1.25 V 1 + 2 + IAdj R1 R2 1 SOT−89 H SUFFIX HT317LRHZ Pin 1. Adjust 2. Vout 3. Vin Since I Adj is controlled to less than 100 µA, the error associated with this term is negligible in most applications. Rev. 01 HT317L MAXIMUM RATINGS Symbol Value Unit Input−Output Voltage Differential Rating VI −VO 40 Vdc Power Dissipation Case 29 (TO−92) TA = 25C Thermal Resistance, Junction−to−Ambient Thermal Resistance, Junction−to−Case PD R8JA R8JC Internally Limited 160 83 W C/W C/W Case 751 (SOIC−8) (Note 1) TA = 25C Thermal Resistance, Junction−to−Ambient Thermal Resistance, Junction−to−Case PD R8JA R8JC Internally Limited 180 45 W C/W C/W TJ −40 to +150 C Tstg −65 to +150 C Operating Junction Temperature Range Storage Temperature Range Stresses exceeding Maximum Ratings may damage the device. Maximum Ratings are stress ratings only. Functional operation above the Recommended Operating Conditions is not implied. Extended exposure to stresses above the Recommended Operating Conditions may affect device reliability. 1. SOIC−8 Junction−to−Ambient Thermal Resistance is for minimum recommended pad size. Refer to Figure 24 for Thermal Resistance variation versus pad size. 2. This device series contains ESD protection and exceeds the following tests: Human Body Model, 2000 V per MIL STD 883, Method 3015. Machine Model Method, 200 V. Vin 300 300 300 3.0k 6.8V 70 300 6.8V 350 18k 8.67k 500 130 400 5.1k 200k 6.3V 180 180 2.0k 6.0k 60 10 p 10 F p F 2.5 Vout 2.4k 12.8k 50 Adjust Figure 1. Representative Schematic Diagram Rev. 01 HT317L VCC VOH - V OL x 100 VOL Line Regulation (%/V) = * VOH VIH Vout V IL V in VOL HT317L Adjust Cin 0.1µF R1 240 1% RL + CO IAdj 1µF R2 1 % * Pulse Testing Required: 1% Duty Cycle is suggested. Figure 2. Line Regulation and 庄IAdj/Line Test Circuit Load Regulation (mV) = V O (min Load) -VO (max Load) VO (min Load) - VO (max Load) Load Regulation (% VO) = VO (min Load) Vin * X 100 V (min Load) O VO (max Load) Vout Vin HT317L IL RL (max Load) 240 R1 1% Adjust * + Cin 0.1µF CO IAdj RL (min Load) 1.0µF R2 1% * Pulse Testing Required: 1% Duty Cycle is suggested. Figure 3. Load Regulation and 庄IAdj/Load Test Circuit Vin Vout HT317L IL Adjust R1 IAdj VI Cin 240 1% Vref RL + 0.1µF VO CO ISET Pulse Testing Required: 1% Duty Cycle is suggested. R2 1% To Calculate R 2: Vout = ISET R2 + 1.250 V Assume I SET = 5.25 mA 1µ F Figure 4. Standard Test Circuit Rev. 01 HT317L 14.30V Vout Vin 4.30V f = 120 Hz Vout = 1.25 V HT317L Adjust Cin D1 * 1N4002 240 1% R1 0.1µF CO R2 RL + 1µF VO + 1.65K 1% 10µF ** * D1 Discharges C Adj if Output is Shorted to Ground. **C Adj provides an AC ground to the adjust pin. 0.4 Vin = 45 V Vout = 5.0 V IL = 5.0 mA to 40 mA 0.2 RR, RIPPLE REJECTION (dB)  V out, OUTPUT VOLTAGE CHANGE (%) Figure 5. Ripple Rejection Test Circuit 0 -0.2 Vin = 10 V Vout = 5.0 V IL = 5.0 mA to 100 mA -0.4 -0.6 -0.8 80 70 IL = 40 mA f = 120 Hz Vout = 10 V Vin = 14 V to 24 V 60 50 -1.0 -50 -25 0 25 50 75 100 125 TJ, JUNCTION TEMPERATURE (C) 150 -50 -25 Figure 6. Load Regulation 150 Figure 7. Ripple Rejection 0.50 V in -Vout , INPUT-OUTPUT VOLTAGE DIFFERENTIAL (V) 2.5 TJ = 25C IO, OUTPUT CURRENT (A) 0 25 50 75 100 125 TJ, JUNCTION TEMPERATURE (C) 0.40 0.30 0.20 TJ = 150C 0.10 0 2.0 IL = 100 mA 1.5 IL = 5 .0 mA 1.0 0.5 0 10 20 30 40 Vin-Vout, INPUT-OUTPUT VOLTAGE DIFFERENTIAL (V) Figure 8. Current Limit 50 -50 -25 0 25 50 75 100 125 TJ, JUNCTION TEMPERATURE (C) 150 Figure 9. Dropout Voltage Rev. 01 HT317L 100 4.5 90 TJ = 55C TJ = 25C TJ = 150C 4.0 3.5 RR, RIPPLE REJECTION (dB) IB , QUIESCENT CURRENT (mA) 5.0 3.0 2.5 2.0 1.5 1.0 0.5 70 60 50 40 30 20 10 0 10 20 30 40 Vin-Vout, INPUT-OUTPUT VOLTAGE DIFFERENTIAL (V) 10 Figure 10. Minimum Operating Current 100 10 k 100 k 1.0 M f, FREQUENCY (Hz) 1.250 1.240 Vin = 4.2 V Vout = V ref IL = 5.0 mA 1.230 IAdj, ADJUSTMENT PIN CURRENT (A) 80 1.220 70 65 Vin = 6.25 V Vout = Vref IL = 10 mA IL = 100 mA 60 55 50 45 40 35 -50 -25 0 25 50 75 100 125 150 TJ, JUNCTION TEMPERATURE (C) -50 0.4 Vin = 4.25 V to 41.25 V Vout = Vref IL = 5 mA 0.2 0 -0.2 -0.4 -0.6 -25 0 25 50 75 100 125 150 TJ, JUNCTION TEMPERATURE (C) Figure 13. Adjustment Pin Current NOISE VOLTAGE (V) Figure 12. Temperature Stability  Vout , OUTPUT VOLTAGE CHANGE (%) 1.0 k Figure 11. Ripple Rejection versus Frequency 1.260 V ref , REFERENCE VOLTAGE (V) IL = 40 mA Vin = 5.0 V  1.0 V PP Vout = 1.25 V 80 Bandwidth 100 Hz to 10 kHz 10 8.0 6.0 -0.8 -1.0 4.0 -50 -25 0 25 50 75 100 125 150 TJ, JUNCTION TEMPERATURE (C) Figure 14. Line Regulation -50 -25 0 25 50 75 100 125 150 TJ, JUNCTION TEMPERATURE (C) Figure 15. Output Noise Rev. 01  Vout , OUTPUT VOLTAGE DEVIATION (V) 1.5 1.0 CL = 1.0 µF; C Adj = 10 µF 0.5 0 V in , INPUT VOTLAGE CHANGE (V) -0.5 Vout = 10 V IL = 50 mA TJ = 25C -1.0 -1.5 CL = 0; Without C Adj 1.0 Vin 0.5 0 0 10 20 30 40 0.3 0.2 CL = 1 µF; CAdj = 10 µF 0.1 0 -0.1 Vin = 15 V Vout = 10 V I NL = 50 mA TJ = 25C CL = 0.3 µF; CAdj = 10 µF -0.2 I L , LOAD CURRENT (mA) Vout , OUTPUT VOLTAGE DEVIATION (V) HT317L -0.3 100 IL 50 0 0 10 20 30 40 t, TIME (µs) t, TIME (µs) Figure 16. Line Transient Response Figure 17. Load Transient Response APPLICATIONS INFORMATION Basic Circuit Operation Load Regulation The HT317L is a 3−terminal floating regulator. In operation, the HT317L develops and maintains a nominal 1.25 V reference (Vref) between its output and adjustment terminals. This reference voltage is converted to a programming current (IPROG) by R1 (see Figure 13), and this constant current flows through R2 to ground. The regulated output voltage is given by: The HT317L is capable of providing extremely good load regulation, but a few precautions are needed to obtain maximum performance. For best performance, the programming resistor (R1) should be connected as close to the regulator as possible to minimize line drops which effectively appear in series with the reference, thereby degrading regulation. The ground end of R2 can be returned near the load ground to provide remote ground sensing and improve load regulation. Vout = Vref (1 + R2 ) + IAdj R2 R1 Since the current from the adjustment terminal (IAdj) represents an error term in the equation, the HT317L was designed to control IAdj to less than 100 µA and keep it constant. To do this, all quiescent operating current is returned to the output terminal. This imposes the requirement for a minimum load current. If the load current is less than this minimum, the output voltage will rise. Since the HT317L is a floating regulator, it is only the voltage differential across the circuit which is important to performance, and operation at high voltages with respect to ground is possible. Vout Vin HT317L + R1 External Capacitors A 0.1 µF disc or 1.0 µF tantalum input bypass capacitor (Cin) is recommended to reduce the sensitivity to input line impedance. The adjustment terminal may be bypassed to ground to improve ripple rejection. This capacitor (CAdj) prevents ripple from being amplified as the output voltage is increased. A 10 µF capacitor should improve ripple rejection about 15 dB at 120 Hz in a 10 V application. Although the HT317L is stable with no output capacitance, like any feedback circuit, certain values of external capacitance can cause excessive ringing. An output capacitance (CO) in the form of a 1.0 µF tantalum or 25 µF aluminum electrolytic capacitor on the output swamps this effect and insures stability. Vref Adjust IPROG Vout IAdj R2 Vref = 1.25 V Typical Figure 18. Basic Circuit Configuration Rev. 01 HT317L Protection Diodes D1 When external capacitors are used with any IC regulator it is sometimes necessary to add protection diodes to prevent the capacitors from discharging through low current points into the regulator. Figure 14 shows the HT317L with the recommended protection diodes for output voltages in excess of 25 V or high capacitance values (CO > 10 µF, CAdj > 5.0 µF). Diode D1 prevents CO from discharging thru the IC during an input short circuit. Diode D2 protects against capacitor CAdj discharging through the IC during an output short circuit. The combination of diodes D1 and D2 prevents CAdj from discharging through the IC during an input short circuit. 1N4002 Vin Vout HT317L + Cin R1 CO D2 Adjust 1N4002 CAdj R2 Figure 19. Voltage Regulator with Protection Diodes +25V Vout HT317L VO R1 IO 1.25k Vin Adjust D1 D1 1N914 R2 500 * To provide current limiting of I O to the system ground, the source of the current limiting diode must be tied to a negative voltage below - 7.25 V. 1N4002 Vin Vout HT317L D2 1N914 + 1.0µF 120 Adjust MPS2222 1N5314 Vref R2  I DSS R1 = TTL Control 720 1.0k VSS* Vref IOmax + IDSS Minimum Vout = 1.25 V VO < P OV + 1.25 V + VSS ILmin - IP < IO < 100 mA - IP As shown O < I O < 95 mA D1 protects the device during an input short circuit. Figure 20. Adjustable Current Limiter Figure 21. 5.0 V Electronic Shutdown Regulator Vin R1 HT317L Iout Vout I Adj Adjust Vout Vin R2 HT317L 240 Ioutmax = 50k Adjust R2 1N4002 MPS2907 + I 10µF outmax = Vref R1 + IAdj 三 1.25 V R1 Vref R1 + R2 +I Adj 三 1.25 V R1 + R 2 5.0 mA < I out < 100 mA Figure 22. Slow Turn−On Regulator Figure 23. Current Regulator Rev. 01 HT317L 3.2 150 2.8 P D(max) for TA = 50C 2.4 130 110 2.0 Graph represents symmetrical layout 90 L 1.6 2.0 oz. Copper 1.2 70 L 3.0 mm 50 0.8 RJA 30 0 10 0.4 20 30 40 PD, MAXIMUM POWER DISSIPATION (W) R JA, THERMAL RESISTANCE JUNCTION-TO-AIR (C/W) 170 50 L, LENGTH OF COPPER (mm) Figure 24. SOP−8 Thermal Resistance and Maximum Power Dissipation versus P.C.B. Copper Length Rev. 01 HT317L PACKAGE DIMENSIONS TO−92 (TO−226) Z SUFFIX CASE 29−11 ISSUE AM A B STRAIGHT LEAD BULK PACK R P NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. CONTOUR OF PACKAGE BEYOND DIMENSION R IS UNCONTROLLED. 4. LEAD DIMENSION IS UNCONTROLLED IN P AND BEYOND DIMENSION K MINIMUM. L SEATING PLANE K D X X G J H V C SECTION X−X 1 N DIM A B C D G H J K L N P R V INCHES MIN MAX 0.175 0.205 0.170 0.210 0.125 0.165 0.016 0.021 0.045 0.055 0.095 0.105 0.015 0.020 0.500 --0.250 --0.080 0.105 --0.100 0.115 --0.135 --- MILLIMETERS MIN MAX 4.45 5.20 4.32 5.33 3.18 4.19 0.407 0.533 1.15 1.39 2.42 2.66 0.39 0.50 12.70 --6.35 --2.04 2.66 --2.54 2.93 --3.43 --- N A R BENT LEAD TAPE & REEL AMMO PACK B P NOTES: 1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M, 1994. 2. CONTROLLING DIMENSION: MILLIMETERS. 3. CONTOUR OF PACKAGE BEYOND DIMENSION R IS UNCONTROLLED. 4. LEAD DIMENSION IS UNCONTROLLED IN P AND BEYOND DIMENSION K MINIMUM. T SEATING PLANE K G D X X J V 1 C SECTION X−X DIM A B C D G J K N P R V MILLIMETERS MIN MAX 4.45 5.20 4.32 5.33 3.18 4.19 0.40 0.54 2.40 2.80 0.39 0.50 12.70 --2.04 2.66 1.50 4.00 2.93 --3.43 --- N Rev. 01 HT317L PACKAGE DIMENSIONS SOIC−8 NB D SUFFIX CASE 751−07 ISSUE AK NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: MILLIMETER. 3. DIMENSION A AND B DO NOT INCLUDE MOLD PROTRUSION. 4. MAXIMUM MOLD PROTRUSION 0.15 (0.006) PER SIDE. 5. DIMENSION D DOES NOT INCLUDE DAMBAR PROTRUSION. ALLOWABLE DAMBAR PROTRUSION SHALL BE 0.127 (0.005) TOTAL IN EXCESS OF THE D DIMENSION AT MAXIMUM MATERIAL CONDITION. 6. 751−01 THRU 751−06 ARE OBSOLETE. NEW STANDARD IS 751−07. −X− A 8 5 S B 0.25 (0.010) M Y M 1 4 K −Y− G C N X 45 DIM A B C D G H J K M N S 。 SEATING PLANE −Z− 0.10 (0.004) H M D 0.25 (0.010) M Z Y S X J S MILLIMETERS 。 MIN MAX 4.80 5.00 3.80 4.00 1.35 1.75 0.33 0.51 1.27 BSC 0.10 0.25 0.19 0.25 0.40 1.27 0 8 0.25 0.50 5.80 6.20 。 INCHES 。 MIN MAX 0.189 0.197 0.150 0.157 0.053 0.069 0.013 0.020 0.050 BSC 0.004 0.010 0.007 0.010 0.016 0.050 0 8 0.010 0.020 0.228 0.244 。 SOLDERING FOOTPRINT* 1.52 0.060 7.0 0.275 0.6 0.024 4.0 0.155 1.270 0.050 SCALE 6:1 ) mm (inches *For additional information on our Pb−Free strategy and soldering details, please download the ON Semiconductor Soldering and Mounting Techniques Reference Manual, SOLDERRM/D. Rev. 01
HT317LRHZ 价格&库存
很抱歉,暂时无法提供与“HT317LRHZ”相匹配的价格&库存,您可以联系我们找货
HT317LRHZ
  • 1+0.55005
  • 10+0.44637
  • 30+0.39453
  • 100+0.35565
  • 500+0.32454
  • 1000+0.25380
库存:80
